jeepaholic Posted June 23, 2006 Share Posted June 23, 2006 Jeeeezus. When i decided on a MJ for my next project I didnt plan on it being so hard to find one. The cj5 is done and i need something to wrench on. :headpop: Just keep your eyes open for one :eek: Link to comment Share on other sites More sharing options...
mjeff87 Posted June 23, 2006 Share Posted June 23, 2006 What specs/price range are you looking for (if any), or do you just want a builder? Link to comment Share on other sites More sharing options...
jeepaholic Posted June 23, 2006 Author Share Posted June 23, 2006 I would like..shortbed..manual..4x4...4.0L....I want to get something to tinker w/...thinking of 6"lift...12/50 33's Ground Hawgs..Gonna have to make it a grocery getter/wheeler. Wife wants to be able to drive around town in it. :nuts: Link to comment Share on other sites More sharing options...
Dadinator Posted June 23, 2006 Share Posted June 23, 2006 How about this one. This dude can't spell comanche either. :D http://cgi.ebay.com/ebaymotors/Jeep-Che ... enameZWDVW :cheers: Link to comment Share on other sites More sharing options...
jage Posted June 24, 2006 Share Posted June 24, 2006 The 'manche I got from my dad had the same B&M shifter handle installed on the stick. I hated it... nice looking MJ tho. :drool: ...already a 4.0 manual and a 4wd... wouldn't that be nice (but not free like my basket case) Link to comment Share on other sites More sharing options...
whowey Posted June 24, 2006 Share Posted June 24, 2006 The 'manche I got from my dad had the same B&M shifter handle installed on the stick. I hated it... nice looking MJ tho. I cut the end off my Pugeot shifter and welded on a new one to install almost that shifter knob. I have the one with the writing outlined in red on mine. Pretty cool, except when its 90 degrees outside and the MJ has been in the sun all day. Link to comment Share on other sites More sharing options...
xmeatbagx Posted June 24, 2006 Share Posted June 24, 2006 I don't know how far you want to travel but I know of one here in CT. It's out in stafford. It's a manual shortbed 2 point whatever... not a 4.0 :cry: . The guy told me 2 or 3 hundred like a month ago. He said when you fill the gas tank over half way it leaks and sometimes when you start it it shoots oil from the motor. It's an 88. Link to comment Share on other sites More sharing options...
Eagle Posted June 24, 2006 Share Posted June 24, 2006 I don't know how far you want to travel but I know of one here in CT. It's out in stafford. It's a manual shortbed 2 point whatever... not a 4.0 :cry: . The guy told me 2 or 3 hundred like a month ago. He said when you fill the gas tank over half way it leaks and sometimes when you start it it shoots oil from the motor. It's an 88. That seems to be a common problem, and probably NOT the tank. Which I found out the hard way, when I first tried to fill the NEW tank I had just installed, and watched the gas flowing out around my feet from beneath the vehicle. The problem is often where the fuel hard lines go through the flange the mounts in the tank. One or both tubes gets loose and the gas flows out through the cracked seam. I'm going to try carefully wire brushing it with a bronze cleaning brush, then epoxy it and hope for the best. Link to comment Share on other sites More sharing options...
87manche Posted June 24, 2006 Share Posted June 24, 2006 epoxy likely isn't going to hold up the gasoline Eagle. Try getting one of those tank repair kits and using the sealant included wiht those. Epoxy hols up well to methonal/alcohol, but gas softens and eats it eventually. Link to comment Share on other sites More sharing options...
pingpong Posted June 25, 2006 Share Posted June 25, 2006 I have a brand new Long bed tank in my garage I will be happy to sel someone ;) Also I have said it before.. for the right price some one can buy Pong :nanner: Link to comment Share on other sites More sharing options...
87manche Posted June 25, 2006 Share Posted June 25, 2006 you wouldn't happen to have a LWB gas tank skid would ya? I know someone said they had one a while back. That's about the only piece of armor I'm missing. Link to comment Share on other sites More sharing options...
pingpong Posted June 26, 2006 Share Posted June 26, 2006 No mine was beyond repair or even useable when we took my rig apart. It was totally caved in to the point that my gas tank would only hold 14 gallons :eek: Link to comment Share on other sites More sharing options...
