pug Posted December 8, 2009 Posted December 8, 2009 I have one of the old long arm kits the 3 link. The flex is awsome. Over the last couple of months i have noticed the front end wants to nose dive on the passenger side I was wondering if i could put upper control arms back on in the factory location. Would this help keep the front from nose dive.
87Warrior Posted December 8, 2009 Posted December 8, 2009 Don't do that :doh: Caster and pinion angle nightmare. Image Not Found *Image for TJ rear, but you can mentally flip it for the front! Not sure what you mean by nose dive?
freakjeep93 Posted December 8, 2009 Posted December 8, 2009 mabye your spring is sagging on one side :hmm:
pug Posted December 8, 2009 Author Posted December 8, 2009 I have the two lower long arms. Then for the third arm back then they called it a tourqe arm. It goes from middle of drivers side long arm to the coil spring base to bracket that is welded on. Sorry i do not pictures
redneck23ms Posted December 8, 2009 Posted December 8, 2009 if its only diving on one side then you probably have a bad shock on that side.
redneck23ms Posted December 8, 2009 Posted December 8, 2009 i would like to see a pic of the torque arm deal though if you can get one
pug Posted December 8, 2009 Author Posted December 8, 2009 I will try to get some pictures. Shockes are about 3 months old. Also there is nothing bolted to the factory upper control arm mounts on the axel left ar right side
pug Posted December 8, 2009 Author Posted December 8, 2009 No i checked that to everything is tight. I wonder since i do not drive it that much i am used to driving the other with the four link set up.
shelbyluvv Posted December 8, 2009 Posted December 8, 2009 DO NOT PUT ARMS IN THE STOCK UPPERS LOCATION!!!! It will either buckle the arm or rip the mounts off the axle or body. I tried the same thing when I had my RK 3 link. I was worried there was not enough support for daily driving in the event of a failure. I tried it, it failed. If it is diving, you have a weak shock or coil. You have the first Gen kit. If you call and talk sweet to Heather she will normally give you the Gen II upgrade for a discount.
LoTGoD Posted December 8, 2009 Posted December 8, 2009 Latest 3 link from RK: This is the upper driver side link Lower passenger arm, note there is no UCA with this kit. Mount for driver side upper and lower arms Passenger side LCA frame mount
pug Posted December 8, 2009 Author Posted December 8, 2009 Just curious on the teraflex longarm it shows just two longarms and two brackets. Is there anything else that goes with the kit.
pug Posted December 16, 2009 Author Posted December 16, 2009 I was bored today so desided to switch shocks from left side to right side. Drove acouple miles started nose diving on the side i switched shocks. they are doethch shocks. Any opinions what new shocks to buy. thanks
89eliminator Posted December 16, 2009 Posted December 16, 2009 Just curious on the teraflex longarm it shows just two longarms and two brackets. Is there anything else that goes with the kit. thats a horrible design. it uses longer lowers while keeping the short arm uppers.
87Warrior Posted December 16, 2009 Posted December 16, 2009 I have had great luck with the OME shocks on my TJ. 65K miles and still doing their job. Not sure if they offer one in the configuration you will need. I think the Rubicon Express monotubes are a similar design.
