avnsteve
Everything posted by avnsteve
The worlds Fastest Comanche
avnsteve replied to Worlds Fastest Comanche's topic in Member Projects: Your Comanches
I cannot imagine why one wouldn't join the stroker group, expecially with an MJ :nuts: -
New to the "Comanche craze" and lovin' it
avnsteve replied to Brenton's topic in Member Projects: Your Comanches
welcome aboard! If you ever need a hand, or wanna get together for an adult beverage with like minded jeople, I'm about 45 minutes away from you in Kyle. send me a pm sometime... -
How to install JEEP header emblems.
avnsteve replied to knever3's topic in MJ Tech: DIY Projects and Write-Ups
...and a leak! :brows: -
the truck, or the girlfriend? :brows:
20 ga is the stock dimension, cold rolled can be had for about 60 bux 4x10 sheet, and you'll easily find something to do with the rest...
HELP PLEASE with windshield leak
avnsteve replied to Squeegy410's topic in MJ Tech: Modification and Repairs
whoa!! hold on a moment! I bought the c2c pans, because they were the cheapest, it was a waste of my money. The pans were poorly sized, inaccurately formed, and i wound up buying more sheet to make up for what they lacked. AND, i had to reform the pans anyway. If you're going to do your floors, just buy some sheet and form it yourself. a 4'x10' sheet of 20 gauge in austin cost $55, those c2c floor pans cost 125! if you want some help, send me a pm, i'll be happy to walk you through it
Installed 2005+ Dakota Bench (Pics Inside)
avnsteve replied to comanche09's topic in MJ Tech: Modification and Repairs
those look really nice, I may consider that option as my bench sux right not, and I just put new floors in, I can still fab up any mount arrangement i want/need. thanks -
Driveway Tranny Drop...any tips?
avnsteve replied to ParadiseMJ's topic in MJ Tech: Modification and Repairs
ahh, lessons from our youth... i can remember the day too -
Renix era o2 sensor questions
avnsteve replied to cherokee's topic in MJ Tech: Modification and Repairs
I don't have the answer, but I know that 5-90 over at NAXJA will know that information. you can reach him by PM at NAXJA.org or go to his website and browse around a bit: http://www.kelleyswip.com/ -
"I'm already planning on pulling carpet when I do my seat swap here in a couple weeks. Any recomendations on a floor pan or what grade of metal to weld in?" 18ga will do, that's what i'm using, and it's close to original. my supplier only sells it 4X10 sheets, so I will have much to spare... I'm considering just fabricating a custom floor pan and eliminating the seams and all that crap...
good off-road setup???
avnsteve replied to M1A1TankerTom's topic in MJ Tech: Modification and Repairs
be very judicious about that bedliner on the whole truck, it do tend to hold dirt and will NEVER look good after a few miles of filth etc. -
yes i am. my wife cannot dig it. she thinks i'm in over my head. I explained to her if i could do this kind of work on a helicopter, then a truck should be a piece of cake...
OK, here I am. I've been lurking for awhile, and decided to post progress on my 87 long bed. I traded a small pile of camping gear for it. I thought it was a good deal (since it was all leftover army crap) I was browsing around here and read the "infamous" red text about pulling up your carpets and guess what!?!?! before Image Not Found after Image Not Found above is the drivers' side looking aft, that looks structural, so I guess I'll be making a new piece to stob in there... in the next pic you can tell, the floors were STILL wet from the carpet holding in the moisture! :shake: Image Not Found Image Not Found and finally here at the last pic you can see a little bit of progress. I tried a spot weld cutter, but the rust was SO BAD i couldn't tell where the spot welds were. So what I ended up doing was just cutting all the metal around the frame rails with an angle grinder/cutoff wheel, and then using an air chisel to reveal all the spot welds, then took a grinding wheel to the remainder. It's cleaned up pretty good now. I have no sure plans of where I'm gonna go with this truck, but i'm sure there's enough ideas here to give me some inspiration. please feel free to pipe up with your ideas and opinions
how do i install a speedy sleeve
avnsteve replied to comanche13's topic in MJ Tech: Modification and Repairs
HB is $45 at local parts store new (autozone) with warranty... -
did you install a mower deck on your MJ? what's that red rig underneath there? :brows:
How to bleed the Cooling System
avnsteve replied to Jeepcom23's topic in MJ Tech: Modification and Repairs
and if all that still doesn't work, back your rig up onto a set of ramps, you want the rear most portion of the head sitting higher than the rest of the engine, you can then remove the temp gauge sender and burp from there, I almost ALWAYS have an air pocket back there and thats how i clear it. -
sure sounds like the master cylinder has failed, the piston is hanging up in the cylinder...
What goes here?(Intake Manifold)
avnsteve replied to dancome433's topic in MJ Tech: Modification and Repairs
it's definitely not the brake booster, thats a much bigger fitting. on my XJ, that fitting runs to the vacuum ball from the bumper. -
CFC was never about oil, or fuel economy or the environment, anytime the government hide one of their programs under one of those guises, we jump on it like lemings...
is this a really critical step in the process? I'm just trying to be sure i do it right... :yes:
