Knucklehead97 Posted January 12, 2015 Author Share Posted January 12, 2015 Can't smell any. And I've got a "new" sending unit on the way to put in after I clean it up some. May drop the new unit in after checking for leaks on it and see if it has better pressure or anything. Still will check my old one though. Link to comment Share on other sites More sharing options...
Knucklehead97 Posted February 8, 2015 Author Share Posted February 8, 2015 I finally got the sending unit and fuel pump installed. I turn the key and hear a nice hum. Then I crank it and bam started right up (after my brother in law jumped me off because for some reason my battery was dead... ) BUT. I have 31 PSI with engine off and key ON. Just the fuel pump running. But then I have about 26 at idle with the vacuum line connected and just engine cold. I didnt have time to let the engine warm up. Do I seriously still have low fuel pressure with every fuel system component changed? Help is seriously needed. Link to comment Share on other sites More sharing options...
