jeepaholic Posted August 29, 2006 Posted August 29, 2006 On a dana 44 the chevy tie rod ends fit in the holes where the tie rods connect...Is this the same for the dana 30 on MJ's? :dunce:
87manche Posted August 29, 2006 Posted August 29, 2006 half ton or one ton? I know the one ton chebby TRE's require the knuckle to be reamed out. Supposedly Dodge one tone TRE's drop right in, but I've never seen it in person.
jeepaholic Posted August 30, 2006 Author Posted August 30, 2006 come on pete,pong, or some other MJ master, hep me hep me :cry:
Oizarod115 Posted August 30, 2006 Posted August 30, 2006 my brother bought jcroffroads 1-ton XJ steering (D30) and had to have his knuckles reamed. (thats from a chevy 2500)
Pete M Posted August 30, 2006 Posted August 30, 2006 On a dana 44 the chevy tie rod ends fit in the holes where the tie rods connect...Is this the same for the dana 30 on MJ's? :dunce: I don't quite understand the question. :hmm:
87manche Posted August 30, 2006 Posted August 30, 2006 I took this to mean: will chevy one ton TRE's fit in a D30 knuckle. see my reply above.
Bounty Hunter Posted August 31, 2006 Posted August 31, 2006 the tie rod ends fit in the holes where the tie rods connect... I tried to break the question down, and I'm still at a loss :roll:
DirtyComanche Posted August 31, 2006 Posted August 31, 2006 Yeah, both of them have tie-rods that fit in holes on the knuckles. However, the holes are of different sizes.
pingpong Posted August 31, 2006 Posted August 31, 2006 You will need to ream the knuckles out. If you are going to do this just go get some 1ton TRE's and make a new steering setup. Of course I recommend doing a over the knuckle conversion at the same time maybe something like this
