eunique Posted April 2, 2010 Share Posted April 2, 2010 Hello all! I have been reading in these forums for a number of months now and have gotten a lot of great info and tips! Thank you to all. It's been a number of months now that I've had my 1988 Comanche..off white/cream color (i think it's officially butterscotch?) color standard bed, 4WD, 4.0L 5 speed transmission here is what I have done so far.... tune up *new plugs, wires, cap/rotor cleaned up/replaced some vacuum lines new injectors updated to open system cooling new radiator, hoses, new thermostat, new water pump upgraded to 4ga power and ground wires upgraded to high output alternator removed standard fan...put in electric from newer Cherokee...no controller yet...using direct jumper wire for now :ack: until I figure out what best to use for auto thermo switch HID lights updated to newer style valve cover (no more oil in the air cleaner!!!) painted grille newly painted bumpers washer bottle update into fender area got double booster/brake master (not installed yet) I think the arms are not the same with the factory... :wall: what route should I go into making this work? more recently: new front rotors and Performance Friction pads (used these in numerous vehicles and am very happy with them) acquired used 15" rims... had them refinished outside of the US... gold mesh with polished lips now, hopefully get my bigger tires tomorrow...possibly 31"s question: i don't want to lift the MJ too much... i was thinking 2" max...how should i go by doing this if i am trying to stay in a budget? most of my parts upgrades I got from junkyard...except for the new necessities...otherwise other parts are used. can anyone help? i will post pics as soon as i can...if I am able to already. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted April 2, 2010 Share Posted April 2, 2010 A cheap lift....coil spacers for the front, add a leaf spring in the rear...sheesh, yor post looks like u got alot done so far, waiting for pics..oh yeah, welcome Link to comment Share on other sites More sharing options...
eunique Posted April 4, 2010 Author Share Posted April 4, 2010 A cheap lift....coil spacers for the front, add a leaf spring in the rear...sheesh, yor post looks like u got alot done so far, waiting for pics..oh yeah, welcome Thanks! That is exactly what I was thinking...i saw local Autozone carry the Energy suspension coil spacers..which are 1 3/4" lift for fronts... do you think those are good? what abt the add a leaf? where do i get them? what kind is good? i want to say that the kit comes for front and rear for the Comanche at Autozone for the energy suspensions... but does not give the detail or anything about leaf springs... i don't think they are add a leafs.. Link to comment Share on other sites More sharing options...
Dirteatr717 Posted April 4, 2010 Share Posted April 4, 2010 Welcome to the club! if you want 2'' of lift get 2inch coil spacers and either a Add-a-leaf or shackles. Link to comment Share on other sites More sharing options...
eunique Posted April 5, 2010 Author Share Posted April 5, 2010 Welcome to the club! if you want 2'' of lift get 2inch coil spacers and either a Add-a-leaf or shackles. Thank you for the advice. Any particular manufacturers/suggestions? And where should I be looking to buy them for a good price? :hmm: Link to comment Share on other sites More sharing options...
Darren Posted April 5, 2010 Share Posted April 5, 2010 You can get V8 ZJ coils to lift the front ~2" and bastard pack for the rear. I'm not a fan of spacers. Link to comment Share on other sites More sharing options...
88pioneer Posted April 5, 2010 Share Posted April 5, 2010 :agree: i would like springs over spacers myself, but to each his own. An i would run an add a leaf in the rear Link to comment Share on other sites More sharing options...
eunique Posted April 6, 2010 Author Share Posted April 6, 2010 :agree: i would like springs over spacers myself, but to each his own. An i would run an add a leaf in the rear just to confirm...you prefer the V8 springs? instead of stock springs plus spacers? I looked into Hell Creek for the add-a-leaf...and they are very reasonable. I'll probably order those soon. hope I get the tires tomorrow so I can get them mounted. check out my other posts/pics "My 1988" in Your project MJs I see that you are in the fire service in NJ. I am a firefighter in San jose..and I got this Comanche from our "Commander." He has been in the department the longest and they will probably force him to retire later this year because he is turning 70 yrs. old. And he is still on the line in one of the busiest Engines in the department. I am building the MJ as a sort of a commemoration for him. He is a great leader and good friend. Link to comment Share on other sites More sharing options...
eunique Posted April 6, 2010 Author Share Posted April 6, 2010 :agree: i would like springs over spacers myself, but to each his own. An i would run an add a leaf in the rear here's some other pics my new radio with Bluetooth new seat and shift boot upholstery Link to comment Share on other sites More sharing options...
-600JeepMJ Posted April 6, 2010 Share Posted April 6, 2010 :cheers: welcome to the MJ maddnes. Link to comment Share on other sites More sharing options...
johnnyc Posted April 6, 2010 Share Posted April 6, 2010 I did a two inch budget boost on my MJ when I first got it. The V8 ZJ coils only netted me half an inch. So I added a 1.5 inch spacer. In the back, I added the main leafs from an XJ for two inches.Then I added 245/75/16 tires (just under 31") on Moab wheels. These parts worked great for a few months, until I went SOA. I don't see a problem running coil spring spacers on a street vehicle. Hell, now I have 3.5 inch coil springs with ACOS set at about 2.5 inches. And the ACOS is just an adjustable spacer. Link to comment Share on other sites More sharing options...
eunique Posted April 7, 2010 Author Share Posted April 7, 2010 I did a two inch budget boost on my MJ when I first got it. The V8 ZJ coils only netted me half an inch. So I added a 1.5 inch spacer. In the back, I added the main leafs from an XJ for two inches.Then I added 245/75/16 tires (just under 31") on Moab wheels. These parts worked great for a few months, until I went SOA. I don't see a problem running coil spring spacers on a street vehicle. Hell, now I have 3.5 inch coil springs with ACOS set at about 2.5 inches. And the ACOS is just an adjustable spacer. Great! thanks for the info. I think the minimal for me would be fine. I don't plan on going hard core on this. And it's kind of a budget build. so, I might end up with coil spacers and add-a-leafs. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 13, 2010 Share Posted April 13, 2010 :agree: i would like springs over spacers myself, but to each his own. An i would run an add a leaf in the rear here's some other pics my new radio with Bluetooth new seat and shift boot upholstery Your shifter looks like an uncircumcised....uh...... you know! Just looks wierd! But to each his own.... Keep up the good work! Link to comment Share on other sites More sharing options...
bermsurfer230 Posted July 1, 2010 Share Posted July 1, 2010 Welcome to the club! As you've seen, manner folks on here are knowledgeable and ready to help you with whatever you ask. Seems like somebody has an answer, or where to look for one :thumbsup: And it's cool to see another fellow FF! I'm a volunteer in WA, and i noticed your seat cover. That's pretty sick! Where/how did you get that made? Would be cool to get/make something similar for my seat rebuilds i need to do... Keep us posted on any updates about you or the MJ! Link to comment Share on other sites More sharing options...
