JeepcoMJ Posted December 10, 2008 Share Posted December 10, 2008 oooooooooo i thought u meant using an aftermarket oil pressure gauge. :ack: ...of the electronic variety if I do. Link to comment Share on other sites More sharing options...
skibumps Posted January 17, 2009 Share Posted January 17, 2009 What is the schrader valve on the fuel rail normally used for ? I like the gauge, but I'm wondering if the valve is used for something other than checking pressure? (introducing injector cleaner, just releasing pressure ect...) Skibumps Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 17, 2009 Author Share Posted January 17, 2009 It's just a test port for checking fuel rail pressure. That's is it's only function in life. Link to comment Share on other sites More sharing options...
relyt120 Posted October 7, 2012 Share Posted October 7, 2012 This seems perfect to help me diagnose my intermittent over fuelling issue, is there another source for the fitting? The link in op is broken, no wonder after 4 years though :rotf: Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 7, 2012 Author Share Posted October 7, 2012 The link works fine. http://www.casperselectronics.com/store2/product_info.php?products_id=1337 Link to comment Share on other sites More sharing options...
relyt120 Posted October 7, 2012 Share Posted October 7, 2012 Well I'll be damned, I don't know what is issue was. Thanks hornbrod! Link to comment Share on other sites More sharing options...
Comanche County Posted October 27, 2012 Share Posted October 27, 2012 Nice, I need to do this one! Link to comment Share on other sites More sharing options...
1989 Eliminator Posted July 14, 2014 Share Posted July 14, 2014 I also bought this setup of fittings. A 1/4" female flare to 1/8" NPT Female straight and a 1/8" NPT Female x 1/8" NPT Male Elbow. I did this since I can look at the guage better this way. I got these off of McMaster Carr. Around $12 total. Part#: 6432T117 http://www.mcmaster.com/#catalog/120/195/=su11cn (Update... Bought the flare fitting and the threads are not deep enough to catch the threads on the fuel rail.) Part#: 4452K471 http://www.mcmaster.com/#catalog/120/4/=su11ql Link to comment Share on other sites More sharing options...
Rohls Posted January 11, 2015 Share Posted January 11, 2015 Okay, so I did this mod; very cool! My pressure at idle is 44 PSI (!). I rev it to about 2000 RPM and it tops out at 48 PSI... Is this okay? To be expected? I have the larger multi-port injectors (Mustang 5.0 I believe) and an updated fuel pressure regulator that I thought was supposed to regulate the pressure to ~39 PSI...no? Link to comment Share on other sites More sharing options...
Rohls Posted January 11, 2015 Share Posted January 11, 2015 Okay, so I did this mod; very cool! My pressure at idle is 44 PSI (!). I rev it to about 2000 RPM and it tops out at 48 PSI... Is this okay? To be expected? I have the larger multi-port injectors (Mustang 5.0 I believe) and an updated fuel pressure regulator that I thought was supposed to regulate the pressure to ~39 PSI...no? Also, i was reading the instructions that came with the brass adapter and it warns against using glycerin filled gauges on the fuel rail because the engine vibs could crack the Shrader valve eventually...I guess its a weight thing.....anyone ever heard of this happening? Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 11, 2015 Author Share Posted January 11, 2015 Okay, so I did this mod; very cool! My pressure at idle is 44 PSI (!). I rev it to about 2000 RPM and it tops out at 48 PSI... Is this okay? To be expected? I have the larger multi-port injectors (Mustang 5.0 I believe) and an updated fuel pressure regulator that I thought was supposed to regulate the pressure to ~39 PSI...no? Sounds like you bought the wrong regulator. Which "updated" regulator did you install? A GM regulator? They are useful perhaps on a stroker to correct a lean condition but should not be on a N/A engine. Also, i was reading the instructions that came with the brass adapter and it warns against using glycerin filled gauges on the fuel rail because the engine vibs could crack the Shrader valve eventually...I guess its a weight thing.....anyone ever heard of this happening? Maybe if you hit it with a hammer long enough. :yes: I've had one mounted for years. They are referring to the larger 2-1/16" gauges. Link to comment Share on other sites More sharing options...
Rohls Posted January 11, 2015 Share Posted January 11, 2015 Okay, so I did this mod; very cool! My pressure at idle is 44 PSI (!). I rev it to about 2000 RPM and it tops out at 48 PSI... Is this okay? To be expected? I have the larger multi-port injectors (Mustang 5.0 I believe) and an updated fuel pressure regulator that I thought was supposed to regulate the pressure to ~39 PSI...no? Sounds like you bought the wrong regulator. Which "updated" regulator did you install? A GM regulator? They are useful perhaps on a stroker to correct a lean condition but should not be on a N/A engine. Also, i was reading the instructions that came with the brass adapter and it warns against using glycerin filled gauges on the fuel rail because the engine vibs could crack the Shrader valve eventually...I guess its a weight thing.....anyone ever heard of this happening? Maybe if you hit it with a hammer long enough. :yes: I've had one mounted for years. They are referring to the larger 2-1/16" gauges. Thanks Hornbrod. I was checking my records and I believe it is the PR11 for Chrysler vehicles. I remember doing research and that's the best I could come up with. I think this one....http://www.ebay.com/itm/PR211-NEW-Fuel-Injection-Pressure-Regulator-for-CHRYSLER-DODGE-PLYMOUTH-/261522234559?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ce3f09cbf&vxp=mtr Which one do you suggest i buy? The motor is stock other than the injectors pretty much. Here is an image on mine...it has 8565 stamped in it...I haven't got around to noting the other number...I imagine its a PN. Thanks! Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 11, 2015 Author Share Posted January 11, 2015 If you have a stock engine you should be using the stock fuel pressure regulator to maintain the proper A/F (air/fuel) ratio. It's pressure is sized for your fuel system, 31 and 39 psi in this case. Obviously you have one that's has a higher pressure rating and you're just wasting fuel. You should be using the below or similar for your 92 4.0. http://www.jeep4x4center.com/fuel-pressure-regulator-53030001.html Another remote possibility is that your new pressure gauge may be reading high. It's doubtful, but verify this using a rental set of gauges from Autozone or another parts store. Link to comment Share on other sites More sharing options...
Rohls Posted January 12, 2015 Share Posted January 12, 2015 Hmm... I really thought the larger injectors required the higher pressure regulator... Also, when I first put the injectors in I started it with the stock regulator and is coughed, sputtered and ran like crap...hence buying the upgraded 44psi regulator. What should I do? Link to comment Share on other sites More sharing options...
Rohls Posted January 13, 2015 Share Posted January 13, 2015 Any thoughts on this...? Link to comment Share on other sites More sharing options...
ggcnash Posted January 13, 2015 Share Posted January 13, 2015 Any thoughts on this...?Exactly what Hornbrod said go back stock, when I put my new injectors it also run like crap till computer learned new setup. Good luck Link to comment Share on other sites More sharing options...
ggcnash Posted January 13, 2015 Share Posted January 13, 2015 As stated you only get a higher pressure regulator of you have a stroker. With a stock engine you stay stock the point of the upgraded injectors is for the 4 hole spray pattern vs single. Link to comment Share on other sites More sharing options...
Jeepman Posted January 13, 2015 Share Posted January 13, 2015 Hmm... I really thought the larger injectors required the higher pressure regulator... Also, when I first put the injectors in I started it with the stock regulator and is coughed, sputtered and ran like crap...hence buying the upgraded 44psi regulator. What should I do? Ok I see a lot of miss info here so I wanted to chime in... what I see misunderstood is not that you have a larger regulator or larger injectors but how your mixing them... Example... Your Stock system is 31psi @ idle and 39psi without vacuum which is usually on acceleration... Your Factory injectors which vary in size but roughly in and around 20-21lbs run at 39psi so the mustang injectors you installed need to be run at the pressure of the mustang otherwise they are larger or smaller then they were intended for... So if you have a 24lbs injector (typical mustang injector for a 5.0L) and running at lets say 38psi (I do not know what the actual pressure is for the mustang) would mean that the injectors your running will be around 25.5lbs which is way too large for a Stock engine unless you have done a lot of upgrades... If you have the bosch part number on the injector I can run them to see what the lbs and psi are for that specific injector... Either return your regulator to stock 31-39psi or match the pressure to bring down the mustang injectors... I run Both an in cab A pillar pod with A/F Gauge and electronic Fuel pressure gauge as I prefer to see what my fuel is when I am on the throttle but my system is now OBDII 49psi constant and I run a 4.7L Stroker engine... Link to comment Share on other sites More sharing options...
Rohls Posted January 14, 2015 Share Posted January 14, 2015 Thanks guys. The Bosch injector number is 0280155700. I bought them after reading another post on this forum. The ebay listing is http://rover.ebay.com/rover/0/e11400.m1842.l3160/7?euid=7aa58b828db147fa8d5699ebd1ead20f&loc=http%3A%2F%2Fcgi.ebay.com%2Febaymotors%2Fws%2FeBayISAPI.dll%3FViewItem%26item%3D261285799097%26ssPageName%3DADME%3AL%3AOC%3AUS%3A3160 I not believe he mentions flow rate or what regulator swap. Link to comment Share on other sites More sharing options...
ggcnash Posted January 14, 2015 Share Posted January 14, 2015 Thanks guys. The Bosch injector number is 0280155700. I bought them after reading another post on this forum. The ebay listing is http://rover.ebay.com/rover/0/e11400.m1842.l3160/7?euid=7aa58b828db147fa8d5699ebd1ead20f&loc=http%3A%2F%2Fcgi.ebay.com%2Febaymotors%2Fws%2FeBayISAPI.dll%3FViewItem%26item%3D261285799097%26ssPageName%3DADME%3AL%3AOC%3AUS%3A3160 I not believe he mentions flow rate or what regulator swap. I think you need to move this to tech instead of posting on Hornbrods write up.The number you need and what I used is Bosch 0280155703 with stock regulator runs great Link to comment Share on other sites More sharing options...
Jeepman Posted January 14, 2015 Share Posted January 14, 2015 Done Link to comment Share on other sites More sharing options...
TheDude Posted February 2, 2015 Share Posted February 2, 2015 Is there anywhere else to likely carry the adapter? Something about spending $25 on such a simple part makes me cringe. Link to comment Share on other sites More sharing options...
Arizona Duffer Posted February 10, 2015 Share Posted February 10, 2015 Hornbrod, what am I missing here? I am extremely interested in fitting my 'manche with a pressure gauge. But, two problems. First, the Shrader valve on this vehicle's rail is canted downwards somewhat. It is not obvious to me that the rail can be repositioned upward...but perhaps. Second, the problem with a downward can't is that the gauge seriously conflicts with what appears to be a CCV assembly of tubes, etc. That's not to say with some creativity, I couldn't lower them a tad. But is it possible you have replaced this assembly with a more stream-lined version? I toyed with the thought of a 60-degree bronze extension fitting (to lift the gauge up slightly), but I'm not sure it would clear the hood. Even if I were able to reposition the rail so that the Shrader valve was canted somewhat upwards, I would still be conflicting with the supposed CCV stuff. Another question, arising from taking many long looks at your photos. I have been toying with chroming the valve cover to class the joint up a bit. In your photos, though, you seem to have a different-than-chrome coating on the valve cover...is that right? What is it? Thanks for any thoughts. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 10, 2015 Author Share Posted February 10, 2015 Then you must have a Renix era MJ. You'll have to use an elbow fitting for clearance to adapt the gauge to the Renix rail. It would be a good idea to add your year and model specifics to your signature so we don't have to guess what you are driving. :thumbsup: http://comancheclub.com/topic/44810-stalling-out-craziness/page-5 My valve cover is silver powder coated with the ribs polished natural. Link to comment Share on other sites More sharing options...
TheDude Posted February 13, 2015 Share Posted February 13, 2015 I also bought this setup of fittings. A 1/4" female flare to 1/8" NPT Female straight and a 1/8" NPT Female x 1/8" NPT Male Elbow. I did this since I can look at the guage better this way. I got these off of McMaster Carr. Around $12 total. Part#: 6432T117 http://www.mcmaster.com/#catalog/120/195/=su11cn (Update... Bought the flare fitting and the threads are not deep enough to catch the threads on the fuel rail.) Part#: 4452K471 http://www.mcmaster.com/#catalog/120/4/=su11ql Are these the part numbers I need? He updated and says something didn't fit but didn't say if those part # have been corrected or not. Link to comment Share on other sites More sharing options...
