rylee144
    3
Everything posted by rylee144
  1. Only 250 pounds and I got this squat. Might need new leafs
  2. Finished my sprinkler system. My oh my was the yard rocky. Then it rained and the clay was a mess. Gotta let it grow in then level it a bit. Next project is a 20x13 concrete patio.
  3. trencher is in the back of the truck. the sod cutter worked so well. the trench beat me up, so sore today. lots of rocks 0600-2100 was a long day. then I spotted that gear oil leak from my front axle shaft. busy times around my place.
  4. And now I'm leaking gear oil from the brand new axle shaft.
  5. Sprinkler system is coming along.
  6. That mount was hard to find. I was very lucky a member here had an extra one.
  7. Pilot bushing I used https://www.rockauto.com/en/moreinfo.php?pk=221655&cc=1309452&jsn=925&_nck=ZExt1ysfqhqWnq%2BEvUNdS3Txyey60IDtnjPWF5UU9J0BWQv7pvqZbkEUk86%2BAYIhteHnM8iYlR4ebKH3uRnjZxcDb0o67mtPZBCV8ZwaYy9iATWCyKzrWw6zMoVZjeRvj6PPTkpMNTx95f9DaD7HdXOK3NBSaOc405yvcWxQAj5x6%2B5Zs%2FXQVizs%2F8emZNwVXMFNavEZjDi2LQQFoWloc8ScKPSEC3HSeLnRHye8icso1SEmYkCR018M%2FE6Awt8A5FYKrr7MGN5%2BFrW4OkIbjLQHeTJACesL%2BmLy9rWOab%2BrYUe3BnQikb6hLuN4yGvtMPhT5EU78RGOUuu2FByiMOzVmuh%2FAlf5 Slave with master cylinder https://www.rockauto.com/en/moreinfo.php?pk=1382128&cc=1180213&jsn=856&_nck=ZExt1ysfqhqWnq%2BEvUNdS3Txyey60IDtnjPWF5UU9J0BWQv7pvqZbkEUk86%2BAYIhteHnM8iYlR4ebKH3uRnjZxcDb0o67mtPZBCV8ZwaYy9iATWCyKzrWw6zMoVZjeRvj6PPTkpMNTx95f9DaD7HdXOK3NBSaOc405yvcWxQAj5x6%2B5Zs%2FXQVizs%2F8emZNwVXMFNavEZjDi2LQQFoWloc8ScKPSEC3HSeLnRHye8icso1SEmYkCR018M%2FE6Awt8A5FYKrr7MGN5%2BFrW4OkIbjLQHeTJACesL%2BmLy9rWOab%2BrYUe3BnQikb6hLuN4yGvtMPhT5EU78RGOUuu2FByiMOzVmuh%2FAlf5 This is a wrangler trans mount plate. The one you'll need looks like the second pic.
  8. Also my ax15 was from a wrangler
  9. I recently swapped in an ax15 I bought a slave with master cylinder attached. Also had to find a ax15 cross member and mount plate. I can send photos of anything your curious about. I tried to document in my thread but its lacking
  10. Re bled the master, we'll see how it goes. Found a couple leaks. Might need a new oil pan plug and a new seal on the slip yoke eliminator.
  11. wowza! nice work. I'm about to break ground on my backyard project. Sprinkler system and a concrete patio.
  12. Np good luck
  13. That's where mine came from too. It's coming along.
  14. Also the speedo no longer works
  15. Pretty good. Couple techs said I needed to bleed the clutch again and reverse should be there. I need to drive it more to figure out the sounds it makes and if they are good or not. Its geared way lower, I hit 5th gear sooner. I got some wheel spacers for the front until I locate some smaller misalignment spacers. They said the camber is off a tad but can't get it any better. He said the heim components won't let them dial it in more.
  16. Got the alignment done. Good people out at XO Fab
  17. https://www.facebook.com/marketplace/item/1311370835914419/?ref=facebook_story_share
  18. I will. Feels different than that tho. I'll crawl around and see what's what. Felt good to get out tho. Wife already put it to work, dump run and home depot trip
  19. Great. About 2 inches off the floor I start to go.
  20. I am out for a little put around the neighborhood so I feel better about driving to get it aligned in the next town over. Twice I hear a grinding sound when I hit a bump once on each front corner. Vast amount of possibilities but any guesses. Feels fine other than that. So many new things on the truck I'm not used to
  21. https://www.facebook.com/marketplace/item/306287570818764/
  22. Extremely frustrating! I'm glad you got the welder back. Sad truth that the justice system favors the crook and not the victim. Here in WA all drugs are legal now, terrible idea. Too much crime and no place to put them. Take a theft of 2k to be a felony as of last month. They get a week in jail as punishment so why not keep stealing.
  23. I got tied up, I'll have to report back later
  24. I'd like to find an xj shifter stalk someday too. The one I have is taller and feels weird. Guess I could cut out a chunk and weld it
