87 comanche Posted June 26, 2009 Share Posted June 26, 2009 Are egr vales interchangable with cherokees. I am getting alot of oil in my air box and would like to try one from the junk yard before I buy one for 133.00. If so how new can I go. I have an 87 4.0. Link to comment Share on other sites More sharing options...
Geonovast Posted June 26, 2009 Share Posted June 26, 2009 EGR has nothing to do with oil. The EGR allows exhaust into the intake. Are you talking the PCV system on the top of the valve cover? If you are, then yes. Cherokees and Comanches are pretty much identical from the doors forward. Everything in the engine bay is identical. Front suspension is identical with the exception that the LCA frame mounts on the MJ are a little beefier. So basically, anything on the motor is going to be interchangeable with any 87-90 4.0 XJ/MJ. Link to comment Share on other sites More sharing options...
87 comanche Posted June 26, 2009 Author Share Posted June 26, 2009 I was told my egr valve could be stuck closed causing preasure causing the oil blow back? Link to comment Share on other sites More sharing options...
Geonovast Posted June 26, 2009 Share Posted June 26, 2009 Whoever told you that either doesn't know what they're talking about, or is somehow trying to get money out of you. The EGR is just a pipe that runs from the exhaust manifold to the intake manifold, and is controlled by the valve to allow a small amount of exhaust into the intake. The EGR was completely done away with in 91. Your pcv valves may be crudded up and stuck, which will cause oil to blow by into the air filter. Very common on both the 2.5 and 4.0. The valves are located inside the valve cover, underneath the two big hoses going to it. Link to comment Share on other sites More sharing options...
ratrapp Posted June 26, 2009 Share Posted June 26, 2009 my egr valve has been unplugged for 9 years.most new vehicles don't even have them.like said earlier egr has nothing to do with oil blow by. Link to comment Share on other sites More sharing options...
bigalpha Posted June 26, 2009 Share Posted June 26, 2009 I thought it was a CCV system, not a PCV system? Link to comment Share on other sites More sharing options...
Geonovast Posted June 26, 2009 Share Posted June 26, 2009 I thought it was a CCV system, not a PCV system? It's called either one, but it's the same thing. Crank Case Ventilation Positive Crankcase Ventilation Link to comment Share on other sites More sharing options...
87 comanche Posted June 26, 2009 Author Share Posted June 26, 2009 I read a post quick about a mod to the valve cover but not in depth. So you can just un hook it? I need to replace my valve cover gasket anyway so I guess I will pull it apart and clean it up. Link to comment Share on other sites More sharing options...
ratrapp Posted June 27, 2009 Share Posted June 27, 2009 i had blowby and changed to the steel baffled cover and all my blowby problems disappeared.i gave less than $20 for the cover and used a new model perma seal fel-pro gasket.no more blowby and leaky vc.it's a well worth small project. Link to comment Share on other sites More sharing options...
maddzz1 Posted June 27, 2009 Share Posted June 27, 2009 I read a post quick about a mod to the valve cover but not in depth. So you can just un hook it? I need to replace my valve cover gasket anyway so I guess I will pull it apart and clean it up. It sounds like you are getting the egr valve and CCV hoses confused? Are you asking anout the egr on the driver side near the intake or are you asking about the hoses coming from the valve cover? Link to comment Share on other sites More sharing options...
87 comanche Posted June 28, 2009 Author Share Posted June 28, 2009 The guy pointed to the one on the drivers side. I might try to find a valve cover off a 2000 cherokee from the jy. Where did you find the new steel baffle? Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 1, 2009 Share Posted July 1, 2009 Just a little info on the EGR valve: Link to comment Share on other sites More sharing options...
