lower jeep
Everything posted by lower jeep
  1. ok so i havent updated lately, i got the 5 speed aisian transmission in :D , it wasnt that bad of a swap to do :cheers: , I'm starting to build a stroker motor for the truck found out the Nova leafs won't fit. :headpop:
  2. I'm getting readdy to build a 4.7 stroker motor :D and i was wondering what is the best way to clean the piston rods can i sandblast them or just soak them in some degreaser? also where can i get a complete gasket set cheap? i called around and found the cheapest Fel Pro gaskets for like $103 for the upper and $33 for the lower parts of the motor, is this a good price for these? Thanks Lower Jeep
  3. for tail light shavers just get some metal and start at the end by the tail gate and bend it around while welding it in and for a roll pan i used a 87-96 dakota roll pan had to cut i think 1 1/2" form each end and 3/8" out of the flange that bolts to the bed and the outside of the pan
  4. the one on the left looks like a automatic computer for the tranny the tranny will not shift out of 1st gear with out this and the second one looks like a cruise control unit i think.
  5. please don't put foam in the bed side, like they said make friends with some one that has a welder because i had a dodge shadow that some one put foam in a rust hole before i got it and had a new paint job on it and with in 3 months it made the hole even bigger. foam is not a good choice for any thing that is going to be exposed to the elements even after drying the foam out and welding new metal in the rust started back before i got rid of the car.
  6. a set of 2000 wrangler rims fit on a mj?
  7. that thing is sweet
  8. o the rear is going lower than that even :D
  9. so i got the bead just about done execpt i got a few welds to grind down , I'm lowering the rear end of the truck again, but this time I'm using a set of leafs from a bud that he had on a 70 Nova that were flatened out and putting a set of air shocks on it to have a adjustable suspension in the back , ill be ordering the air shocks tomarrow ill get some pics up in the next few weeks and days for the work :D
  10. if you look under mj projects theres a few pics of mine as of last year truck looks pretty much the same ill get some pics up when i get the new leafs in and the air shocks next week
  11. thanks all I'm looking for is the back and thanks for the help
  12. what kind of truck will the rear air shocks work on a mj? i was looking at 84-88 toyota shocks but iu don't know if they would work. ps they don't have to be as long as a normal shocks because the truck is lowered about 4 inches thanks
  13. my parents had a 1993 ford taurus wagon in the last year that we had it it was in the shop for 8 out of the 12 months in the year head gaskets blew at 53,000 miles , when they first bought it the rear window would not roll down, they fixed it but then when we got it back the front seat had a sqeack in it and the sale rep. told us face to face that we bought a ford and not a mercedes tehy ordered in a new car with the same color interior and swapped the seat out and put the bad seat in the new car and sold it that way
  14. sweet game http://www.planet4x4.net/4x4Country/register.php?REF=2828
  15. is this the book that you guys are talking about? http://www.amazon.com/Jeep-Performance-Handbook-Motorbooks-Workshop/dp/076030470X/ref=pd_bxgy_b_text_b/103-5304937-5054241?ie=UTF8&qid=1187974611&sr=8-12
  16. i have a dynomax supertrubo muffler on my truck in the factory location wit a trun down after it and sounds very nice. it is deeper tone than a glasspac and not to loud :D
  17. i am not looking for a motor that is NOT going to see any wheeling because its going in my lowered mj i want to rebuild this new engine that i got for cheap the guy said it ran but hes puting in a 4.3 out of a chevy, i want to rebuild it and make more power for the motor and make it sound beefy :D
  18. i think that quadratek make them i think
  19. so here are the cams i am looking at getting any advise would be helpfull on the desision Product Line: Crane PowerMax Camshafts Part Type: Camshafts Cam Style: Mechanical flat tappet Basic Operating RPM Range: 2,500-6,000 Intake Duration at 050 inch Lift: 228 Exhaust Duration at 050 inch Lift: 238 Duration at 050 inch Lift: 228 int./238 exh. Advertised Intake Duration: 264 Advertised Exhaust Duration: 274 Advertised Duration: 264 int./274 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.533 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.555 in. Valve Lift with Factory Rocker Arm Ratio: 0.533 int./0.555 exh. lift Lobe Separation (degrees): 112 Intake Valve Lash: 0.028 in. Exhaust Valve Lash: 0.030 in. Product Line: Crane Truck Power Camshafts Part Type: Camshafts Cam Style: Hydraulic flat tappet Basic Operating RPM Range: 1,500-4,500 Intake Duration at 050 inch Lift: 204 Exhaust Duration at 050 inch Lift: 216 Duration at 050 inch Lift: 204 int./216 exh. Advertised Intake Duration: 260 Advertised Exhaust Duration: 272 Advertised Duration: 260 int./272 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.456 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.484 in. Valve Lift with Factory Rocker Arm Ratio: 0.456 int./0.484 exh. lift Lobe Separation (degrees): 112 Intake Valve Lash: 0.000 in. Exhaust Valve Lash: 0.000 in. Computer Controlled Compatible: No Grind Number: H-260-2
  20. ok so i want some thing that would give me the best power thru the entire rpm range but mostly in the mid range, but i am still confused about it some but that explained it better than any thing else
  21. so I'm picking up a 5 speed tranny for the truck on sat evening its mot the peugot but the betterone? i think
  22. i would say at least half of the bump stop or remove it all together
  23. lower jeep
    jeep jt
    x3 that thing is very nice, wonder what it would look like lowered on big wheels :brows: just joking i look nice how it is :D
  24. i just stuck a cone filter for autozone on the factory pipe and got a valve cover air filter and put it on the other line for the brether
  25. am i crazy or is some one else wanting to lower a jeep also!!!!!!!! :eek: :D i bought a set of rear leaf brackets form a junk yard and then a set of 4" drop blocks to add to that, i would reconmend cutting the bump stops down it you do the same as me. i now am working on getting a c-notch to weld in and a mono leaf or 4 link rear suspension with air ride on to it
