Everything posted by xmeatbagx
Thanks slug
She's an 89 if that matters. What's the code for this blue?
So I had this grille hanging on the wall in my den for awhile and had the idea a few days ago to make a headboard for my bed with it. Today I was bored and none of my other projects got me excited enough to do with a hangover so here it is. Queen size bed headboard. Still needs some molding and stain but you get the idea.
-Shift knob for column shift automatic -Dark blue bench seat belts -Dark blue or black 4wd shifter plastic surround without transmission section -Rear bumper Truck specs: 1989, 4.0L, Swb, 2wd converting to 4wd
Hornbrod, it looks like the drivers side is being pulled toward the ground making the body look like it's leaning. Just the body though not the axle.
Does it matter if the truck is my DD?
My truck has around 3 inches of lift (I think) and the front end leans to the drivers side. The coil springs on both sides are fine and I don't see anything wrong in the back of the truck. The lean is more in the front than the rear. The track bar is stock, could that be why it leans? If I get an adjustable one do I have to know my lift height exactly? What's a good brand? Thanks for the help.
So I got all these white spots all over my truck. I'm thinking it's the clear coat getting crappy. Is there any way to get rid of the spots without screwing up my paint?
thank you
I'm swapping my rims and want to change my lug nuts. I was wondering if these would work with the steel 5 dimpled spoked rims off a 95 Cherokee. http://www.quadratec.com/products/92806_100x_pg.
Does anyone use Rusty's fixed upper and lower control arms? The bushings are shot in my stock arms and was thinking about picking them up. Tubular arms look pretty sweet. Any benefit to having a bend in the lower arms? I have around 3 inches of lift if that makes a difference.
thanks for the info guys
I have a 89 4.0 auto 2wd and want to convert to 4wd. I scored a front axle from work out of a 96 Cherokee with none of that vacuum crap. We have a 90 Cherokee that's 4wd auto at work, if it's non vacuum can I slap that in my Comanche. From what I understand converting to 4wd is all bolt in in my truck right? No changing wire harness right? Front axle Tranny w/ t-case Driveshafts Is it that basic or is there something I'm overlooking? Thanks
I have a 1989 comanche with a 94 cherokee 4.0. The intake and throttle body are off a late model 4.0. When I'm speeding up normaly between 35 and 45 the rpms cut out and the truck spudders sometimes stalling out. Also when I stop at a light or stop sign it idles low and sometimes stalls. So far all i've tried tried was changing the fuel filter. I've got no clue what it could be. I'm hoping it's something cheap. Thanks
I need a black or dark blue cloth bench. Doubt i'll find them but aluminum diamond plate bed rails also.
Anyone know of any junkyards in CT or southern MA that have comanches?
Mine should drop soon from turning 25. For now I pay $66 a month. I have glass and vandalism with it. (i've angered a few folks over the years)
I'm looking for a bench seat either black or dark blue, preferably not vynal. thanks for looking
dang it
Anyone around northern CT or Southern MA have a Blue or Black cloth bench seat? The truck I bought has buckets that work fine but I need a bench. The buckets in the truck look like he cut the bench seat track off and mounted bucket tracks on the floor brackets. Thanks Sean
Not sure if this is the right spot to post this but... http://www.jeeprally.org/ Sept.15 2012 hope to see some manches there
I've seen a couple things about updates for the brakes. I was wondering what is the best upgrade. What are the benefits? How bad is it to do? Any info is good info. Thanks I've got a 89 2wd auto with a 94 cherokee 4.0 and a late model intake and throttle body. Just bought the truck yesterday.
$2800 is my max. As far a traveling, I think I can use a dealer plate from work to drive it home but I would like to stay in or just outside of CT. I never should have sold my last two manches :wall:
My wife and I are having our first baby in about a month so I had to sell my Dodge with the expensive payments. Now I'm looking to go back to a Comanche. 4wd, auto, 4.0L prefered. Let me know what you got.
