DirtyComanche Posted September 13, 2008 Share Posted September 13, 2008 I'll admit I know nothing. Well, close to it. I never cared enough to learn about lights. But I know stock jeep lights suck. Anyways, I read a review on these http://www.rocky-road.com/xjipfH4.html They seemed pretty positive. $120ish is cheap. I'd just go with the housings and the 55/60W bulbs. Nothing crazy. I think. But thoughts, opinons, etc? Link to comment Share on other sites More sharing options...
Pete M Posted September 13, 2008 Share Posted September 13, 2008 My biggest issue with the stock Jeep headlights is the insane length of wire that the electricity has to travel around the engine bay. Wire length and corrosion are the enemy. If I drove my trucks with any sort of regularity, I'd wire the headlights to use the factory switch to power a new relay that brings the electrons directly from the battery (with a fuse of course). I know it'd make a world of difference in my trucks. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted September 13, 2008 Share Posted September 13, 2008 I run the Autopals and love them. They are like 1/2 the price of the IPF's, or Cibies. Here is my review on them; http://greatlakesxj.activeboard.com/ind ... D=15250394 Their is info in my review as to where to get them. Link to comment Share on other sites More sharing options...
DirtyComanche Posted September 13, 2008 Author Share Posted September 13, 2008 How long have you had the autopals? Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted September 13, 2008 Share Posted September 13, 2008 How long have you had the autopals? Wife's XJ since January and she drives it daily (at night) so they get used every day. My XJ I've had them for over a year now. It doesn't get driven as much, but they've held up in both rigs thus far. I'm sold on them.... Link to comment Share on other sites More sharing options...
DirtyComanche Posted September 13, 2008 Author Share Posted September 13, 2008 Cool. I'll probably order them unless anybody else has a better idea. And Pete, my headlight wiring is messed up. Somebody added daytime running lights without using any factory parts or an aftermarket module (I'm still not entirely sure how they did that, I didn't unravel it all) and as a result I think I'll have to pull a few wires before things are peachy anyways. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted September 14, 2008 Share Posted September 14, 2008 I don't know the MFG of mine, but I got them off EBay and love them. they are just like the auto-pal's. I use the sylvania silverstar bulb in mine when the supplied ones crapped out. they got even better!!! CW. Link to comment Share on other sites More sharing options...
Sir Sam Posted September 14, 2008 Share Posted September 14, 2008 I had H4 housing in my silver freedom with some 85W/105W bulbs from JC whitney. They put out alot of bright light and were tons better than stock, but the dispersion pattern was a little wierd. I now have silverstar sealed beams, not as much light output but in much better places, overall I would say they are better than the H4s I had. And a headlight harness should make a huge difference too. Link to comment Share on other sites More sharing options...
deziped Posted September 14, 2008 Share Posted September 14, 2008 Running autopals (80/100watt) for about a year on DD. Run Hi & Lo relays directly off distribution block on 10 ga wire, using R side OEM light connector only to trip relays. Puts a lot of light on the road. What a diff. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 14, 2008 Share Posted September 14, 2008 just put Sylvania Performance sealed beam headlights in my truck...they're $20 each, and come out with white light rather than yellow-ish. stock wiring, and still a WORLD of improvement Link to comment Share on other sites More sharing options...
aemsee Posted September 14, 2008 Share Posted September 14, 2008 Most of the problems I've seen with the H4 set ups is lack of refinement in the reflector causing poor light pattern. I definitly need to do something as well. Of course since the 'manche isn't a DD I never think about it until it is dark while I'm driving it and realize I can't see $#!&. Link to comment Share on other sites More sharing options...
BLHTAZ Posted September 14, 2008 Share Posted September 14, 2008 just put Sylvania Performance sealed beam headlights in my truck...they're $20 each, and come out with white light rather than yellow-ish. stock wiring, and still a WORLD of improvementI did the same thing and have been very happy with them Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted September 14, 2008 Share Posted September 14, 2008 Most of the problems I've seen with the H4 set ups is lack of refinement in the reflector causing poor light pattern. I definitly need to do something as well. Of course since the 'manche isn't a DD I never think about it until it is dark while I'm driving it and realize I can't see $#!&. I have another set on the TJ and those are like your refering to. the light is great, its like a flood, but seems to go everywhere. In the rain its like you don't have any lights. CW Link to comment Share on other sites More sharing options...
highlandjeeper Posted September 14, 2008 Share Posted September 14, 2008 I run GE Nighthawks in all my vehicles. I have been in vehicles that had Silverstars and thought the light was kind of blue. I am very happy with Nighthawk as they are bright white and the dipursion is very smooth. They are also cheaper than Silverstars. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 14, 2008 Share Posted September 14, 2008 I highly recommend installing an upgraded wiring harness for the more power hungry H4s. I used this one from APC; has the relays built in and the wiring fits the MJ perfectly, and easy to install. Your new headlamps will burn brighter and your stock headlight switch and wiring will not. :eek: http://tinyurl.com/5puqoj Link to comment Share on other sites More sharing options...
