comanche13 Posted November 10, 2008 Share Posted November 10, 2008 ok i just got a comanche and i have to kinda winterize it so i don't wreck it and I'm doing my block heater right now what is the size of the block heater like i bought one and its 4.5cm and my engine's frost plug when i measured it is 5cm any one know where the block heater is supposta be located on the engine? how much are rino bed liners sprayed in anyone have one on there truck? Link to comment Share on other sites More sharing options...
HKB3 Posted November 10, 2008 Share Posted November 10, 2008 Myself & My brother both have Line X liners great product, cost around $400 going to get one in the MJ after paint Link to comment Share on other sites More sharing options...
Catatonic Comanche Posted November 10, 2008 Share Posted November 10, 2008 ok i just got a comanche and i have to kinda winterize it so i don't wreck it and I'm doing my block heater right now what is the size of the block heater like i bought one and its 4.5cm and my engine's frost plug when i measured it is 5cm any one know where the block heater is supposta be located on the engine? how much are rino bed liners sprayed in anyone have one on there truck? Behold...a Ziebart-applied Rhino spray-on bedliner after 5 years...faded and peeling! Good luck and I hope you experience better Rhino results than I... V/R :beerhead: Paul Link to comment Share on other sites More sharing options...
Eagle Posted November 10, 2008 Share Posted November 10, 2008 The factory block heater goes into either the front or the #2 freeze plug hole on the left (driver's side) of the block. Did you buy yours from Jeep? I retrofitted an '88 XJ 4.0L with a new one from the dealer and it went right in with no problems. Link to comment Share on other sites More sharing options...
Pete M Posted November 10, 2008 Share Posted November 10, 2008 I also have peeling Rhino liner (on my truck's rockers). I've seen other guys' trucks that have Rhino and it seems to be holding up, so I'm guessing there's going to be some variation due to the installer. :dunno: Link to comment Share on other sites More sharing options...
Catatonic Comanche Posted November 10, 2008 Share Posted November 10, 2008 I also have peeling Rhino liner (on my truck's rockers). I've seen other guys' trucks that have Rhino and it seems to be holding up, so I'm guessing there's going to be some variation due to the installer. :dunno: Ziebart should be an honorable installer. They failed my minimal expectations. You witnessed the image that I posted. You be the judge... V/R :beerhead: Paul Link to comment Share on other sites More sharing options...
comanche13 Posted November 10, 2008 Author Share Posted November 10, 2008 I BOUGHT MY BLOCK HEATER FROM NAPA i dono what type of bed liner i want i have a plastic one in there right now. Link to comment Share on other sites More sharing options...
BLHTAZ Posted November 10, 2008 Share Posted November 10, 2008 I would advise taking the block heater back and getting the one from the dealer. I had Line-X done in mine. Had a bit of a problem with it peeling paint off on the outside of the bed when they removed the tape, but the liner is great. It was about $400... Link to comment Share on other sites More sharing options...
WahooSteeler Posted November 10, 2008 Share Posted November 10, 2008 I would advise taking the block heater back and getting the one from the dealer. I had Line-X done in mine. Had a bit of a problem with it peeling paint off on the outside of the bed when they removed the tape, but the liner is great. It was about $400... HKB3 and Meatgrinder, I was going to mention Brett's woes if he had not posted up. Brett, IIRC, you had your liner done not too long after your paint job and you felt that maybe the paint had not cured 100%. Also, because I was very interested your thread at the time because I was hoping to paint and line soon (still haven't done it though), the discussion in your thread was that it would be advisable to do the liner first and paint second to avoid this potential problem. I believe if you are not planning on going "over the rail" like Brett has done, the paint guys generally are not too happy about having to tape off the bed. Just some food for thought.......... Link to comment Share on other sites More sharing options...
BLHTAZ Posted November 10, 2008 Share Posted November 10, 2008 Yes...the liner was done about 7 months after the paint, so it was ASSumed that maybe it was still too new to stand up to the tape job. If you look at the invoice from Line-X, it very clearly states that paint damage is possible from the tape on any vehicle though regardless of the age of the paint. It's one of those risks you take and something that is "possible", but doesn't happen often. Link to comment Share on other sites More sharing options...
DirtyComanche Posted November 10, 2008 Share Posted November 10, 2008 For block heaters, there's a couple options that each have their merit. A) Freeze plug replacement. OEM style, like what you bought. I believe you have the wrong one (normal parts store screwup). Northland probably won't help you much more than chieftan, NAPA or Lordco can. Just go in and ask for a block heater, then ask for a freeze plug for the same truck. If they are the same dimensions, you probably found the right block heater. B) In-line hose ones. They require you to cut a rad hose (lower or upper), and are then installed with a couple hose clamps. They aren't as effective. C) Pressure bottle heater, or rad cap heater. I've seen them a couple times. With a closed system one would work good. A guy could also wrap a battery blanket (basically a heating pad for the battery) over the pressure bottle. D) Magnetic stick-on heater. I've never used them, princess auto sells them, but I've seen them stuck to the oil pan on equipment before. I think they would work best on an oil pan, providing it was steel. Another thing that is really nice is a 'buddy heater'. It's just a small electric heater that a guy can throw in the cab. You can put one under the hood too - but I'd not do any sort of permanent install. We use 'em in the helicopters all the time, 1 or 2 in the cabin, 1 or 2 on the engine deck, and 1 on the tranny deck, and it keeps everything toasty warm. Link to comment Share on other sites More sharing options...
