project Old Rusty (new panel welded in)
well,
i think its time to start my build thread,
i have a swb 1989 comanche with 4x4 and a roll bar as of 7 hours away and counting, :yes:
it is blue :yes: i am buying it today, with out ever seeing it once :banana: jamminz.gif
more pics to come, teaser till later on today
things to do
Lift (mix between IRON MAN FAB and RUBICON EXPRESS)
rustoration (in midsts)
change locks (bought ROCK AUTO (did not work))
change ignition (bought ROCK AUTO)
change head lamp switch (bought ROCK AUTO (did not work))
buckets
bush wackers
re-gear
lockers
bed liner
  • Replies 61
Man the Rear axle was 1 of the 1st things I looked at when buying my Trucks, lol
Nice find for sure :cheers:
Absolutely. After I find out what drivetrain I am staring down, the ol' back axle gets a looking at.
Nice find there kid.
Rob L. :cheers: :cheers:
startin rippin stuff off :P
visor came off, taking front plate off putting some shinnies on :yes:
and started choppin the rusted rails off
got a helper, i think i got my sister with the jeep bug, shes workin on it with me :clapping:
before
got rained out,
more to come like always
and check this out, this is our jeep rolling down the driveway,
close hey?
found my fancy dancy hood prod (took so long to find it, i was looking at the hood itself thnking :hmm: theres not even a hole, i was used to the 86 one :P )
look what the previous owner lost
and how far i got today before i went to see an old gf before she moved (stupid idea)
pulled front clip(correct me if I'm wrong) stripped it, stripped my old one, going to replace lights on it tomorrow, and finish it, and bolt it back on
more to come :yes:
before
after, had to modify parts, (cut pieces off) to get it to fit on the renix front clip, those peices are frome a h/o front clip
fixing this p/o's crappy wiring
fixed
testing
out with the old
in with the new
rigging the tweeters to work
that's a basic 4wd leaf pack, NOT a metric ton pack.
two dead give-aways...
1st, it's a shortbed. they could have HD axles, but not MT springs from factory.
2nd is that the pictures show only 3 leafs plus an overload, which is normal.
thanks for clarifying :D
  • 3 weeks later...
update, kinda,
thanks to btm24 i got my build sheet before i was unable too
(btw in canada they don't have that feature to get a vin decoded)
Dear Meier:
Thank you for contacting the Jeep Customer Assistance Center regarding a
build sheet for your 1989 Jeep Comanche.
We are pleased to provide vehicle build information per your request.
According to our records, your vehicle was equipped from the factory
with the following:
Sales Code Description
ADH Heavy Duty Electrical Group
ADL Skid Plate Group
APAS Monotone Paint
BGAS Power Front Disc/Rear Drum Brakes
BKPS 10x2.5 Rear Drum Brakes
CBAP Straight Back Bench Seat
CKJS Black Vinyl Floor Covering
CSRS Passenger Assist Handles
DGB All 4-Speed Automatic Transmissions
DGSS 4-Speed Automatic AW4 Transmission
DHAS Lock-Up Torque Converter
DHNS Command-Trac Part Time 4WD System
DHTP Elec,Shift-on-the-Fly,P/Time T/Case
DJHS Dana M30/181MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRKP Dana 44/226MM Rear Axle
DSA Anti-Spin Differential Rear Axle
EAAC All Engines
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEHS Fixed Door Vent Glass
GFD Rear Sliding Window
GNAS Rear View Day/Night Mirror
GRZP Left Remote Mirror
GSZP Right Remote Control Mirror
GTZS Manual Remote Mirrors
HCDS Heater w/Instrument Pnl Ventilation
JAAS Instrument Panel
JAZS Analog Instrument Cluster
JBFS Instrument Panel Black Bezel
JDBS 180 KPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
JKBS Inst Panel Mounted Hood Release
LAFS Key in Ign/Seat Belt Warning Buzzer
LBCS Glove Box Lamp
LMAS Halogen Headlamps
MBJ Black Front Bumper
MB1S Black Front Bumper
MDAS Front License Plate Bracket
MFFS Black Grille
MHBS Bright Windshield Moldings
MMCS Upper Door Frame Moldings
MMGS Belt Moldings
NAAS Federal Emissions
NBKS EVAP Control System
NDAS Catalytic Converter
NF2S 18.5 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHKS Engine Block Heater
NMCP Heavy Duty Engine Cooling
PB3 Intense Blue Pearl Coat
QB3S Intense Blue Pearl Coat
RAAC All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCDP 4 Speakers
SBAA Power Rack and Pinion Steering
SCBS 2-Spoke Steering Wheel
SFAS Standard Duty Shock Absorbers
SGAS Rear Shock Absorbers
SUA Tilt Steering Column
TAAC All Tires
TBB Full Size Spare Tire
TBMS Tire Carrier Winch
TMW P215/75R15 OWL All Terrain Tires
WJM 15X7.0 Chrome Wheels
XBSS Pickup Box
XEEP Fuel Tank Skid Plate Shield
XEFP Transfer Case Skid Plate Shield
XEUP Front Suspension Skid Plate
XFAS -35F Protection Anti-Freeze
YACS Build To Canada Mkt. Specifications
Z01P Rear Spring Group I
Z66P Left Front Group XV
Z85P Right Front Spring Group XIV
Thanks for driving Jeep.
Sincerely,
Sarah
Customer Service Representative
Chrysler Customer Assistance Center
I'm thinking my starter is pooched,
boosted my truck today, since the previous owner hacked apart the tumbler the starter got pinned wide open with the truck,
burning hot, now have a short, glad i have recently rebuilt one i can throw in and test my theory,
will post with results once everything is cool enuff to see whats going on
time to let some sparks fly,
:yes:
i swear i didnt make this hole :dunno: :rotfl2:
well... maybe i did XD
left
right
and thats when i met my new neighbour,
turns out he is a welder and a pro at autobody XD
once I'm finished doing all of this,
going to drive it to his side of the driveway (we have a joint driveway, which now doesnt bother me) and tack er all up :jump:
