thejum57 Posted October 16, 2008 Share Posted October 16, 2008 My 86 Comanche has dripping fluid on the driver's side mat. The slave cylinder for the clutch was REALLY low, NOT empty. I filled it, but it needs to be replaced. Can anyone whoe's done R&R give me some guidence? It "looks" like a "simple" job, but we all know how that works. Thanx!! Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted October 16, 2008 Share Posted October 16, 2008 My 86 Comanche has dripping fluid on the driver's side mat. The slave cylinder for the clutch was REALLY low, NOT empty. I filled it, but it needs to be replaced. Can anyone whoe's done R&R give me some guidence? It "looks" like a "simple" job, but we all know how that works. Thanx!! That'll be the master. Ive never attempted one but the general consensus is its a pain and if you're going to do the master, do the slave in the Trans too. If one goes, the other one is sure to follow. Hey from another cross-boarded IFSJA member too Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 16, 2008 Share Posted October 16, 2008 Try typing "slave" in the search button and be sure to click search all terms... like this, then read through them and should get you an idea... Image Not Found Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 16, 2008 Share Posted October 16, 2008 That should be stickied! :agree: Link to comment Share on other sites More sharing options...
Pete M Posted October 16, 2008 Share Posted October 16, 2008 If it's dripping anywhere on the fuse box, clean it up immediately! Brake fluid will destroy the fuse box. :( Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 16, 2008 Share Posted October 16, 2008 :agree: Ask $500MJ about what happens if you don't :thumbsup: Link to comment Share on other sites More sharing options...
FxRacing282 Posted October 16, 2008 Share Posted October 16, 2008 its fairly easy. undo the hose or line the connects to it from inside the engine housing along with the resivoir. then disconnect the two bolts or however many it is from the fire wall, then disocnnect it from the pedal. put new one it. probabally gonna have to flush from the slave FYI. be carefull with the fittings. i went to change my slave and the fitting was seized and nothing would take it off. so i figured oh no ill spend $3 and get a new line. well the other side was gnarly too. pb blast it! it works i swear. bleed it like you would a caliper but the more you bleed it the better the pedal will feel. make sure you bleed it until the pedal goes ALL THE WAY BACK UP. or else youll find yourself grinding gears Link to comment Share on other sites More sharing options...
DansGreyMj Posted October 16, 2008 Share Posted October 16, 2008 Its very easy, way easier than i expected. It only took me and my dad 20 minutes total, that includes bleeding the system. Link to comment Share on other sites More sharing options...
thejum57 Posted October 17, 2008 Author Share Posted October 17, 2008 I cleaned up the fuse box as well as I could & stuck a plastic coffee "can" lid upsidedown under where it's leaking. I'll have to empty that every time I drive it....I CAN'T get a new cylinder for another week.....0 $$$ !!!!! Does the fluid short out the box or is it the carosive in the fluid? Link to comment Share on other sites More sharing options...
Pete M Posted October 17, 2008 Share Posted October 17, 2008 That's actually kinda dangerous to drive that way. You could lose your clutch completely at any time if the leak gets worse. :( Brake fluid softens the plastic (causing it to sorta "melt" and become very brittle) and accelerates corrosion in the metals. Link to comment Share on other sites More sharing options...
thejum57 Posted October 18, 2008 Author Share Posted October 18, 2008 I tried to wipe it down with some diluted Simple Green, I hope that's enough. It's really hard to get it real clean. Maybe I should go looking for another box....just in case? Link to comment Share on other sites More sharing options...
Eagle Posted October 18, 2008 Share Posted October 18, 2008 I cleaned up the fuse box as well as I could & stuck a plastic coffee "can" lid upsidedown under where it's leaking. I'll have to empty that every time I drive it....I CAN'T get a new cylinder for another week.....0 $$$ !!!!! Does the fluid short out the box or is it the carosive in the fluid? Both But (as usual) I'm confused. Your title said "slave" cylinder, but it's the master cylinder that trashes fuse panels. What are you having problems with, the master, the slave, or both? Link to comment Share on other sites More sharing options...
thejum57 Posted October 18, 2008 Author Share Posted October 18, 2008 My bad on termanolagy, it is the cylinder on the fire wall. I'm guessing by feedback here, I had better check the "slave cylinder" also. I'm a newbie with Comanche's....I'm an IFSJA "crossover"...still own the FSJ Link to comment Share on other sites More sharing options...
Pete M Posted October 18, 2008 Share Posted October 18, 2008 Master cylinder is on the firewall Slave cylinder is in the bellhousing (or on the side of the bellhousing in some instances) Link to comment Share on other sites More sharing options...
thejum57 Posted October 18, 2008 Author Share Posted October 18, 2008 Can I unscrew the 4 screws holding the fuse box to the firewall and carefully pull it out a little so I can clean it up better? I really don't need it melting down on me. Link to comment Share on other sites More sharing options...
Wildman Posted October 19, 2008 Share Posted October 19, 2008 There should be 2 screws holding the fuse box to the inside fire wall, and one "bolt" from the engine compartment, thru the connector into the back of the fuse box, IIRC it takes a 1/4" drive socket. I would be better to remove the fuse box and inspect it for "hidden" damage. Link to comment Share on other sites More sharing options...
thejum57 Posted October 19, 2008 Author Share Posted October 19, 2008 This afternoon when I started it to go home from work, the "battery" light was glowing. The more gas I gave it, it glowed brighter, and got dimmer when I let off. Could this be from the brake fluid dripping on the fuse box? It was really only dripping 2-3 days, about 1/2 of the volume of the cylinder was gone. Or maybe another problem......altenator??? :headpop: Link to comment Share on other sites More sharing options...
Wildman Posted October 19, 2008 Share Posted October 19, 2008 That would be from your alternator or voltage regulator. The idiot light show when the battery is not being charged, and it gets brighter as you use more voltage, or taking more drain off the battery. If the light remains on, your alternator is not charging, and your actually running the truck off the battery, that is until the battery goes dead. So......if your home.....don't drive it, you'll brake down some where and be pushing the truck home :eek: A quick check is to start the truck, and pull the positive connection off the battery post, if the truck died, it's your alternator. Link to comment Share on other sites More sharing options...
FxRacing282 Posted October 19, 2008 Share Posted October 19, 2008 or to save time just take a multimeter, put it on 20V in DC power and black on black and red on red. it should be 14-16V. if its less then you either have, A) Bad ground from battery- engine,fender, frame ect B) Bad alternator. if its a bad alternator get one with a lifetime warranty and nothing less. put the receipt with your registration so when it breaks in 3 years you go back and get a new one and the receipt is right there. C) Bad battery, could be a dead cell or something lame like that. Link to comment Share on other sites More sharing options...
thejum57 Posted October 21, 2008 Author Share Posted October 21, 2008 I pulled the fuse box away from the firewall inside the truck. It has a pretty good amount of brake fluid in it. Is there anything I can spray in there to clean it up??? I can't get into the back part , all the wires can't be individually cleaned. Some pics............... Is this some kind of electrical greese that should be there???? Pleas say yes?!?!?!??! It doesn't "look" like the brake fluid seeped in? Link to comment Share on other sites More sharing options...
Wildman Posted October 21, 2008 Share Posted October 21, 2008 Yea, you can clean it with some "Contact Cleaner" The grease should be in there.......it's "Die-elect Grease" Both of these items you can get at the auto parts store......like Advance. From your pictures......it don't look like the brake fluid from the master leaked on it too long, but don't wait too long to get it cleaned out. Link to comment Share on other sites More sharing options...
thejum57 Posted October 22, 2008 Author Share Posted October 22, 2008 I think it was only leaking about a week. when I pulled it from the firewall it was dripping liquid thiugh. I got a can of electronic component cleaner that says it's safe for plastics & quick drying. I started giving it some blasts today...the box is still hanging in the truck & you need lot's of ventalation, so I'm don't want to fill the cab with fumes. I'll be spraying the rest of the week & hope for the best. Of corse I still have to replace the master cylinder before I put the box back in place. Link to comment Share on other sites More sharing options...
Wildman Posted October 22, 2008 Share Posted October 22, 2008 That sounds like good news :D Yup, you caught it in time. The "electronic component cleaner" is just a fancy name for contact cleaner. You should only have to spray it once or twice, and I guest put some rags on the floor to catch the 'drippings' after that, any fluid that got into the circuit breaker box should be cleaned out. Yea, it would be a good idea to replace the master before you put the box back together...........and don't forget to add some die-electric grease to the back of the box before you reconnect it to the engine harness. That will keep any moister and corrosion out of the connector. Link to comment Share on other sites More sharing options...
