BookspanS Posted October 8, 2008 Share Posted October 8, 2008 Does anyone know where this plug could go? Haven't found anywhere for it to plug in to Link to comment Share on other sites More sharing options...
Mitch Posted October 8, 2008 Share Posted October 8, 2008 isnt there supposed to be a large vacuum thing where that plug is? Link to comment Share on other sites More sharing options...
BookspanS Posted October 8, 2008 Author Share Posted October 8, 2008 You talking about the canister? Link to comment Share on other sites More sharing options...
Eagle Posted October 8, 2008 Share Posted October 8, 2008 Under-hood convenience light? Link to comment Share on other sites More sharing options...
Mitch Posted October 8, 2008 Share Posted October 8, 2008 Computer? Link to comment Share on other sites More sharing options...
BookspanS Posted October 8, 2008 Author Share Posted October 8, 2008 Under-hood convenience light? That is plugged in Link to comment Share on other sites More sharing options...
BookspanS Posted October 8, 2008 Author Share Posted October 8, 2008 Computer? Can't find anywhere for it to go... Link to comment Share on other sites More sharing options...
Mitch Posted October 8, 2008 Share Posted October 8, 2008 I swear your missing a part in that picture, but I don't know what it is. I think its all the vacuum stuff, and that might run the motor - but I have no idea. Link to comment Share on other sites More sharing options...
BookspanS Posted October 8, 2008 Author Share Posted October 8, 2008 Tell me what to take pics of and I will do.....the second i am told to cause i want to know where it goes cause it has me worried right now Link to comment Share on other sites More sharing options...
Mitch Posted October 8, 2008 Share Posted October 8, 2008 does your truck run? That is the 2.5L that was on the truck you got from the junk yard? I would say that you probably can't have to many pictures at this point. Link to comment Share on other sites More sharing options...
BookspanS Posted October 8, 2008 Author Share Posted October 8, 2008 That is the 2.5 in my blue DD. Gotta finialize the storage building for the one fron the JY Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 8, 2008 Share Posted October 8, 2008 Look like the IOD connector in mine. But I don't know if the Renix era had these........ Explanation: The "Ignition Off Draw" connector and fuse (IOD). The term ignition-off draw identifies a normal condition where power is being drained from the battery with the ignition switch in the Off position. The IOD connector feeds the memory and sleep mode functions for some of the electronic modules in the vehicle as well as various other accessories that require battery current when the ignition switch is in the Off position, including the clock. The IOD connector can be used by the vehicle owner as a convenient means of reducing battery depletion when a vehicle is to be stored for periods not to exceed about twenty days (short-term storage). Simply disconnect the IOD connector from the JB receptacle slot # 15 and place it in slot # 11 (see diagram above). However, it must be remembered that disconnecting the IOD connector will not eliminate IOD, but only reduce this normal condition. When a vehicle will not be used for more than twenty days, but less than thirty days, remove the IOD fuse from the Power Distribution Center (PDC). Link to comment Share on other sites More sharing options...
BookspanS Posted October 8, 2008 Author Share Posted October 8, 2008 ummmmmm....with my VERY little knowledge about what was just said :oops: ....maybe that could explain why my radio has unknowingly reset itself sometimes?? Link to comment Share on other sites More sharing options...
DirtyComanche Posted October 9, 2008 Share Posted October 9, 2008 I've seen no such animal on a renix era 4.0L, but I could not tell you about a 2.5L. Link to comment Share on other sites More sharing options...
manche Posted October 9, 2008 Share Posted October 9, 2008 i think its the charcoal canister for the evap is missing Link to comment Share on other sites More sharing options...
BookspanS Posted October 9, 2008 Author Share Posted October 9, 2008 You mean this thing? BTW its there and the plug is hanging right above it if you can see it Link to comment Share on other sites More sharing options...
manche Posted October 9, 2008 Share Posted October 9, 2008 ill run out to my truck and see its the under hood light adapter Link to comment Share on other sites More sharing options...
manche Posted October 9, 2008 Share Posted October 9, 2008 yep it is :yes: do you have a lamp? Link to comment Share on other sites More sharing options...
mfpdm Posted October 9, 2008 Share Posted October 9, 2008 Well I always love a challenge. Just spent about 40 minutes looking for this. Found it on my 86 2wd 2.5 but not on the harness for the 88 2wd 2.5. Looked in the many resources that I have and think I came up with it. It may be the 4wd indicator light switch connector. Which would explain why it is not connected. Or it may be one of the Californa emission things. I'm thinking the 4wd indicator. If someone with a 86 4wd 2.5 can look at theirs, they might be able to confirm or dis-spell this. :cheers: Link to comment Share on other sites More sharing options...
jteckmann Posted October 9, 2008 Share Posted October 9, 2008 Well I always love a challenge. Just spent about 40 minutes looking for this. Found it on my 86 2wd 2.5 but not on the harness for the 88 2wd 2.5. Looked in the many resources that I have and think I came up with it. It may be the 4wd indicator light switch connector. Which would explain why it is not connected. Or it may be one of the Californa emission things. I'm thinking the 4wd indicator. If someone with a 86 4wd 2.5 can look at theirs, they might be able to confirm or dis-spell this. :cheers: I don't think it's the indicator light. I have an '86 2.5, 4x4 - that connector is hanging blank on my truck too, and my indicator light works. What colorts are the wires going to the connector? I can't really make them out in the pictures, Looking at my wiring diagram .... my guess is it's un-used spot for the A/C clutch relay. or possibly for the EGR solenoid? Link to comment Share on other sites More sharing options...
mfpdm Posted October 9, 2008 Share Posted October 9, 2008 I don't think it's the indicator light. I have an '86 2.5, 4x4 - that connector is hanging blank on my truck too, and my indicator light works. What colorts are the wires going to the connector? I can't really make them out in the pictures, Looking at my wiring diagram .... my guess is it's un-used spot for the A/C clutch relay. or possibly for the EGR solenoid? Well that eliminates the 4wd light. Mine has AC so I don't think it's that. I saw the EGR solenoid but couldn't narrow down the wire colors. So I think it's Californa emission stuff. Either way, it's not needed as several now have said that it's just hanging there. :cheers: Link to comment Share on other sites More sharing options...
james750 Posted October 10, 2008 Share Posted October 10, 2008 You mean this thing? BTW its there and the plug is hanging right above it if you can see it Nope, thats a vacuum bottle. Link to comment Share on other sites More sharing options...
Akula69 Posted October 10, 2008 Share Posted October 10, 2008 If you are referring to the plug resting on the red wires in the picture above, the electrical troubleshooting book says its the A/C Diode Module, appears of the 4L engine, and should be taped to the wiring harness by the left hood hinge. Link to comment Share on other sites More sharing options...
mfpdm Posted October 10, 2008 Share Posted October 10, 2008 So if you have AC, should this be plugged into something? I have AC and it's just laying there as well. Link to comment Share on other sites More sharing options...
BookspanS Posted October 10, 2008 Author Share Posted October 10, 2008 A/C...Never heard of such a thing... :teehee: Link to comment Share on other sites More sharing options...
