89Tonto Posted September 17, 2006 Share Posted September 17, 2006 Drivers door won't unlatch- can't unlock. PITA to crawl over seat. :mad: 1. Tried different keys- 2. Sprayed oil in lock- 3. Played with both inside and outside latches. Only to get door open to pull panel...someday. Any suggestions just short of tearing the door off of hinges? :headpop: Link to comment Share on other sites More sharing options...
aemsee Posted September 17, 2006 Share Posted September 17, 2006 Just sounds like it is frozen in the locked position. Pulling door panel and trying to get it to unlock would be your best bet. Not an easy thing to do for sure. You may end up damaging the panel. Link to comment Share on other sites More sharing options...
Pete M Posted September 17, 2006 Share Posted September 17, 2006 I had that happen to me once on the passenger side. Ended up pulling off the door panel to get at the stuff inside. If I had to do it again, I'd remove the seats and center console first (I have buckets). Maybe you could spray some WD-40 (through the straw) down past the window to the lock mechanism? Or maybe that would just make a huge mess... :hmm: Link to comment Share on other sites More sharing options...
89Tonto Posted September 17, 2006 Author Share Posted September 17, 2006 What are my chances of pulling the door panel off with the door closed? It appears it's "do-able" if I pull the bench seat out. I'll try the WD 40 trick first. Wish me luck. :roll: Link to comment Share on other sites More sharing options...
DirtyComanche Posted September 17, 2006 Share Posted September 17, 2006 I doubt it'd be easy... But, if you take an old wide slotted screw driver and warm it up and bend the tip over 90* you might be able to pop all of the little clips without wrecking the panel. If it gets wrecked, go see a wrecker. Link to comment Share on other sites More sharing options...
Pete M Posted September 17, 2006 Share Posted September 17, 2006 Have you ever pulled the panel off with the door open? Doing that with the door closed is hard, but possible. Having a bench makes it a lot easier (in that there are fewer bolts to undo and empty the interior). Link to comment Share on other sites More sharing options...
GirsMJ86 Posted September 17, 2006 Share Posted September 17, 2006 that happened to me on my old 88. the plastic caps on the rod that connects the handles to the mechanics of the door fell out of their holes. i threaded the ends of the rod, put the plastic caps back on and put lock nuts on the ends of the rod. seemed to work just fine. but you have to be able to get the door panel off to do it. Alex Link to comment Share on other sites More sharing options...
Wanderin Posted September 18, 2006 Share Posted September 18, 2006 Had that happen on Old Rusty, i pulled the lower of the panel away from door and used a screwdriver IIRC to get it unlocked and open. Then took it all apart and got the gunk cleaned outta there and she works like a charm now :D Link to comment Share on other sites More sharing options...
89Tonto Posted October 23, 2006 Author Share Posted October 23, 2006 Have you ever pulled the panel off with the door open? Doing that with the door closed is hard, but possible. Having a bench makes it a lot easier (in that there are fewer bolts to undo and empty the interior). Thanks guys for all of the suggestions. The MJ came home for a short-overnight stay Sunday morning. After removing bench seat and panel, finally got the door opened. ;) Found a broken spring assemblies in bottom of door cavity. :cry: The door opens and closes ok. If the door get's locked, it stays locked until I can play with the correct latches. Therefore, I left the panel off for now. Hope to finish up around Thanksgiving. Anyone have a door latching assembly (drivers side) they can part with from a junk door? Link to comment Share on other sites More sharing options...
87manche Posted October 23, 2006 Share Posted October 23, 2006 I need to get back wth a guy about some doors. If I get them you can have the latches. I'm interested in glass and rubber pieces mostly. Oh, and doors to cut up for the trail :) Link to comment Share on other sites More sharing options...
89Tonto Posted November 14, 2006 Author Share Posted November 14, 2006 I need to get back wth a guy about some doors. If I get them you can have the latches. I'm interested in glass and rubber pieces mostly. Oh, and doors to cut up for the trail :) Hey there 87manche, Did you come across the latches? Truck is coming home for 3-4 days and would like to attempt to fix. Let me know- feel free to PM. Thanks!!! :cheers: Link to comment Share on other sites More sharing options...
GirsMJ86 Posted November 15, 2006 Share Posted November 15, 2006 i might have a set of spare latches. i will look for you in the morning. Alex Link to comment Share on other sites More sharing options...
mike Posted November 15, 2006 Share Posted November 15, 2006 i have a set on my doner mj, no locks but everything else is there. make me an offer. i'm in indiana also so if you want anything else maybe you can take a drive over here and load up on parts :D . Link to comment Share on other sites More sharing options...
89Tonto Posted November 15, 2006 Author Share Posted November 15, 2006 i have a set on my doner mj, no locks but everything else is there. make me an offer. i'm in indiana also so if you want anything else maybe you can take a drive over here and load up on parts :D . Ummm.... interesting-. Did you say PARTS? :bowdown: You are in West central Indiana? Where? I'm over next to Ohio in Richmond. Might be a roadtrip in the near future???? :cheers: Link to comment Share on other sites More sharing options...
mike Posted November 16, 2006 Share Posted November 16, 2006 i'm about 30 miles or so from the state line, and about 10 miles northeast of rockville. right on st. rd. 47 by the montgomery-parke county line. there's a golf course right across the road, very easy to find. as far as parts, i have an 86 2wd, 2.5L, auto, that i'm parting out and still have about %80 of it left. everything is up for offers. let me know what you need and i'll see if i have it. Link to comment Share on other sites More sharing options...
89Tonto Posted November 24, 2006 Author Share Posted November 24, 2006 Found a broken spring assemblies in bottom of door cavity. :cry: FYI- This is what was broken. Hope this is what I need to fix. :roll: Link to comment Share on other sites More sharing options...
89Tonto Posted November 24, 2006 Author Share Posted November 24, 2006 i have a set on my doner mj, no locks but everything else is there. make me an offer. i'm in indiana also so if you want anything else maybe you can take a drive over here and load up on parts :D . I'm going to the Badlands next weekend. How far are you from there? Link to comment Share on other sites More sharing options...
mike Posted November 25, 2006 Share Posted November 25, 2006 we're about 40-45 miles south of the badlands, just take 41 south out of attica and go to 47 then go east about 7 miles and we're right across from a golf course. saturday would be the best. Link to comment Share on other sites More sharing options...
