Jakeman17 Posted October 10, 2009 Posted October 10, 2009 88'' 4.0L 5-speed Manual 2WD I like pictures FYI. The Day I Got It: Sand Bag Box: Exhaust Pipe 31's Image Not Found Image Not Found CB: Image Not Found D30 Before Image Not Found After Image Not Found Image Not Found Soon to come: Tints Sound System Exhaust Tip Roll Bar Light Bar 4WD Conversion(Pending)
Jakeman17 Posted October 11, 2009 Author Posted October 11, 2009 Just puled it out...... still leaks same spot i know i covered that spot well
reson46 Posted October 12, 2009 Posted October 12, 2009 Clean off all of that RTV, quickly. You are going to clog up your cooling system. You don't need anywhere near that much. Now take off the belt before you put the thermostat housing back on. It is very easy for the thermostat to slide down between the housing and the head when you try to install it with the belt on. With the belt off you will be able to get a straight shot with the thermostat housing. Willy
Jakeman17 Posted October 12, 2009 Author Posted October 12, 2009 Clean off all of that RTV, quickly. You are going to clog up your cooling system. You don't need anywhere near that much. Now take off the belt before you put the thermostat housing back on. It is very easy for the thermostat to slide down between the housing and the head when you try to install it with the belt on. With the belt off you will be able to get a straight shot with the thermostat housing. Willy I am sure it is in the grooves. The rtv was not all squshed out. Alot of it was added on outside. I have pictures from next attempt last weekend
offroader461 Posted October 12, 2009 Posted October 12, 2009 get some of the RTV copper...put a light coat on the head and thermo housing..put it on and let it sit 24 hrs and it will seal up just fine
Jakeman17 Posted October 12, 2009 Author Posted October 12, 2009 After Driving to school and back today NO LEAKS but no coolant in the reservoir bottle. but i left the cap untightened I make a wood box for sand bags also
500 MJ Posted October 13, 2009 Posted October 13, 2009 They make gaskets for the thermostat housings, they usually come with the new thermostats...
Jakeman17 Posted October 13, 2009 Author Posted October 13, 2009 They make gaskets for the thermostat housings, they usually come with the new thermostats... There is one under there
Jakeman17 Posted October 15, 2009 Author Posted October 15, 2009 I went and got my oil changed today and here is what I found out: I need a crankshaft pulley mine is rubbing on case water pump heater control valve flexable rear brake hose also found out I have a Vacuum leak My fuel filter is on wrong Ball joints are good Nothing really broken or hanging The guy said he would buy it off me for 2K.
Jakeman17 Posted October 18, 2009 Author Posted October 18, 2009 I am going to drain my Diff tomorrow what kind of gear oil should i get? I looked it up on alldata it say 75w-90? Should I do synthetic or regular? How much? Comanche, Grand Wagoneer, Wrangler, YJ 75W-90 GL-5 With trailer tow pkg. 80W-140 GL-5 Cherokee 75W-90 GL-5 With Class III hitch 80W-140 GLS* *Mopar synthetic gear oil *All with Limited-Slip differential, add one container Mopar Trac-Loc additive CAPACITY Grand Wagoneer 1.8 Liters 3.8 Pints Comanche w/Metric Ton Pkg 1.4 Liters 3.0 Pints Others 1.2 Liters 2.5 Pints bold one correct or is there something else i should get?
Jakeman17 Posted October 19, 2009 Author Posted October 19, 2009 Got pulled over by a State Trooper today I got ticket for no turn signal use(i used it) following to close(guy pulled out in front of me right before cop) He said he let me go on Speeding( only i was speeding though not the guy i was following Loud exhaust?? Reckless driving for trying to pass this guy then going back into same lame??? He was a complete @$$ hole I asked him how fast i was going he said you flew by me...... he was sitting still i was doing 35MPh speed limit lol He gave me a verbal warning (if i would have gotten ticket i would have asked to see radar) but i changed my diff fluid and o2 sensor and got sand bags
ComancheKid45 Posted October 19, 2009 Posted October 19, 2009 Worst thing cops gert on me about is 2 many uncovered lights, lol I think he was just jelous :thumbsup:
Jakeman17 Posted October 19, 2009 Author Posted October 19, 2009 I have to go to court for them also WTF!!! that bs ill just pay them and be done
Jakeman17 Posted October 20, 2009 Author Posted October 20, 2009 Pictures of what i did today in first post
Jakeman17 Posted October 20, 2009 Author Posted October 20, 2009 I want some kind of tip.... in black Help?
Jakeman17 Posted October 20, 2009 Author Posted October 20, 2009 exhaust tip i don't like the the pipe just sitting there
Darren Posted October 20, 2009 Posted October 20, 2009 Go to an exhaust shop and have them put a tailpipe on it. I won't cost very much at all. Exhaust tips are for rice-burners.
reson46 Posted October 20, 2009 Posted October 20, 2009 exhaust tip i don't like the the pipe just sitting there I agree. That definitely isn't a good spot. It is a rock magnet sitting there. Willy
Jakeman17 Posted October 27, 2009 Author Posted October 27, 2009 I found the connector for my cargo light today now just gotta find someone to drill it in for me. Def not gonna do that. Maybe ill run to the body shop have them throw it on
Jakeman17 Posted October 31, 2009 Author Posted October 31, 2009 Here us what I ran at track Run 1 R/T: .968 60': 3.022 330: 7.934 1/8th: 12.384 MPH: 54.02 1000: 16.226 1/4: 19.398 MPH: 70.52 Run 2 R/T: .474 60': 3.004 330: 8.034 1/8: 12.261 MPH: 53.69 1000: 16.152 1/4: 19.355 MPH: 70.80 Run 3 R/T: .670 60': 3.263 330: 8.247 1/8: 12.318 MPH: 58.93 1000: 15.905 1/4: 18.914 MPH: 75.02
