90eliminator Posted March 28, 2009 Share Posted March 28, 2009 ok, there are some problems, at current the speedometer in non op...so not a clue what the actual fuel economy is..... But I filled up last night, drove about 150 miles and I am already at 1/4 tank.... could this be injectors.... just had a tuneup.... so I am at a loss.....???? help please.... Link to comment Share on other sites More sharing options...
Automan2164 Posted March 28, 2009 Share Posted March 28, 2009 Just had a tune up? Start simple, if you havent already. Air filter, fuel filter, check gap... No speedo, are you sure on the milage? Rob L. Link to comment Share on other sites More sharing options...
Eagle Posted March 28, 2009 Share Posted March 28, 2009 A failing oxygen sensor can keep the engine running rich. Do you have any idea when yours was last replaced? The O2 sensor is a scheduled maintenance item -- it should be replaced every 75,000 to 80,000 miles. Link to comment Share on other sites More sharing options...
Pete M Posted March 28, 2009 Share Posted March 28, 2009 Does it still drive ok? Does it feel different? Have you tried filling the tank up to see if it's the gauge or sender that's faulty? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 28, 2009 Share Posted March 28, 2009 if your speedometer isn't working, then your odometer isn't working, or isn't showing accurate. how are you gauging your miles travelled? Link to comment Share on other sites More sharing options...
ratrapp Posted March 28, 2009 Share Posted March 28, 2009 i would fix the gauges and see what i'm really getting.my mj with 160k 4.0 and a/t gets about 16mpg.it didn't get much better than that when it was new.my gas gauge when i fill it up takes 100-125 miles before it moves but is accurate when it hits empty.you can't trust the gauges in these trucks.mine is a bad sending unit. Link to comment Share on other sites More sharing options...
Geonovast Posted March 28, 2009 Share Posted March 28, 2009 Me, my dad, and my brother have been driving Jeeps almost exclusivly since 1994, and have never had any gauge problems that were the fault of the gauge itself. Only problems I've had was a speedo that didn't always work, and that was the cause of a worn down speedo gear. Gauges have been pretty reliable for me. :dunno: Link to comment Share on other sites More sharing options...
90eliminator Posted March 28, 2009 Author Share Posted March 28, 2009 ok, the engine has 88k on it, so an o2 sensor is a great place to start...also probably will check the gap, is that per spark plug manufacturer or per engine requirement, if so what is it for ours... I am totally guessing at mileage per gallon, tank sending unit is operating correctly, filled it up, went from empty to full, and as I drive it drops...I need to replace the speedo cable....trip to the yard...oh well.... Thanks guys, I think that the o2 sensor will be my first step....S Link to comment Share on other sites More sharing options...
maddzz1 Posted March 28, 2009 Share Posted March 28, 2009 if your speedometer isn't working, then your odometer isn't working, or isn't showing accurate. how are you gauging your miles travelled? Pat, My speedo doesnt work but my odometer does. Even the trip counter works. I think I messed something up when I took it apart to switch the odom to the correct mileage. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 28, 2009 Share Posted March 28, 2009 if your speedometer isn't working, then your odometer isn't working, or isn't showing accurate. how are you gauging your miles travelled? Pat, My speedo doesnt work but my odometer does. Even the trip counter works. I think I messed something up when I took it apart to switch the odom to the correct mileage. you unwound the spring inside of it then. pretty easy to just replace the gauge. I have a few around...got a pic of it? I can send ya the correct one. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted March 29, 2009 Share Posted March 29, 2009 My fuel guage when I fill up goes to 1/4 tank real fast, but then it seems likew it will run at 1/4 tank for a long time, but seems like empty is correct so I havent tried to fix it. Find out what size tank you have and if you think it really is close to empty, you should be able to fill it close to what it is supposed to take. But yeah, fix your speedo first.Then go from there. Link to comment Share on other sites More sharing options...
