offroader461 Posted September 25, 2006 Posted September 25, 2006 does anyone know of a company or have done it themselves to eliminate the c.a.d. setup on the front axle so i don't have to swap in a new one? if you do can i get that site or if you have done it can i get a parts list of what i will need to do it correctly thx again....
Pete M Posted September 25, 2006 Posted September 25, 2006 Take the cover off, slide the collar over, install cover upside down. I heard about that a while ago and someday I might get a chance to try that on my own axle. :D
DirtyComanche Posted September 25, 2006 Posted September 25, 2006 Can put in a non-cad axle shaft, and a new seal.
mjeff87 Posted September 25, 2006 Posted September 25, 2006 Take the cover off, slide the collar over, install cover upside down. I heard about that a while ago and someday I might get a chance to try that on my own axle. :D Just did that on Chuck's YJ yesterday. Minor problem was that the disco motor is in great shape, and it kept pulling the shift fork back juuuust enough to disengage the collar. Pulled it all apart and shimmed it with some washers (like I have mine) and it works like a charm :D Don't forge to refill the CAD housing with gear oil when you put it back together. Jeff
jage Posted September 25, 2006 Posted September 25, 2006 Just pull the cover and slide the fork over and put a hose clamp on the shaft. Works like a charm. Of course I disco'd the hoses and plugged them with screws and blue RTV because they didn't reach well anyway. I think I capped the axle ones with little random rubber caps. Or you can buy my used posilock... :D
husky410ohio Posted September 25, 2006 Posted September 25, 2006 4x4 posi-lok sells a Perm-Lok to permanently engage the central axle but it cost $94.29 http://www.4x4posi-lok.com/app_jeep.html My Jeep page: http://hometown.aol.com/husky410ohio/my ... /auto.html
87manche Posted September 25, 2006 Posted September 25, 2006 http://home.earthlink.net/~stevenschreiber/cabledis.htm have fun :)
