Everything posted by 70barracuda
definetly recommend it. I'm so close its actually painful. I really want to start it up but I have no spot for the o2 sensor and don't want to run it without incase it goes super lean or rich. Trying to find an exhaust shop that will do stainless and mandrel is tougher than I thought. Plus everyone wants to see the truck to give me a quote, which I get but not even a ball park amount. I'm not wasting my AAA calls shuttling it from shop to shop...
Intake is made! Nothing special about it, summit silicon and aluminum tube and a K&N filter. Sits right where the fresh air intake is behind the headlight. Driveshaft is also in. Stock one weighs about 25 pounds and the new one weighs in at about 12. Super nice quality and fast shipping. Still waiting on the shifter then off to the exhaust shop
So most LS's have a MAF which also has the intake temp sensor in that whole assembly. Holley uses MAP, and in turn has a separate IAT sensor. No ports are in the intake and I wanted it separate from the air intake tube so I found this nifty little egr block off plate that is threaded for a GM IAT used on another LS (I think gto?). Driveshaft and shifter should be here tomorrow and the only thing left is exhaust! Gotta find a place now and see if I can borrow my tow truck from work...
Bosch makes a great cheap tach. Just 4 wires and a hose clamp to the steering column and done. I had a small one for a bit but went up to the bigger size. It perfectly covers the stock tach without getting in the way of anything else.
Feels like I just keep moving wires around to what looks better. Just a bit more before I can wrap and loom everything. I'm super picky about how my stuff is ran. I redid the accessories in my Cherokee about 4 times and I'm still probably gonna redo that once this is done. Got the front end on and it's starting to look like a jeep again! Just waiting on parts now, shipping has been super slow with everything going on.
I used a 105 amp off a Caprice with the cop car specs. Bracket had to be trimmed a bit and I did reclock it so the power stud was in a better spot. Took me like maybe an hour and it fit perfect. Plugs right in.
Meme contest - lets have some fun! edit: cast your votes!!!
70barracuda replied to strictlyxjs's topic in The Pub
New fuel line questions
70barracuda replied to Jackrabbit41's topic in MJ Tech: Modification and Repairs
Speedway motors Corvette filter/regulator with an fittings brazed on. Don't really recommend it, as it bent up like a pretzel when I tried to tighten the fittings on. There isn't a nut on the actual filter to grab on to -
Clutch is bled. Feels pretty good for a 11 inch BBC one. Got everything that's supposed to turn on with the key working including the fuel pump. Leaked from 3 different spots...tried to tighten the filter locations and it bent and kinked the damn filter. Ugh, have to order up another one. Atleast I know the pump works. Also pissed like crazy out of the rail shrader valve, but it was just loose so that tightened up fine. ECU is mounted and well hidden. Got almost all the connectors together. Just o2 sensor and manifold intake temp. Hoping I can atleast fire it up this weekend maybe. Driveshaft should be here next week along with a short throw shifter. SO CLOSE
Russell's makes all kinds of adapters from various fittings types to an. Problem is alot of our stuff is Barb and for those you need to cut off the flare and have it straight, then use a compression type adapter from that to an. A new fuel filter can be had with an fittings already brazed on. Tank fittings are Barb. I ran rubber line from the tank to my filter then converted it to an because I didn't wanna cut up the sending unit. I'm doing a ls swap but same thing applies really. Unsure what the fuel rail fitting is for yours so that may be tricky. -
Does anyone have the locations of the grounds and which one is which? I'm looking for the g104 ground but can't find where it would be on the Jeep.
Awesome. Thank you! Now I just gotta find out what I need to get ignition and starter signal
Need some help on the ignition wiring. Went to try and just bump the starter on my ls swap and I'm getting nothing at the ignition switch. Is the factory computer needed for power to reach the switch? Any diagrams would be great.
