where can i buy a model comanche
comanche13
I couldn't find any either so I made my own out of some Matchbox 1:64 2-door Cherokees. The Red one is actually two XJs spliced together to extend the bed. The only 4-door Cherokees I’ve found are made by Majorette, but I have not converted those yet.
Now that is cool! :clapping:
That is great work Mike! I wonder if this company
http://yhst-97102109552530.stores.yahoo ... nting.html
might build some of those toy trucks you made? If it was financially feasible I know I would buy a few. It looks like they need at least a 150 minimum order.
This is what the finished product looks like. I know you guys can make them. Just get the Matchbox Cherokees, drill out the rivets holding it together, strip all the paint, cut off the top past the b-pillar, cut the hatch and use it to extend the bed (and house the rear window), use the left over top to make the bed front (the ridges make it look right), sand off the ridges on the roof, fill in the gas tank door and all seams with model putty, sand everything. If your XJ has holes in the roof for a light bar just fill them with model putty. You'll have to modify the interior by cutting off the rear seats and covering the back portion with something to look like the bottom of the bed and cut the window to fit the front/side windows and use the rear window for the rear. Paint and assemble. I just use epoxy where the rivet posts come through base.
