I dunno how many of you fellow CCrs shop at OReillys, but if youre used to buying our house microguard filters, STOP... They are no longer Purolators, they are now Fram... Great cost cutting measures :fs1:
Ugh, I got a purolator. What's the deal? What's it gonna do to my truck? I'm noticing some higher oil pressures...
You misunderstood me, the old microguard filters were purolators, and they were decent, the new microguards are now manufactured by fram
Purolator = Good
Fram = Bad
Sorry about the confusion. I have the NEW FRAM made filter. What's the problem with these? Bear in mind I have a Chevy 2.8 V6, though.
Purolator = Good
Fram = Bad
the filter element is junk, it doesn't filter.
the backflow preventer (check valve) is junk...it doesn't work. the point of the check valve is to keep oil in the top end between startups. so, since this doesn't work, rather than having an un-lubricated startup on only cold starts, you have un-lubricated startups on EVERY start.
end result, bad lifters, bad cam, bad valves.
Only Fram filters every 3000 miles for 260,000 miles from 1994 to 2010 and when sold it the 4.0 had no lifter noise, main or rod noise on start up after oil change nor on startup even after sitting for a few days, etc. I never had a problem with Fram filters.
I invite you to cut one down, and compare the internals to a wix... Youll never buy a fram again, they are just cheap crap
I never liked the looks of those Microguard filters in the first place. They looked cheap. Sixth sense I reckon.
I have read those sites before, and agree others are better, but how can 260,000 miles and none of the problems mentioned here (bad lifers, cams, etc) showing up mean all the Frams I used were terrible for my engine? :dunno:
Well any filter is better than no filter, I think neglect is a large contributor to these issues, and religious maintenance can help, but if were just talking filters, the fram works but its junk
I have been using the purolators since around 99, but I was told recently(by a mechanic buddy who cuts them open once in a while) that they changed their design and are now worse than frams, so I switched to oem from my local jeep dealer. They are the same price and seam a little better quality.
Last time I put a Fram on the MJ after i got it, everytime I would come to a stop my oil light would come on. Pulled it off after asking here and put on a NAPA Gold (made by WIX) and the problem was solved.
Yeah fram filters are notorious for low oil pressure. At hot idle on my XJ, the oil pressure would dip down below 10psi with a fram. When I switched to Wix, the psi would be steady at 20 psi.
Also, if you have a 4.0HO engine, you can run a bigger filter. It spins right on without any problems. The Wix part number is 51515, or just look for the same oil filter as a 5.0 mustang. A bigger filter means cleaner oil. :banana:
Thanks for the info. Over the past few years I have studied my favorite oils, lubes, and filters carefully. The number of changes in the same product is almost scary.
On a side note, I run the V8 F150 mobile1 filter.
What O Reillys do you work at? They are scares here. All I ever seem to find are Advance.
Mine is an Overland Park store, its on the SW corner of 75th and Metcalf, if you drive by and see a red run-down MJ, thatd be mine :thumbsup:
