NCTyphoonKid
NCTyphoonKid's Achievements
I found some but would be interested in buying a couple as extras
Pretty sure no one has ever put a fuel pump in the Comanche if they did it was long ago. I used the Bosch 69302 fuel pump was a pretty easy install. Had to get another fuel pump o-ring for the tank and just went ahead and installed a new lock ring as well. Fingers crossed that leak is fixed.
Just finished pulling the tape should have the new tires mounted Friday. I painted the inserts a graphite color and resprayed the black on the caps
Been working on the turbine wheels I’ve been busy sanding the corrosion imperfections out and managed to get one polished and it looks great. Still need to paint the inserts and caps but should be ready for the new tires by the end of the week hopefully.
Thanks and just updated signature so it should show up now!
Picked up a set of turbine wheels and caps today a good cleaning and fresh set of tires they will be ready
Thanks I’ll see if they’ll ship them. If not then I’m still on the hunt
Thank you!
Wow that would be a long haul for me would definitely like to have them heck if I could find a set of caps to buy I would buy just the caps as i’ve found several sets of wheels local to me they just don’t have caps
The painter I have painting my blue z71 which is probably who will paint the Comanche used to have one and told me he had something that he would give me. Check out this gem a original bed mat. My bed is almost perfect from where I think it had a top on it for most of its life. Had to go dig it out of the painters storage building because it was buried.
Very true it definitely seems the Jeep stuff is a lot more difficult to find depending on the item. I’ve only had two jeeps the other was a 1984 CJ7 I usually deal with the more uncommon GM stuff. Couple pictures of the Comanches stable mates. The blue z71 is currently being restored.
Ive been keeping my eye out but no luck yet also tried car-part and no luck there either.
