Craft86MJ Posted September 23, 2010 Share Posted September 23, 2010 What is the Ideal/best manual transmission to have in a Comanche? Link to comment Share on other sites More sharing options...
freakjeep93 Posted September 23, 2010 Share Posted September 23, 2010 AX 15 is best Link to comment Share on other sites More sharing options...
Craft86MJ Posted September 23, 2010 Author Share Posted September 23, 2010 in what years did they put these in? Link to comment Share on other sites More sharing options...
freakjeep93 Posted September 23, 2010 Share Posted September 23, 2010 i think it wa 90-92 4.0L comanches. and some 2.5L dakotas had them to Link to comment Share on other sites More sharing options...
Craft86MJ Posted September 23, 2010 Author Share Posted September 23, 2010 how easy would it be to put up to a 3.4L in a 1986 MJ? Link to comment Share on other sites More sharing options...
freakjeep93 Posted September 23, 2010 Share Posted September 23, 2010 uhm that i don't know . again i think that the 3.4 uses the same bellhousing as the 2.5 so if you got the dakota 2.5 AX15 it might work. but id consult the experts first Link to comment Share on other sites More sharing options...
Craft86MJ Posted September 23, 2010 Author Share Posted September 23, 2010 will do thanks Link to comment Share on other sites More sharing options...
Geonovast Posted September 23, 2010 Share Posted September 23, 2010 AX-15 was used in mid 89 - 92 MJ, mid 89-95 YJ, 97-99 TJ, and mid 89-99 XJ. Link to comment Share on other sites More sharing options...
Automan2164 Posted September 23, 2010 Share Posted September 23, 2010 3.4 swap will bolt directly in place of the 2.8, and will use or can use, all of its accessories. AX15 is the best, but will not bolt up to the 2.5L/2.8L engines. You can, however, find an older Dodge dakota that used the AX15 behind the 4 cylinder, and that has the correct bellhousing for the 2.5L/ GM 2.8L (60 degree V6 family). Rob L. Link to comment Share on other sites More sharing options...
Eagle Posted September 23, 2010 Share Posted September 23, 2010 AX 15 is best I beg to differ - NV 3550 is best. However, it won't be found in any MJs as donors, VERY few Cherokees had it (2000 and 201 only), so it would have to come from a 2000 or newer Wrangler. Link to comment Share on other sites More sharing options...
Craft86MJ Posted September 23, 2010 Author Share Posted September 23, 2010 will the early AX 15 out of the Dakota bolt up directly or would i have to do a lot of fabrication? Link to comment Share on other sites More sharing options...
Automan2164 Posted September 23, 2010 Share Posted September 23, 2010 will the early AX 15 out of the Dakota bolt up directly or would i have to do a lot of fabrication? Direct, but be warned, that is a rare bird. Rob L. Link to comment Share on other sites More sharing options...
Craft86MJ Posted September 23, 2010 Author Share Posted September 23, 2010 will it work well with 4x4 or not at all? Link to comment Share on other sites More sharing options...
wannabeMJ Posted September 23, 2010 Share Posted September 23, 2010 if it comes from a 4x4 truck it will fit but if from a 2x4 no the output shaft is not the same unless its going in a 2wd Link to comment Share on other sites More sharing options...
Pete M Posted September 24, 2010 Share Posted September 24, 2010 nothing wrong with the ol' AX-5 that your truck would have come with. plenty of them out there. :thumbsup: Link to comment Share on other sites More sharing options...
Incommando Posted September 24, 2010 Share Posted September 24, 2010 nsg370 FTW!!!!! :D Link to comment Share on other sites More sharing options...
Geonovast Posted September 24, 2010 Share Posted September 24, 2010 nsg370 FTW!!!!! :D Except the gearing sucks. Link to comment Share on other sites More sharing options...
carnuck Posted September 24, 2010 Share Posted September 24, 2010 How about T18A with NP208? (I have one for sale with a running AMC 360 for $500 obo in Seattle) I'm taking it out of my '82 Honcho because I don't plan to haul any loads with it so it's getting a 290 with AX-15 (already have them) since it'll be a freeway cruiser. It'll have an NP208 for now (the adapter is @$100 from Partsmike.com ) Later it will get an NV241 OR with 4:1 low range :brows: Link to comment Share on other sites More sharing options...
