RandysMJ Posted February 27, 2009 Share Posted February 27, 2009 Will a YJ steering box work in a MJ/XJ? I found one that is drilled for hydro assist and has lines for $100. So that sound fair? Link to comment Share on other sites More sharing options...
ren Posted February 28, 2009 Share Posted February 28, 2009 Nope, different mounts, and stub stickout for the column to hook to. Link to comment Share on other sites More sharing options...
offroader461 Posted February 28, 2009 Share Posted February 28, 2009 ren said: Nope, different mounts, and stub stickout for the column to hook to. incorrect..you can use a YJ box but you will need to get this http://www.tntcustoms.com/page.asp?pageid=58 i helped my buddy install one last weekend with this kit and it was smooth..i might be doing it soon also Link to comment Share on other sites More sharing options...
juan Posted February 28, 2009 Share Posted February 28, 2009 Well, I helped swap an xj steering box in a YJ and it fit right in, I just left one bolt out - after all there are 3 bolts holding it - the jeep has benn running like this for several years of fourwheeling w/o any issues.... Link to comment Share on other sites More sharing options...
offroader461 Posted February 28, 2009 Share Posted February 28, 2009 juan said: Well, I helped swap an xj steering box in a YJ and it fit right in, I just left one bolt out - after all there are 3 bolts holding it - the jeep has benn running like this for several years of fourwheeling w/o any issues.... Yea you don't need the 4th bolt but the reason a lot of XJ guys do it is b/c the added support and the YJ box is a fixed ratio instead of a varible ratio box Link to comment Share on other sites More sharing options...
ren Posted February 28, 2009 Share Posted February 28, 2009 Well, nice to know that this can work. I called the local parts house and they said that the boxes usaed different mounts and stub stickout. Oh, well. Something learned for the day. :waving: Link to comment Share on other sites More sharing options...
RandysMJ Posted February 28, 2009 Author Share Posted February 28, 2009 So will it work without that bracket? Link to comment Share on other sites More sharing options...
Eagle Posted February 28, 2009 Share Posted February 28, 2009 offroader461 said: Yea you don't need the 4th bolt but the reason a lot of XJ guys do it is b/c the added support and the YJ box is a fixed ratio instead of a varible ratio box The FSM indicates that the XJ box is a fixed ratio. Where do you see references to variable ratio in the XJ/MJ? Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 28, 2009 Share Posted February 28, 2009 Eagle said: offroader461 said: Yea you don't need the 4th bolt but the reason a lot of XJ guys do it is b/c the added support and the YJ box is a fixed ratio instead of a varible ratio box The FSM indicates that the XJ box is a fixed ratio. Where do you see references to variable ratio in the XJ/MJ? My 1991 FSM refers to the steering box as variable ratio. Excerpt from the 1993 Service manual: STEERING SYSTEM - POWER 1993 Jeep Cherokee 1993 STEERING Chrysler Corp. Power Steering - Recirculating Ball Jeep; Cherokee, Grand Cherokee, Grand Wagoneer, Wrangler DESCRIPTION & OPERATION NOTE: This article has been revised as per TSB # 19-02-93 dated Feb. 22, 1993. Steering gear is a variable ratio, recirculating ball type. Power assist is provided by a belt driven hydraulic pump. Control valves are located inside steering gear housing. Maybe the Renix boxes are fixed?? Link to comment Share on other sites More sharing options...
Eagle Posted March 1, 2009 Share Posted March 1, 2009 I'm going to send Pete the bill for treating my hernia. Just dragged out the 88 (which is really the 86), 94, and 2000 factory manuals. 88(86) (XJ & MJ): Steering gear type: Recirculating ball with hydraulic assist Steering Gear Ratio: .....1984-85 & 86 "off road" package .......... 17:1 .....1986 - All except "off road" package ..... 14:1 ---------------------------- 1994 (XJ & YJ): Steering gear type: Recirculating ball with hydraulic assist Ratio Code (Top of Gear): .....BH, NZ ............................................ 14:1 .....BF, XS ...................................... 13 - 16:1 .....AL ................................................ 12.7:1 ---------------------------- 2000 (XJ Only): Steering Gear .....Type.............................. Recirculating Ball Gear Ratio: .....LHD ................................................ 14:1 .....RHD ................................................ 14:1 ---------------------------- The 1994 FSM covers both the XJ Cherokee and the YJ Wrangler, so I have no way of knowing which of those steering box code would apply to which vehicles and/or which packages. I know the steering in the 2000 XJ feels much better than the 88 XJ and MJ, but I'd be extremely happy if I could lay my hands on one of the 12.7:1 boxes for my daily driver. I've been tempted to take the box out of one of the hulks and have it rebuilt as a 12:1 box. That would be just about right for the way I drive, I think. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 1, 2009 Share Posted March 1, 2009 Eagle said: I'm going to send Pete the bill for treating my hernia. Just dragged out the 88 (which is really the 86), 94, and 2000 factory manuals. 88(86) (XJ & MJ): Steering gear type: Recirculating ball with hydraulic assist Steering Gear Ratio: .....1984-85 & 86 "off road" package .......... 17:1 .....1986 - All except "off road" package ..... 14:1 ---------------------------- 1994 (XJ & YJ): Steering gear type: Recirculating ball with hydraulic assist Ratio Code (Top of Gear): .....BH, NZ ............................................ 14:1 .....BF, XS ...................................... 13 - 16:1 .....AL ................................................ 12.7:1 ---------------------------- 2000 (XJ Only): Steering Gear .....Type.............................. Recirculating Ball Gear Ratio: .....LHD ................................................ 14:1 .....RHD ................................................ 14:1 ---------------------------- The 1994 FSM covers both the XJ Cherokee and the YJ Wrangler, so I have no way of knowing which of those steering box code would apply to which vehicles and/or which packages. I know the steering in the 2000 XJ feels much better than the 88 XJ and MJ, but I'd be extremely happy if I could lay my hands on one of the 12.7:1 boxes for my daily driver. I've been tempted to take the box out of one of the hulks and have it rebuilt as a 12:1 box. That would be just about right for the way I drive, I think. Well I know for sure the YJs are fixed ratio boxes. But what you posted Eagle is something I've been thinking about doing for awhile. My 91 steering box (14.1:1 ratio) has some slop and I am looking for a replacement. I am almost sure that the 90s ZJ V8 box (12.7:1 ratio) would be a direct swap. This would quicken the steering a bit and it's also beefier. Have read about the Durango and YJ box swaps, but the ratio is higher or the same (unless you get one rebuilt as you suggested). So what do you think Eagle - will the ZJ box work? I've done a lot of searching and have not found anyone who has done the ZJ box in an XJ/MJ, but the GM hot rod guys swap them all the time for the quick steering ratio. Link to comment Share on other sites More sharing options...
aemsee Posted March 1, 2009 Share Posted March 1, 2009 Don't know if it makes a difference or not, but some of those ZJ's had something called Speedpro steering. It was a module that changed the amount of assist through the pump. Link to comment Share on other sites More sharing options...
Eagle Posted March 1, 2009 Share Posted March 1, 2009 GM boxes are pretty widely interchangeable, whether they used three or four bolts to mount. The fourth bolt can be ignored in an MJ/XJ, and I think the other three are in the same positions. In my case, the Borgeson Company (http://www.borgeson.com/) is just a few miles north of me, and even closer to where I work, so one of these days I plan on taking the worn out box I took out of the 88 MJ up to them and asking if they'll rebuild it to a 12:1 box, with a stiff spool valve for better road feel/response. I really hate variable ratio. The problem is, I do a WHOLE lot more highway driving than I do off-roading. Fir highway driving, I want a box that gives my instantaneous response if I need to make an evasive manuever. And the variable ratio boxes are slowest at the straight ahead (center) position, and the ratio gets faster as you get more into the turn. For my purposes, that's worse than useless -- it bass-ackwards. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 1, 2009 Share Posted March 1, 2009 Eagle said: GM boxes are pretty widely interchangeable, whether they used three or four bolts to mount. The fourth bolt can be ignored in an MJ/XJ, and I think the other three are in the same positions. In my case, the Borgeson Company (http://www.borgeson.com/) is just a few miles north of me, and even closer to where I work, so one of these days I plan on taking the worn out box I took out of the 88 MJ up to them and asking if they'll rebuild it to a 12:1 box, with a stiff spool valve for better road feel/response. I really hate variable ratio. The problem is, I do a WHOLE lot more highway driving than I do off-roading. Fir highway driving, I want a box that gives my instantaneous response if I need to make an evasive manuever. And the variable ratio boxes are slowest at the straight ahead (center) position, and the ratio gets faster as you get more into the turn. For my purposes, that's worse than useless -- it bass-ackwards. Same-o. That's what I'm looking for too. :D Link to comment Share on other sites More sharing options...
wolfpackjeeper Posted March 1, 2009 Share Posted March 1, 2009 I am going to put a GM box into mine when I get power steering swapped in. It is the "Z" box from a formula trans am. Should turn in a tighter pattern and be better for the road work I intend to set this up for. Link to comment Share on other sites More sharing options...
Eagle Posted March 1, 2009 Share Posted March 1, 2009 wolfpackjeeper said: I am going to put a GM box into mine when I get power steering swapped in. It is the "Z" box from a formula trans am. Should turn in a tighter pattern and be better for the road work I intend to set this up for. That would be my choice for a junkyard box, too -- if the spline for the pitman arm is the same. That should have the quick ratio, and the spool valve (the "module" to which someone referrered above) should be the one that provides less boost & better road feel. Link to comment Share on other sites More sharing options...
wolfpackjeeper Posted March 1, 2009 Share Posted March 1, 2009 Eagle said: wolfpackjeeper said: I am going to put a GM box into mine when I get power steering swapped in. It is the "Z" box from a formula trans am. Should turn in a tighter pattern and be better for the road work I intend to set this up for. That would be my choice for a junkyard box, too -- if the spline for the pitman arm is the same. That should have the quick ratio, and the spool valve (the "module" to which someone referrered above) should be the one that provides less boost & better road feel. we had it in my buddies cherokee, but we took it out when the pitman seal started leaking. I will just change out the seals and call it done. It worked fine, and his pitman fit right on. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 12, 2009 Share Posted March 12, 2009 Eagle said: GM boxes are pretty widely interchangeable, whether they used three or four bolts to mount. The fourth bolt can be ignored in an MJ/XJ, and I think the other three are in the same positions. In my case, the Borgeson Company (http://www.borgeson.com/) is just a few miles north of me, and even closer to where I work, so one of these days I plan on taking the worn out box I took out of the 88 MJ up to them and asking if they'll rebuild it to a 12:1 box, with a stiff spool valve for better road feel/response. I really hate variable ratio. The problem is, I do a WHOLE lot more highway driving than I do off-roading. Fir highway driving, I want a box that gives my instantaneous response if I need to make an evasive manuever. And the variable ratio boxes are slowest at the straight ahead (center) position, and the ratio gets faster as you get more into the turn. For my purposes, that's worse than useless -- it bass-ackwards. Got a new (to me) ZJ steering box installed today from a 95 Grand. All the 92-1/2 to 98 ZJs boxes had a quicker steering ratio than our XJ/MJ boxes (12.7:1 vs. 14.1:1). Man, it makes a world of difference with the quicker steering and is much more responsive on the road. Handles almost like a sportscar now mates. :D I'm not sure if the ZJ box is variable ratio the XJ/MJ, or fixed ratio like the YJ. But it sure feels better. Very worthwhile mod, I like it a LOT better. :cheers: Link to comment Share on other sites More sharing options...
88 Beast Posted March 13, 2009 Share Posted March 13, 2009 Is it a bolt in? No mods to hoses? Sounds like a good deal. My stock steering box starting to leak and never cared for the feel ( or should I say lack of!) Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 13, 2009 Share Posted March 13, 2009 No mods at all, just have to reuse the MJ pitman arm as the ZJ arm hangs about an inch lower. Works great. Link to comment Share on other sites More sharing options...
jtdesigns Posted March 13, 2009 Share Posted March 13, 2009 hornbrod said: No mods at all, just have to reuse the MJ pitman arm as the ZJ arm hangs about an inch lower. Works great. Wouldnt you want that if your lifted? Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 13, 2009 Share Posted March 13, 2009 jtdesigns said: Wouldnt you want that if your lifted? Naw, not needed for 3" or below. Good for bigger lifts though........ The ZJ pitman arm is a good alternative (read cheaper) to an aftermarket arm for bigger lifts though. Link to comment Share on other sites More sharing options...
rustybottoms88 Posted June 11, 2015 Share Posted June 11, 2015 Back from the dead. My Mj steering gear it puking fluid. Hornbrod you still happy with the ZJ steering box? Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 12, 2015 Share Posted June 12, 2015 Yep, still there, still fine. You will like it. Any stock 93-98 ZJ box will work. Link to comment Share on other sites More sharing options...
Megadan Posted June 12, 2015 Share Posted June 12, 2015 Well, looks like I have something else to grab from the bone yard now. Already raiding a ZJ for about 10 other parts. You guys are going to make me broke lol. Link to comment Share on other sites More sharing options...
