Swanny Posted September 11, 2006 Share Posted September 11, 2006 OK, let's say I'm looking at a used Comanche for sale. I don't have the tools to jack up the back end and rotate one tire to see if it has a limited slip differential. The truck in question is a 89 Eliminator. 4.0L, 5 spd, 2WD. Can I tell from the code on the door jamb or something? Or just dump the clutch and find out the fun way ;) I haven't gone to look at the Jeep yet. It's in another province 550km away and so I can't even get there to see the truck for another 2 weeks (if it's not sold). :Canadaflag: Also, with some weight in the back and some good tires, do the 2WD trucks go anywhere in the winter? My wife has a 2007 Jeep Compass 4WD but I can't drive it too often so I want to make sure I can get around when we get a big snow dump. Link to comment Share on other sites More sharing options...
GirsMJ86 Posted September 11, 2006 Share Posted September 11, 2006 do they get around... well let me see. my 88 eliminator was covered to the windsheild and top of the bed one winter in our driveway. all I had in the bed was a few sandbags. and all i did to get it out that day was rock it a few times, but the tires i had on it were almost too warn out for the road car tires. so with trucks tires i bet it would have just pulled right out. i have never used the 4x4 on my 86 X, even when i was in mud up to my axles one time. so with car tires you would have no problem getting around. Alex Link to comment Share on other sites More sharing options...
Pete M Posted September 12, 2006 Share Posted September 12, 2006 My 2wd 88 was armed with a stick shift and 30" BFGs and I would stay up late or get up early in order to play in the snow covered roads before the plows came by. :D Good tires, a bit of weight (right above or in front of the rear tires and secured) and some skills will go a long way on flat snowy roads. Deepest snow was about 8-10 inches. Oh, and don't put bags of salt in the bed. Link to comment Share on other sites More sharing options...
mjeff87 Posted September 12, 2006 Share Posted September 12, 2006 They can be a pain, but tire chains on a 2WD MJ are the cat's azz I used them on mine until I converted it, and it dug thru almost everything. Only problem I had was when I got a wheel off into a ditch or deep rut (open diff), but got thru it feathering the brake pedal. When you shovel out the driveway/sidewalk, toss the snow in the back of the bed for extra weight over the rear axle. Over the course of time, it hardens into a solid chunk. Jeff Link to comment Share on other sites More sharing options...
bdjr Posted September 12, 2006 Share Posted September 12, 2006 got 31's on the back and some weight in the bed and it goes when and where all these new fancidanci suv's can't. you will have to work to get it stuck :D Link to comment Share on other sites More sharing options...
Oizarod115 Posted September 13, 2006 Share Posted September 13, 2006 i wish we had snow in atl :cry: i get solid ice once a year if I'm lucky Link to comment Share on other sites More sharing options...
beaterjeep Posted September 13, 2006 Share Posted September 13, 2006 You have to work pretty hard to get these things stuck, even with only 2wd, trust me I've been through mud holes and creeks where some of my friends couldn't in their jacked up chevs and fords. Although if it's a manual trans, during winter be careful that you don't accidentally downshift when you want to upshift, the tail end tends to get away from ya. :fool: Link to comment Share on other sites More sharing options...
partsmj Posted September 13, 2006 Share Posted September 13, 2006 Or just dump the clutch and find out the fun way? Yes. Link to comment Share on other sites More sharing options...
87manche Posted September 14, 2006 Share Posted September 14, 2006 short of looking in the diff there's no good way when you're looking to buy. Go and dump the clutch on some gravel. I'd be willing to bet a 2wd MJ will go farther in the snow than a "4"WD compass :) Link to comment Share on other sites More sharing options...
