Ok so I changed out the diff cover gasket and when bolting the diff cover back on I must've not installed the load sensing brake adjustment set up, and it doesn't skid anymore🤷🏼♂️ guess that fixed it.
Also, replaced the O2 sensor. The old one was completely black when I took it out. It seems to run a little smoother now, not sure if that's my imagination though.
My throttle body measures 60mm. The TPS doesn't have letters on it, so I tested the middle wire and it read about 50.6/7 ohms. The value changed 0.1ohms when I shook the harness next to the valve cover.
Working on tip number 1, I found this:
Obviously it will need replaced. I looked up the part on Napa online and the replacement has an extra small cable on it which mine doesn't. Is it still okay to use?
https://www.napaonline.com/en/p/MPB781107
Just yesterday saw a black one with chrome trim in white center, Seattle WA. If you see this, nice truck! Looked clean. First one I've seen besides my own in about 6 months🥲
I guess check valve lash and if you have a feeler gauge check the clearance between the valve and the rod and compare it to the others. Also check clearance between piston and cylinder wall and make sure your piston ring gaps are correct.
Not sure what you mean about the MAP sensor. Whats the difference between renix and HO throttle bodies? Also don't know about the tps. Never changed it.
I am putting this in my diffs and using lubelocker style gaskets. Make sure the gasket surfaces are clean
https://www.amazon.com/gp/aw/d/B000IG5QPK?ref=ppx_pt2_mob_b_prod_image
