I'm wondering if anyone would know why my cigarette lighter isn't working. I have checked all of the fuses and they all appear to be fine. I just want to be able to charge my iphone in there. An Ideas?
Thanks in advance!
they never worked in any of my trucks. usually the problem stemmed from corrosion inside or behind the lighter itself. I bought heavy duty aftermarket versions from the auto parts store. :thumbsup:
  • 1 year later...
any luck with your lighter? i just found out mine won't charge my gps and replaced it. still no luck. it lights up though//
It may also be the fuse. That fuse also controls the reverse lights. Mine pops all the time I have a short some where just need to find it.
Brandon
Before you go ripping anything apart check the iPhone charger wire in another car... Mine stopped working for some reason and I tried my friends in my outlet, it worked fine! Just a heads up :cheers:
