james750 Posted October 31, 2008 Share Posted October 31, 2008 Was ABS ever offered in the mj? What all is involved in putting in an ABS system into an MJ? Thanks, James :cheers: Link to comment Share on other sites More sharing options...
jbhill Posted October 31, 2008 Share Posted October 31, 2008 doubt it, and abs is a crock. Link to comment Share on other sites More sharing options...
Motion Offroad Posted October 31, 2008 Share Posted October 31, 2008 It's a very large job to put ABS into a MJ. You need the tone rings on the axles, all the axle stuff. So your better off just buying ABS equipped axles and swapping in. Than you need the pump and all electric stuff. Change out the bolster to a ABS one etc. Unfortunately (for those of use who already have ABS on the XJ/MJ) the system is less than desirable. The ABS system is known to have issues, and with several recalls on the systems and them still not functioning correctly many guys will just disconnect the pump and run without the ABS. 9 times out of 10 the system works better without the ABS running than it does with it running. Personally I can't see any major benefit to having the ABS in your MJ, and it's not going to be a cheap process to put it in. Not worth the headache/cost if you ask me. Link to comment Share on other sites More sharing options...
BLHTAZ Posted October 31, 2008 Share Posted October 31, 2008 Definitely not worth it. There were XJ's that came with it, but you can't find a lot of parts for them any more and the ones that you can find are insanely expensive. I looked up a replacement ABS pump/controller for one a couple months ago and it was over $2000 :eek: Link to comment Share on other sites More sharing options...
robfg67 Posted October 31, 2008 Share Posted October 31, 2008 James, if you want better brakes go for this mod: '99-'04 Grand Cherokee Booster and Master Upgrade I haven't done it myself yet, but its on my list. Link to comment Share on other sites More sharing options...
james750 Posted October 31, 2008 Author Share Posted October 31, 2008 Yeah, that mod is on my list as well. The reason I wanted ABS is just b/c of the icy roads in winter. Better brakes won't help with that. Link to comment Share on other sites More sharing options...
Sir Sam Posted November 1, 2008 Share Posted November 1, 2008 Yeah, that mod is on my list as well. The reason I wanted ABS is just b/c of the icy roads in winter. Better brakes won't help with that. Your honestly better off adapting the ABS system from a 97+ to be front wheel ABS only for a MJ than trying to source the model year correct parts for the ABS. I once had a 2wd isuzu rodeo - with rear abs only........that was a crock. Link to comment Share on other sites More sharing options...
james750 Posted November 1, 2008 Author Share Posted November 1, 2008 Front is all I need really. If the rear locks thats ok, but its no fun at all when the front tires lock. :eek: Link to comment Share on other sites More sharing options...
FxRacing282 Posted November 2, 2008 Share Posted November 2, 2008 Front is all I need really. If the rear locks thats ok, but its no fun at all when the front tires lock. :eek: you know, i used to think the same thing. until some college girl walked in front of me and my rear end almost went into another car. Link to comment Share on other sites More sharing options...
Eagle Posted November 2, 2008 Share Posted November 2, 2008 Personally I hate ABS, but I wish I had it for my wife. However, especially in a pickup, the rear is what's probably going to lock up first. IF I were going to put ABS on only one end of a pickup, I'd put it on the rear rather than the front. Link to comment Share on other sites More sharing options...
exjay33 Posted November 3, 2008 Share Posted November 3, 2008 If you really want abs buy something with it , abs on something you use wheeling will get you hurt . If you start sliding down a hill backwards abs does not know which way you are going hold on cause it is going too get fun . Link to comment Share on other sites More sharing options...
mvusse Posted November 3, 2008 Share Posted November 3, 2008 Makes me remember almost getting T-boned by a TJ barrelling downhill backwards when his brakes let go last week. The moment he hit level ground he stopped on a dime. TJs have ABS by any chance? Link to comment Share on other sites More sharing options...
FxRacing282 Posted November 3, 2008 Share Posted November 3, 2008 If you really want abs buy something with it , abs on something you use wheeling will get you hurt . If you start sliding down a hill backwards abs does not know which way you are going hold on cause it is going too get fun . no it would still work the same I'm pretty sure. abs dosent care what way your going. it just cares about keeping the wheels from locking up. Link to comment Share on other sites More sharing options...
Eagle Posted November 3, 2008 Share Posted November 3, 2008 If you really want abs buy something with it , abs on something you use wheeling will get you hurt . If you start sliding down a hill backwards abs does not know which way you are going hold on cause it is going too get fun . 10-4. That's why I don't have ABS even on the newer Cherokees, when it was available at the time I bought them. If I had known I was going to remarry and turn the 2000 XJ Classic over to my wife, I would have ordered it with ABS. But ... it's configured the way I wanted it for me (except it has automatic, since the 5-speed wasn't offered in the Classic). Link to comment Share on other sites More sharing options...
Sir Sam Posted November 3, 2008 Share Posted November 3, 2008 If you really want abs buy something with it , abs on something you use wheeling will get you hurt . If you start sliding down a hill backwards abs does not know which way you are going hold on cause it is going too get fun . 10-4. That's why I don't have ABS even on the newer Cherokees, when it was available at the time I bought them. If I had known I was going to remarry and turn the 2000 XJ Classic over to my wife, I would have ordered it with ABS. But ... it's configured the way I wanted it for me (except it has automatic, since the 5-speed wasn't offered in the Classic). Also keep in mind that D35 equipped XJs could have ABS. If you wanted a 8.25 then you would not have abs. Link to comment Share on other sites More sharing options...
BLHTAZ Posted November 3, 2008 Share Posted November 3, 2008 TJs have ABS by any chance? It was an available option in Wranglers starting in 1993 (I believe), but you will find very few with it. Link to comment Share on other sites More sharing options...
