armybmbsqd
    Wisconsin Rapids, WI
armybmbsqd's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. :agree: Should have stayed in 'Bama mate. :cheers: Someone in 'Bama should have hired me and I would have moved back!!
  2. Put it in storage for the winter. :( It is in too good of shape to drive in the winter in Wisconsin. I don't need it turning into a rust bucket.
  3. KA9YJH, license is current but I have not been on the air for many years. I was active on 2meters but found too many "clicks" that would only talk to one of there own.
  4. My first Jeep was a '47 CJ2A that I bought when I was 14. 10 (or so) Jeeps later I have my 89 MJ and an 05 TJ. Jeeps that I have owned 47 CJ2A 78 J20 79 CJ5 72 Jeepster 85 CJ7 97 Grand Cherokee 89 Comanche 89 Cherokee 87 Cherokee 94 Cherokee 05 TJ I really would like to find another CJ2A or a M38 to rebuild. First I have to find a house with a large enough shop!!
  5. I have a rust free '89 w/4.7 stroker that is still available not too far from you.
  6. Had this But sold it for this
  7. I have a set of white gauges I bought on-line several years ago. They are the electro luminescent type, green - blue switchable. I don't think they are available anymore though.
  8. Thanks :D It was one of the easiest mods I've done. :banana:
  9. Mine is off an early 90's (I think) S10. It sits a little low but otherwise works OK.
  10. I cheated and am running a '99 style grill without changing the whole front end. The grill just snapped in place and has been there for a couple years now. I did put a zip tie on the bottom just in case.....
  11. Currently attending Wisconsin Indianhead Technical College for an associate degree in Industrial Automation, Controls and Networking. Will graduate in May. I am working on finishing my resume so I can get a real job :D
  12. In my 4.7 stroker I have HO head and intake on a Renix block. Being a stroker engine I wanted the most out of the performance gains. I have a bored out HO TB and Borla header. I used a HESCO TPS adapter. It's a little expensive but it makes the swap so much easier. The one thing you have to look out for is the HO block does not incorporate the knock sensor. I kept all of the rest of the Renix sensors except the EGR (HO does not use an EGR). I unplugged the harness at the control valve and have had no problems at all.
  13. The EGR on my 89 4.0 failed before I did the stroker swap. All I did was plug the vacuum line going to the EGR valve with a golf tee. I never had any problems after that.
  14. Thanks for the clarification. I'm not sure where I heard that but now I know it's not possible.
  15. I thought I remembered someone doing a heater core swap without discharging the AC. Anyone know if that's possible? I have already spent a ton of money getting my AC working and don't want to have to have it charged AGAIN.
