thousender Posted October 26, 2022 Share Posted October 26, 2022 I just got myself a set of euramtecs. I love the fit and feel, but have an issue with the switch. Up= on Middle= on/off with door Down= on Correct me if I'm wrong, but its supposed to be this way: Up= on/off with door Middle= off completely Down= on completely Has anybody had this issue, any help would be much appreciated! Link to comment Share on other sites More sharing options...
howeitsdone Posted October 26, 2022 Share Posted October 26, 2022 Sounds like a wiring and/or ground issue. I'd probably post in the help section to get more eyes Link to comment Share on other sites More sharing options...
Ωhm Posted October 26, 2022 Share Posted October 26, 2022 A-7180-BC Link to comment Share on other sites More sharing options...
MattK Posted December 8, 2025 Share Posted December 8, 2025 I purchased the euramtec lights for my MJ. For some reason when I have them in the position to automatically come on when opening the door, they pop the fuse. I just manually turn them on now. Did I install incorrectly? Why won’t they work with all 3 connections hooked up? Link to comment Share on other sites More sharing options...
Ωhm Posted December 8, 2025 Share Posted December 8, 2025 Disconnect one side and check the other side. Do same for other side. Determine if one of the lights could be faulty. Link to comment Share on other sites More sharing options...
MattK Posted December 8, 2025 Share Posted December 8, 2025 Do you mean the bulb or the whole light could be faulty? Link to comment Share on other sites More sharing options...
Ωhm Posted December 8, 2025 Share Posted December 8, 2025 Disconnect all three wires from one side or the other. Determine if that still blow fuse. If not, reconnect that side and disconnect other side and do the same test on the other side. Checking for faulty fixture. Verify wiring while it all apart. Link to comment Share on other sites More sharing options...
Gjeep Posted January 8 Share Posted January 8 What year is your MJ? I modified those B-pillar lights for my HO era MJ's to come on with rest of the interior lights with doors/ headlight rotate left switch on. The B-pillar light itself is always at on-center and cannot be switched on independently like factory units (as I did not want it to). Link to comment Share on other sites More sharing options...
