Well in the efforts of trying to get something done to the Wild build, I ran into another road block. The ever so common rusted out window regulator coil.
So with all the searching on this subject, my options are, new to the tune of $150 a piece or JY XJ's.
I probably hit the JY's but once I get some decent one's, what can be done to prevent this from happening again?
I've thought of a couple of ideas like a water inhibitor grease or something of the kind. Also I think I'll replace the tube at the end with a larger one to allow better drainage and route the tube to a fixed hole.
Anyone tried anything different that could help?
:cheers:
I haven't disassembled a door to try it yet, but after considerable research the parts guru at my dealership and I concluded that -- although it isn't listed for manual windows -- it appears that the regulator cable (a.k.a. "snake") for the power windows can also be used in the manual assembly. I have two of them here, just haven't gotten around to trying it out yet.
BLHTAZ, got any comments on whether this looks like a possibility? Is the power window "snake" still available as a replacement part?
Wait one! I see a pigtail. Those ARE the electric window regulators. The "snake" part should be available as a separate part, unless it has been discontinued.
a good coating of wd 40 should keep em from rusting for a good while.
Yeah -- at LEAST 15 or 20 minutes.
You were joking, right? WD-40 as a long-term rust preventive? Get serious. WD-40 is nothing but kerosene with a bit of paraffin mixed into it.
:rotf: good point. wheel bearing grease? thatd do the trick
I thought in my search I ran across a thread saying the "snake" (I like that term better than coil :D ) was an availible part but I thought it was for the manual ones. I may have mis-read it. Would be good to know if it is and what kind of price. How bout it TAZ, oh parts Guru. :bowdown:
:popcorn:
The Jeep OEM regulators are junk, I think designed to fail after about three years. I used these regulators from Electric Life when I installed power windows. The "snake" is stainless, and they are about twice as fast as the OEM regulators. A bit cheaper too, and NOT made in China. I think Quadratech sells them separately also.
Will they accept the wiring from the XJ door harnesses?
Nice. Might be worth it but trying to cut expenses on this build. Thanks for the link. Will consider if all else fails.
:cheers:
The "snakes" are available,but are only available
for xj front electric windows.
Retail for $57 @.
Would they work on manual windows?Meh.
I tried some regulator cables from newer vehicles
dug out of warranty retention.(Yea,they still use them.)
But every one I found was larger diameter.
All from newer vehicles though.
Ended up buying regulators from partstrain.com
about $100 @ I think I paid.
