88pioneer Posted April 5, 2010 Share Posted April 5, 2010 Doing my hubs today, and i noticed there is a cotter pin on the end of nut. My question is do the new hubs come with a replacement pin, or do i have to buy it seperate Link to comment Share on other sites More sharing options...
Puritan21 Posted April 5, 2010 Share Posted April 5, 2010 I had to get the cotter pin seperate. My new hubs were from Oreilly's. Link to comment Share on other sites More sharing options...
kro10000 Posted April 5, 2010 Share Posted April 5, 2010 :agree: Dunno about most stores, but at my oreillys if you ask for a cotter pin, theyll usually give it to you... Or charge 15 cents or whatever Link to comment Share on other sites More sharing options...
88pioneer Posted April 5, 2010 Author Share Posted April 5, 2010 alright perfect, thanks for the help :cheers: Link to comment Share on other sites More sharing options...
one_bad_MJ Posted April 5, 2010 Share Posted April 5, 2010 if it comes right out you can reuse it Link to comment Share on other sites More sharing options...
mvusse Posted April 5, 2010 Share Posted April 5, 2010 Any hardware store should sell cotter pins in any size you can imagine. Link to comment Share on other sites More sharing options...
Wildman Posted April 6, 2010 Share Posted April 6, 2010 if it comes right out you can reuse it Cotter pins are a "once" use item, and should never be re-used :no: {Learned that back in auto shop in '72 :D } Link to comment Share on other sites More sharing options...
Eagle Posted April 6, 2010 Share Posted April 6, 2010 if it comes right out you can reuse it Cotter pins are a "once" use item, and should never be re-used :no: Correct. One or both legs gets bent over 180 degrees to lock it in place. By the time you bend it, straighten it out for removal, then bend it again -- it's pretty well work hardened and on the ragged edge of failing. I confess to having reused them in an emergency, but it really is a "NO-NO!" And no hubs come with cotter pins. The cotter pin is not part of the hub assembly, it's part of the stub axle assembly. Cotter pins are a "consumable" item in automotive repair shops. Tie rod ends sometimes come with replacements, but I can't remember anything else that does. If you don't have an assortment of cotter pins next to your toolbox, you're not a real Jeeper. Link to comment Share on other sites More sharing options...
the_wizard_of_fire Posted April 6, 2010 Share Posted April 6, 2010 if it comes right out you can reuse it Cotter pins are a "once" use item, and should never be re-used :no: Correct. One or both legs gets bent over 180 degrees to lock it in place. By the time you bend it, straighten it out for removal, then bend it again -- it's pretty well work hardened and on the ragged edge of failing. I confess to having reused them in an emergency, but it really is a "NO-NO!" And no hubs come with cotter pins. The cotter pin is not part of the hub assembly, it's part of the stub axle assembly. Cotter pins are a "consumable" item in automotive repair shops. Tie rod ends sometimes come with replacements, but I can't remember anything else that does. If you don't have an assortment of cotter pins next to your toolbox, you're not a real Jeeper. i reuse cotter pins all the time, and actually have never had one break....(though i do realize its just a matter of time.... Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted April 6, 2010 Share Posted April 6, 2010 if it comes right out you can reuse it Cotter pins are a "once" use item, and should never be re-used :no: Correct. One or both legs gets bent over 180 degrees to lock it in place. By the time you bend it, straighten it out for removal, then bend it again -- it's pretty well work hardened and on the ragged edge of failing. I confess to having reused them in an emergency, but it really is a "NO-NO!" And no hubs come with cotter pins. The cotter pin is not part of the hub assembly, it's part of the stub axle assembly. Cotter pins are a "consumable" item in automotive repair shops. Tie rod ends sometimes come with replacements, but I can't remember anything else that does. If you don't have an assortment of cotter pins next to your toolbox, you're not a real Jeeper. i reuse cotter pins all the time, and actually have never had one break....(though i do realize its just a matter of time.... That is your choice and so far you have been lucky. Cotter pins are WAY CHEAP. They are there to keep a critical nut from loosening. Why on earth would you want to take a chance of a catastrophic failure because you where too lazy to change a 20cent cotter pin??? Do what you like, but NOT changing to a new pin every time of foolishness.. CW Link to comment Share on other sites More sharing options...
64 Cheyenne Posted April 6, 2010 Share Posted April 6, 2010 Imagine reusing a cotter pin in the aircraft industry................ Link to comment Share on other sites More sharing options...
