Tsalagi
Everything posted by Tsalagi
  1. Just realized I never got back to this topic. I replaced the torque converter and that solved the issue. I do still have a "whirring" sound that is coming from the drivetrain that I haven't been able to diagnose when it gets warmed up but as we know, this is a marathon not a sprint!
  2. There are other ones to compare but this is the one I got: https://www.amazon.com/dp/B07KYX715P/ref=psdc_15710001_t2_B079R95W17
  3. Good question because I saw some feedback on the Amazon sight about that. No problems there, even when it got dark. Still see fine and I already had tinted windows.
  4. The video instructions showed them installing one on a slider window so that is definitely an option.
  5. Back window screen.
  6. No way! That hurts because you are a role model with what you have done with her. You have done an amazing job on the truck!
  7. Waiting patiently on the behind the seat gun case instructions .
  8. Rebuilt the Peugot in this edition. They did discuss whether it was worth it or not but they decided to go the cheap route and rebuild it.
  9. Thank you. Since I felt something dragging I thought it could be transmission related. I will follow up on this and report back.
  10. Finally got the engine running as smooth as silk for about a month after putting in 02 sensor, new plugs and points, air filter, oil change and 4 hole injectors. Driving in the North GA mountains last weekend and as I started down a grade, I noticed a drag in the momentum for about a second and then it released for about 5 seconds and then did it again. I "felt" the drag and then noticed a small decrease in RPM's every time it did it. I have checked the MAP sensor vacuum line and that isn't an issue. I searched the website and couldn't find a duplicate of this issue. Now I notice it every time I approach a red light or prepare to turn somewhere. Not sure where to look next. All the Cruiser tips have been completed and I am stumped. Could something be "grabbing" in the transmission? Any help will be appreciated!
  11. JKU Winter Edition takeoffs, with the adapters.
  12. Saw this posted on one of the FB groups. More confirmation of a sending unit replacement. "Feels good to have a gas gauge that reads full and no more leaking gas or smell when I fill up! Replaced my leaking sending unit and gas tank with spectra fuel tank part #JP5A and sending unit part #CHP10148. This fuel tank has no pan in the bottom and the sending unit is for an xj. Direct bolt/drop in. Gas gauge reads correctly too. This worked for my 1991. Renix owners will need to use sending unit part #CHP10147 per my research. Scored them both from autozone for $140."
  13. Sharpie marker and baby wipes?
  14. I think people intentionally put the grills on that way just to bring attention.
  15. Same. And then I sprayed it with Flex Seal. https://www.amazon.com/Flex-Seal-Rubber-Sealant-Coating/dp/B00CD9FGNW/ref=asc_df_B00CD9FGNW/?tag=hyprod-20&linkCode=df0&hvadid=216743026518&hvpos=1o3&hvnetw=g&hvrand=15163651080470799398&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9010959&hvtargid=pla-392662396481&psc=1
  16. Made it sit in time out in the parking deck. New 17” wheels from a 2017 JKU Winter edition.
  17. That’s not really accurate. Easy to verify with your agent.
  18. So Pete had the correct answer in a nut shell. They are too short. Otherwise they fit perfectly.
  19. https://www.facebook.com/marketplace/item/2141794762743194/
  20. The last year of manufacture. The fewest models made, etc.
  21. Ha! I just want the lower quarter. It will help hide where some “knucklehead” bumped it. ;)
  22. I may give it a try to see what I can make of it since it appears no one has tried it. I will post pics if I do.
  23. Super Upholstery in Alpharetta GA. They have 4 locations in GA and AL. Mine was $500 for what I chose. Your mileage may vary.
