I have a Jeeping problem !
AMC-MJ
So after owning the shortbed 2wd MJ long enough to fall in love with it then plan out an AMC V8 power train swap . . . I snatched up an 82' Jeep J/10 Honcho, Its getting a J/20 conversion :-) !
So ill have an AMC- V8 Comanche and a 3/4ton Honcho . . . Yep you read it right, Shortbed stepside 3/4ton Jeep ! ! !
What a pair
Mike
1953 Studebaker M275 <- - Well aware of what 2.5ton Rockwells are ;-) !
I'll end up at the same payload & Towed load has the M715, My truck will look like the AM-General AM715/720s, look way better then the M715s I dislike the windshield and wheel wells !
PO is keeping the OEM honcho rear fenders ;-( !
Mike
Its been a long day/night worked a side job for some cash then we get dumped on with some snow so into work work I go . . . Shoveling walks n stoops then salting it all down . . . The tosses some cash for fuel on top of my snow removal wage so I use good ol'AMC MJ ;-) !
Well tonight my door open hard a couple times hitting the fender then it shut really hard, door sticks out like 1/2" from were the fender sits I'm guessing the Hinge pulled out of the Cab like my 62' did years ago ;-( !
I'm going to repair it, Yep you read that right I am going to fix it !
Now if that isn't a Jeeping problem I don't know what is ! ! !
Mike
