kawaboy13 Posted November 27, 2010 Share Posted November 27, 2010 I am tryingto get these coil springs off of a parts truck. Please help. As you can see, I have a few things disconnected. I have the frame on stands. I lowereed the jack that was holding up the front axle and it's still hanging up there. What else needs to be done? I'm trying to get these out and onto my truck before dark. Link to comment Share on other sites More sharing options...
mvusse Posted November 27, 2010 Share Posted November 27, 2010 I'm thinking track bar. After it is off the upper and/or lower control arms can possibly still hold it up too high. There are tabs on the frame that prevent the upper arms from dropping too far, and the lower arms can hit the axle bracket preventing it from going down far enough. And then the brake hoses may hit their end also. Also, if you take off the bump stops (put a pipe wrench through the spring onto the rusty metal part above the rubber stop, it just unscrews) you need 4" less to get the springs out. I find it easiest to unbolt everything. But putting it back together can be a pain as you'll be fighting the springs trying to get the control arms bolted up. Link to comment Share on other sites More sharing options...
Oizarod115 Posted November 27, 2010 Share Posted November 27, 2010 Link to comment Share on other sites More sharing options...
mnkyboy Posted November 27, 2010 Share Posted November 27, 2010 Just go get a cheap spring compressor and they will come right out. The compressor will also help a lot when you reinstall them. Link to comment Share on other sites More sharing options...
foreman1063 Posted November 27, 2010 Share Posted November 27, 2010 Looks like the LCA'a are bottomed out. Also, jack up one side of the axle and step on the low side. The spring will usually come out then. Link to comment Share on other sites More sharing options...
kyleag89 Posted November 28, 2010 Share Posted November 28, 2010 You can not get springs out while the LCAs are bolted up. I have read somewhere where someone says you can but I call BS on that! With everything dis-connected and the bump stop removed you still need another 2" of room to get the coil out. Also you will need compressors to get the coils back in safely. Link to comment Share on other sites More sharing options...
foreman1063 Posted November 28, 2010 Share Posted November 28, 2010 You can not get springs out while the LCAs are bolted up. I have read somewhere where someone says you can but I call BS on that! With everything dis-connected and the bump stop removed you still need another 2" of room to get the coil out. Also you will need compressors to get the coils back in safely. Ok Link to comment Share on other sites More sharing options...
jimmy21669 Posted November 28, 2010 Share Posted November 28, 2010 You can not get springs out while the LCAs are bolted up. I have read somewhere where someone says you can but I call BS on that! With everything dis-connected and the bump stop removed you still need another 2" of room to get the coil out. Also you will need compressors to get the coils back in safely. Ok I have done it a half dozen times....never use spring compressors. And if you DO unbolt the control arms, the easiest was to get them back on is using a BIG pipe wrench on the axle tube to turn the axle to the right angle to seat the control arms. Link to comment Share on other sites More sharing options...
kawaboy13 Posted November 28, 2010 Author Share Posted November 28, 2010 Can someone point out the LCA's? Link to comment Share on other sites More sharing options...
jeepcoma Posted November 28, 2010 Share Posted November 28, 2010 Link to comment Share on other sites More sharing options...
jeepcoma Posted November 28, 2010 Share Posted November 28, 2010 I agree with the above though, go out to autozone or advance or any car parts place and rent their spring compressor (it's free!). I usually grab both the strut spring compressor and the coil spring compressor just so I can use both if I need to. If you can remove the control arms, you don't need the compressors and they will just slide right out (no need to remove the track bar either once the control arms are removed). Actually removing the arms can be a bugger though, beyond getting the nuts off you have to deal with removing the bolts from the holes (which often have tension so you can't just slide them out); since it's a junkyard truck I'd say skip the wrenches and just cut those arms in half if you're that desperate. When it comes to installation on your truck, if you're trying to do this is a hurry, take a moment to step back and approach this the right way. You do not want to unbolt the control arms if you've never done this before, besides just the trouble of removing them the first time, it is a real big hassle to get them installed again. I've done it several times now so it's a quick job for me, I know how to wiggle the axle around and where to put jacks to get the right twist to get holes to line up, but really it's not a fun thing to do if you're in a hurry (I speak from experience!). Get the right tool and do the job the right way! Link to comment Share on other sites More sharing options...
mnkyboy Posted November 28, 2010 Share Posted November 28, 2010 I would just buy one,you can pick one up for as little as $10. http://www.harborfreight.com/macpherson ... -3980.html Link to comment Share on other sites More sharing options...
mkbruin Posted November 28, 2010 Share Posted November 28, 2010 1) Factory springs will come out without a spring compressor, but you need a breaker bar and know how to cheat death if it comes flying out. 2) Aftermarket springs need a compressor. These coils are not factory. I know this because you have said they have more lift than your normal truck, and the diameter of the coil is larger than factory. 3) You need a coil spring compressor. Parts stores "rent" them for $25, and you get the $$ back when you return it. Or, buy a pair. I have one pair Harbor Freight, one pair craftsman. Craftsman is my primary, the HF is for backup use only. Remember, when the coil is comperssed, treat is like you are handeling live ordinance. If it pops loose, it can kill you. Tighten one side, then the other, then back to the other side, then back to the other. Alternate back and forth, and try not to let one side get a lot more compression than the other. Done right: even compression Link to comment Share on other sites More sharing options...
foreman1063 Posted November 28, 2010 Share Posted November 28, 2010 I have done it a half dozen times....never use spring compressors. I've done it before as well but wasn't gonna argue about it. Link to comment Share on other sites More sharing options...
mjtjnj Posted December 8, 2010 Share Posted December 8, 2010 You don't need to remove the LCA's, either, you can get them out, and I got 3" coils in without removing the LCA's. Link to comment Share on other sites More sharing options...
foreman1063 Posted December 8, 2010 Share Posted December 8, 2010 You don't need to remove the LCA's, either, you can get them out, and I got 3" coils in without removing the LCA's. Un-possible apparently ;) Link to comment Share on other sites More sharing options...
