Luvtohunt Posted August 10, 2008 Share Posted August 10, 2008 Need to change the Serpentine belt on my 88 MJ with the inline six. Any advice on how to? Thanks again for your help. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted August 10, 2008 Share Posted August 10, 2008 http://www.greatlakesxj.com/tech/serpbelt.html Link to comment Share on other sites More sharing options...
Pete M Posted August 11, 2008 Share Posted August 11, 2008 Make sure you get all the bolts. It makes the job much harder if you miss one. :roll: I know. Also, PB blaster (or other rust penetrant) is your friend. :D Link to comment Share on other sites More sharing options...
PIKE Posted August 11, 2008 Share Posted August 11, 2008 One of these works pretty well too. http://www.napaonline.com/MasterPages/N ... sion+Gauge Used belt is 140-160 lbs-f New belt is 180-200 lbs-f :cheers: Link to comment Share on other sites More sharing options...
BLHTAZ Posted August 11, 2008 Share Posted August 11, 2008 Make sure you get all the bolts. It makes the job much harder if you miss one. :roll: I know.X2 on that. I broke a tensioner bolt because I forgot about the bolt on the lower rear of the PS pump :roll: . The PS pump is the tensioner on your truck and there are 3 bolt that must be loosened to get it to move...two on the front and one on the lower rear that is easier to get to from under the truck most of the time ;) . One of these works pretty well too. http://www.napaonline.com/MasterPages/N ... sion+Gauge Used belt is 140-160 lbs-f New belt is 180-200 lbs-f I have never seen one of those before... I have always used the "twist" method. Tighten it until the resistance allows only approximately a 1/4 turn worth of play in the belt. Link to comment Share on other sites More sharing options...
PIKE Posted August 11, 2008 Share Posted August 11, 2008 I have never seen one of those before... I have always used the "twist" method. Tighten it until the resistance allows only approximately a 1/4 turn worth of play in the belt. For years I did that too. But I was always worried that I would have the belt too tight and ruin a bearnig, so I would have it too loose and I would get a squeel. It takes all the guess work out of it for me, and its very easy to use. Dave Link to comment Share on other sites More sharing options...
mknherhappy Posted August 11, 2008 Share Posted August 11, 2008 http://www.greatlakesxj.com/tech/serpbelt.html If you do not have air conditioning, does it make any difference? Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 11, 2008 Share Posted August 11, 2008 http://www.greatlakesxj.com/tech/serpbelt.html If you do not have air conditioning, does it make any difference? On the 4 cylinder, if you don't have A/C, you get the belt specifically for your engine w/o A/C, and vice-versa. On the I6, it's the same belt for w. A/C and w/o A/C. The sixes w/o A/C have an idler pulley in place of the compressor. Link to comment Share on other sites More sharing options...
