CEThomas
Everything posted by CEThomas
  1. They bolted right up. They only thing I see different is about $5 :nuts:
  2. CEThomas
    Auto Zone
    I used to buy NAPA all the time, then they started to cheep some things up to keep the price down. I put 2 NAPA ball joints in my truck a few years ago and they both were gonein under a year. NAPA gave me new ones and they lasted just over 2 yrs :cry:
  3. CEThomas
    Auto Zone
    Wth is a "circle parts box"? Circle Parts is Dana'a discount brand, a lot of it is not made in the USA :cry:
  4. Also you can check out what is going on ComancheClub while on the trail :D :cheers: :D
  5. CEThomas
    Auto Zone
    I got a surprise over the weekend. I went to auto zone and got a lower ball joint (Duralast) for my Capri and he gave me a "circle parts" box :roll: When I went to install it I seen Dana and MADE in the USA on the box :eek:
  6. Well we replaced the front DS in the MJ with a 92 DS over the weekend. We found out the 89 calipers, pads and rotors would not fit on the 89 axle :roll: Now I just looked up what a new tie-rod end would cost and see that the tie-rod ends for the 89 and 92 have different part numbers and a big price difference :eek: Anyone know what the difference is??? Will I need to swap out the 92 tie-rods to use on the 92 axle/knuckles???
  7. Take some photos of the axle so we can see what is wrong. I bet the disco is bad and that is a quick cheep fix.
  8. I have seen a all white 2wd once 8) I put it on the list with all the other 2wd Jeeps I have seen, WHY :nuts:
  9. When I got the DS at the local JY, they had it for $30 and it was missing the front cover and right side shaft. It had no fluid in it and a little surface rust on the gears but looked OK. Something must have been up with the bearings that I could not see :oops:
  10. Thanks, For the price and work to replace the bearings, it's going to be replaced with one froom the JY or we will part out my XJ :roll:
  11. Thanks, Have the tools just needed the tork specs and backlash, but just checked and new bearings will run about as much as the $95 D-30 from the JY :nuts:
  12. Everything fine inside, just the pinion bearing seized big time :cry: Any body know the specs to replace the pinion and diff bearings :roll:
  13. What problems are D-30's noted for???? We took the MJ for the first test drive yesterday and had problems :cry: Went for a 5 mile drive first then a 10 mile drive to the in-laws for x-mass. Had some strange vibs when it would go into OD or you let up on the gas :roll: but everything else was fine 8) Made a stop at the father-in-law's house to pick up somethings to take to sister-in-laws, it set for about 40min., went out and it would not move. Acted like a brake had hung up :roll: poped it into 4 low to see if I could free it up and the t-case went pow :mad: think the vibes may have been the chain floping in the t-case :roll: Well we went to eat and came back to see what was wrong. Jacked up each wheel and each tire turned free. Took off both front and rear DS so we could move the MJ so father-in-law could get his car out and it would not move :nuts: we then found the front pinion seized :roll: The fluid level is up to the fill hole, so it did not leak out :nuts: going to get it towed home today so we can pull the cover off, but was just wondering if this is a common problem.
  14. Good god, let them drive and kill a few people :nuts: :nuts: You need to check into someplace and get some help :cheers: You are one sick person :D
  15. You may think it's redicules :nuts: but I ride motorcycles and the only think that is more scary then someone talking on a cell phone is a car full of teens driving and not watching what they are doing :roll:
  16. Yes Cerdit Card :D or any debit card with the Visa or MasterCard label ;) Talking to some of the others who got took to see what we have in common 8) I only use my debit card for gas, food and auto / jeep parts and a few hobby items. Several guys that got taken are from :Canadaflag: so it's making a short list fast :roll: and McDonalds and auto / jeep parts have moved to the top of the list :cry: Charles
  17. They got my debit card # and got funds out of my checking account. They also are using credit card #'s that they got, so they most likely got account info from some company I must have used my card at :cry:
  18. Anyone get a charge from TEMPLATEGLOBUS.COM on your CC acount or checking account???? I just received one on my checking account and from the looks or it some CC / debit card numbers were stolen from someone :mad: Now right at x-mass I have had to shut down my checking account :headpop:
  19. A lot of the stuff in Rangers and s-10 are thinwall and more show bar then roll bar. So you can just bolt it in. If it's a true roll bar will need to tie it into the frame and you can weld or bolt. Bolt being the better way to go.
  20. I wonder if it's this one :roll: http://comancheclub.com/forums/viewtopic.php?t=6547 Right area ;)
  21. I have things to do the next two nights, but will run over on Saturday morning if I get a chance. If not I will stop by on Monday :cheers:
  22. I am just 9 miles away from the JY and drive by all the time, if anyone wants me to pick them up so you can pick up over the weekend PM me and we can work something out.
  23. The mirors are OK, just where they placed them for a fat guy to see them :D
  24. I found this site a few years ago and get a kick out of reading it from time to time :cheers: http://128.83.80.200/taco/scarysteering9.html
  25. Going to give it a try :roll:
