91coMANche
Everything posted by 91coMANche
Is this a good deal?
91coMANche replied to 1990 Pioneer 4x4's topic in MJ Tech: Modification and Repairs
If anyone has another let me know! I keep going back and forth on the 44 idea! -
Brake Pads...What do you Recommend?
91coMANche replied to beepbeepmyredjeep's topic in MJ Tech: Modification and Repairs
Any American brand has been good for me. I believe Bendix is a especially good. -
Buy the tires and then find a small shop ( :USAflag: ) that keeps the money in the USA to install them. I always take my tires to one of the local used tire places to have them mounted and balanced. Also, 30X9.5X15 is right around 235/75-15 and will give you some other choices and fit on a stock ZJ.
U-Bolt Elimanator install
91coMANche replied to MiNi Beast's topic in MJ Tech: DIY Projects and Write-Ups
What is a ubolt eliminator? -
PowerTrax No slip In Dana 30 Opinions Experience
91coMANche replied to skidoo_j's topic in MJ Tech: Modification and Repairs
I found it impossible to turn with the Powertrax in the front axle. I wouldn't install another in the front. Not only was turning difficult but it would also understeer in rain and snow more easily because the front didn't want to turn under power. -
Would super sloppy wipers mean the wiper motor is going bad or the linkage? I can pick up the wipers and swing them back and forth before they hit a stop. I suspect that issue is the linkage. They are also kind of slow at times which I suspect is the motor. Would any XJ system fit? Could I get it from a 97+?
Headlights loose in new header panel?
91coMANche replied to 91coMANche's topic in MJ Tech: Modification and Repairs
I guess the tolerance on the header panel isn't appropriate. I guess I will source bigger adjuster snaps or get a MOPAR header panel. -
I think I need new tires
91coMANche replied to 86ComancheXNate's topic in MJ Tech: Modification and Repairs
If you stick with 235/75 15 you can get the Goodyear Wrangler Radial for really cheap new. I have them now and they are good tires for low traction times. $78 a tire new. http://www.walmart.com/ip/Goodyear-Wran ... al/4404150 Its the original "all-terrain" tread. -
Could someone post instructions on how to install new buckets and lights...perhaps I'm missing something. -
91coMANche posted a topic in MJ Tech: Modification and Repairs
Any reason why my headlights are loose in my new header panel? Its just a spring and the two adjustment screws right? I snapped the threaded inserts into the new header panel (before someone suggests that). -
The 97+ HO engines use a single temperature sensor that both tells the computer whether to be in open or closed loop and to feed the dash gauge. I have a 1998 4.0 (ridiculously amazing and I suggest the swap to everyone) and so I don't have a head with a hole pretapped for a temperature sensor for the gauge. I will drill and tap a thermostat housing and install my sensor in that.
Seems like "the pub" is the best place to post new pub tech
91coMANche replied to 91coMANche's topic in The Pub
Bud Coors Miller mmmmmmmmm -
The fuse is definitely clean and firmly planted in the fuse box?
Will do. So far it seems as if everyone is getting the standard carpet instead of the Essex. I have yet to find anyone that gets the "massbacking." When my 20 year old vinyl came out there was normal surface rust under it and as we all know the vinyl holds lots of moisture. So hopefully even though the cheapest carpet will have the woolen like backing, now it cam breath up through the carpet instead of just sit there.
There is nothing wrong with the stock port in the head if I was still running the weeny 190hp 1991 4.0 :D Lucky me is updating and upgrading to all my dream Jeep parts and one of them was an upgrade to a 98 ZJ 4.0. These did not use a sensor in the head. So where the hole was in the 91 head is just a cast-over on the 98 head. I am not sure what the 98 ZJ used to fire the temperature gauge but it didn't come from the head. I am pretty sure it would just use the main coolant temperature sensor. Anyway, are there any block drains except for the two on the exhaust side of the block?
I was just about to start drilling and tapping the thermostat housing when I realized that I could just as easily find a spot on the block thats already drilled and tapped. I know there are two coolant drains on the side of the block that is shared with the intake/exhaust. Are there any other drains on the block? I would get a reducer to fit the sensor into the hole. Are there any other drain ports that are away from the exhaust side? I am a little scared of running a wire down near the header.
I found a really good low miles one from an automatic so I am getting ready to swap that into my Jeep this week. Once that is complete I am going to try and rebuild the original unit. I will post back my results as soon as I can. Until then if anyone has pictures of YJ components that will help the process along.
