87Chief Posted October 24, 2010 Posted October 24, 2010 Is it possible to do this? I have the 2.5l 4 cyl chief and grandpa made it run amsoil. It looks like it has an amsoil air filter box and all that... How do I convert it back to normal? It does burn oil, so how could I fix that?
Eagle Posted October 24, 2010 Posted October 24, 2010 Amsoil is just a brand of synthetic oil. If you want to "convert" back ... just do an oil change. Just be aware that it it burns synthetic, it's probably going to burn conventional oil worse.
87Chief Posted October 25, 2010 Author Posted October 25, 2010 But on my engine, the intake box has amsoil on it, and then from there there is a mechanism that I have no idea what it is... Also, What would be the cause of oil coming into the air filter from the top?
Eagle Posted October 25, 2010 Posted October 25, 2010 Also,What would be the cause of oil coming into the air filter from the top? Blowby. You can probably find multiple discussions of fixes using the search. Step one is to check your compression. If you have bad rings and are getting a lot of blowby, you can't fix it short of rebuilding the engine. If the rings aren't too bad, replacing the CCV tubing may alleviate most of it.
87Chief Posted October 25, 2010 Author Posted October 25, 2010 I was afraid of that. I will get pics up tomorrow night after work.
mvusse Posted October 25, 2010 Posted October 25, 2010 Our engines are known for that, and most of us just live with it. Some people have made an oil catcher between the valve cover breather and air cleaner. I just replace the air filter twice a year. At $1.22 they are cheap from the junk yard. Then again, last time there someone had already snagged all of them...
87Chief Posted October 25, 2010 Author Posted October 25, 2010 Good idea. Will air filters from an xj work too? Most junkyards here never have Comanches. I always call and they say it's been forever since someone asked about one of those. All these damn mj owners... What are we going to do? Lol :)
87Chief Posted October 25, 2010 Author Posted October 25, 2010 Took some pics.. Showing the side of the engine... all gunk.
Geonovast Posted October 25, 2010 Posted October 25, 2010 NEW air filters are like 5-6 bucks at Wal Mart.
mvusse Posted October 25, 2010 Posted October 25, 2010 $8, but I would trust a used filter from the junk yard before I trust anything made by Fram. And that's the only brand Walmart sells here.
Eagle Posted October 25, 2010 Posted October 25, 2010 Is it possible to do this? I have the 2.5l 4 cyl chief and grandpa made it run amsoil. It looks like it has an amsoil air filter box and all that... How do I convert it back to normal? It does burn oil, so how could I fix that? That's a stock Jeep air box, with an Amsoil sticker on it. Nothing to convert. I guess I misread your post in my first response. I thought you wanted to go back from Amsoil oil to conventional. Now I gather you were referring to the air filter. Just go to pep Boys or Advance Auto and buy a Purolator. The filter element in your air box is a stock filter element. It also doesn't look bad at all.
whowey Posted October 25, 2010 Posted October 25, 2010 That is NOT an Amsoil air filter... That looks like cheap @$$ Fram.... The old Amsoil drop-ins had an orange ring like that, but the filter material is a blue color. The new drop in ones are black with blue filter material.
87Chief Posted October 25, 2010 Author Posted October 25, 2010 Would a new PVC stop oil from going in?
Matt1971 Posted October 25, 2010 Posted October 25, 2010 Your CCV fresh air hose has been rigged, the hard plastic probably broke and they fit rubber tubing to replace it. No biggie should work well. How old is the filter? You shouldn't get a lot of oil in it unless your getting a lot of blowby. Check the hard plastic line in the rear of crankcase cover, someone on here suggested cleaning it with weed eater sting, it worked well for me got the gunk out. Also looks like your crankcase gasket is leaky, could be where you are losing some oil. Fix that and you can get rid of some of the burnt oil smell from it leaking onto the engine block. But like they have already said, it's an mj and an older engine, you just gotta live with little oil.
87Chief Posted October 26, 2010 Author Posted October 26, 2010 Ok, so for the to-do list... 1. New Air Filter 2. New valve cover gasket 3. New PVC/CCV 4. Clean hose on the cover closest to the cab 5. Clean gunk off engine (how should I do that?) Anything else? Thanks in advance for the help!
whowey Posted October 26, 2010 Posted October 26, 2010 How long has it been sitting.. or how many miles since the last oil change??? The Amsoil oil filters have been black for at least three years... yours is white.
87Chief Posted October 26, 2010 Author Posted October 26, 2010 Yeah it's been awhile... lol I have no clue, Since 4th of July I know it hasn't had anything done to it. And before that for about 4 months been sitting in storage..
btm24 Posted October 26, 2010 Posted October 26, 2010 I had an air filter just like that when i changed mine :rotfl2: it was all sort of gummed up tho. Brandon
87Chief Posted October 26, 2010 Author Posted October 26, 2010 How did you fix it? Was there oil coming from the air filter hose?
btm24 Posted October 26, 2010 Posted October 26, 2010 Well thats a very long story on my truck and how i fixed yhings like the air filter. You see the last owners before me never did any thing to this truck ie fix any thing. I mean that, when i got it the guy said the rear main seal was shot ( it was not) and it had been that way for 5+ years just put a new qurt or oil in her every mounth. So how the air filter got gummed up :dunno: what i do know is that whn i got the truck oil was every where under the hood even tho the guy cleaned the hell out of it b4 i could come and see it. And there was oil on the air box. All i know is that i replaced it twice now( once when i 1st got the truck and the 2nd time when i sunk it :ack: ) amd ever since then i yave not had much of an oil leak or air filter getting gummed up. Its 22 years old what do you want from it? Is what my dad allways tells me. I'm sorry that came out a lot longer then i wanted to come out i got very long wended, hope that i was a help. Brandon
87Chief Posted October 26, 2010 Author Posted October 26, 2010 It did, thanks. I need to do an oil change on it and all that good stuff soon before I get the title for it, I plan on doing some engine stuff like valve cover gasket and air filter oil change and then going to the car wash and using some gunk remover stuff (not sure of name) on the engine and hopefully getting the old oil gone... I have this picture... This maybe dumb, but what is it? Carburetor?
87Chief Posted October 26, 2010 Author Posted October 26, 2010 Is there supposed to be oil in there? lol
87Chief Posted October 26, 2010 Author Posted October 26, 2010 I think oil is coming from the CCV and making it's way back up towards the throttle body...
