Was out removing front end parts from a '86XJ. Broke a nut loose with a 1/2 inch ratchet and then unscrewed the nut off with my fingers. While unscrewing it the thought hit me. Bet the guys, and gals, in the rust belt can't do this. 'nuff said. While under there I noticed there is a narrow gap above the bottom of the torque mounting bracket. If some one was unfortunate to have the weldnut come loose on them, there is enough room to slide a screw driver or chisel, something wedge shaped thru this slot and jamb it between the nut and bottom of the mount. By cutting the slot out enough a guy could slip a box end wrench in there and hold the nut. Would also work when re-installing the bolt. This slot is on the inside side of the mount. Get under the Jeep and look up. You can see it.
