1992EliminatorSWB4x4
Everything posted by 1992EliminatorSWB4x4
  1. Thanks for the info, Kody sounds like a fine fellow for Jeep Comanche parts.
  2. Thanks, Hiow do i contact Kody Kilmer ?
  3. Thanks for the East Coast Gear info. I am holding out for a used complete Dana 44 rearend..
  4. Wanted to buy a serviceable used rearend Dana 44 with 3.55 gears for my 1992 Jeep Comanche 4x4. I am in Alabama. Thanks.
  5. Wanted for my 1992 Comanche. Dana 44 rear end 3.55 gears complete with drums and serviceable condition. Can be open carrier or trac-lock or truetrack. Bill in Montgomery Alabama
  6. I have a rust free 1992 White Comanche Eliminator 4x4 Short bed that I would sell. Still 97% original condition. Came from Calif and I have owned it for 7 years or so in Alabama. AW4 trans. Vent windows, Dana 44 Track Lock 3.55 gears with Up Country suspension. Nice original Comanche with very thin paint nowadays. A/C all there but needs freon. $10K is the price and less if I like you with extra parts. I just turned 77 years old and have to find an owner that will keep it up. Not perfect but very nice truck.
  7. You did good, it's cool I like it. Merry Xmas.
  8. Thanks, The Video was very enjoyable for me. Way to go !!!!
  9. Congrats !!! hard to beat a 91-92 H.O. Comanche. Your maintenance plans are just fine. Best of luck.
  10. Your wheels and hood scoop look just fine as is. Are they 16 in or 17 inch wheels, they tuck in the wheel wells just right, you probably have no spacers or adapters I am guessing and a 5 on 4.5 bolt pattern ?..
  11. Your Camo paint job is just great. I like your wheels, door vent visors and roll bar also. Outstanding look on your Comanche.
  12. Thanks for turning me on to these backup lights, just ordered mine from Amazon tonight. Since Don is happy with them I am sure I will be also. Nothing like good lighting at night when I back up my boat trailer to launch. Bill
  13. Our Comanche truck sun visors mount with 3 screws. I would like to change mine from the soft fabric to a harder vinyl similar to what they use on earlier Jeep Wranglers but of course those will not fit. Has anyone used a different sun visor maybe from a 80's Chevy truck or any other manufacture . ? Vinyl would be nice for me and would not show greasy finger prints and you could wash them off easily. Thanks.
  14. Don, thanks again, got a 1994 Cherokee 4 door passenger seat today from pick- n - pull yard today for $25, took the seat apart and put the bottom pan and foam on my 1992 Eliminator using my original seat bottom fabric that is still in great shape, the pan fit like a glove and was a pretty easy job swapping them, now I finally sit straight and not crooked, glad I did it. Thanks for your great advice and help. Bill
  15. Hornbrod, thanks again. so the metal pan is the same up to 1994 mj/xj bucket seats for both drivers and passenger seat side, Correct? If so I will go junkyard hunting tomorrow. those new one are super expensive wow. Bill
  16. My 1992 Eliminator bottom of Drivers seat has a cracked broken metal pan that is located below the foam. Will a 4 door Cherokee pan and/or a 2 door Cherokee both fit OK up to years 1996 or so? The numbers on the bottom of my pan are 8F C35 ( ) 1371 and 65418 PAN, and 30889. Any one have that pan they could sell me also? Thanks from Alabama.
  17. I used a long about 8 inch round flat tip 1/8 inch diameter punch also, tapped mine out from the drivers side of engine. Best of luck to you.
  18. Great write-up on the RedTek . I just ordered myself some from Amazon. I did not know this would work Ok, so my thanks to Hornbrod for the great info. Bill in Wetumpka Alabama
  19. Ouch !!! Big Bummer for your Comanche. Difficult to dodge those deer sometimes. Body Shop should make it pretty again soon. Just one day at a time.
  20. Thanks Hornbrod, guess there is no fooling the computer stuck with the 3 revolution start up I guess. Long live my Comanche.
  21. This: http://www.ebay.com/itm/One-Man-Reverse-Brake-Clutch-Bleeder-Kit-4-FREE-EPDM-Brake-Bleeder-Caps-/272279487374?hash=item3f651f438e:g:Bz4AAOSw~oFXL7ZK&item=272279487374&vxp=mtr
  22. Might try reverse bleeding system using a small hand pressure pump, worked great for me and less than $20 for the setup on Ebay. Its so easy.
  23. having owned 4 total 91& 92 Jeep Comanche's I wonder what takes them 3 revolutions to start up. Is it oil pressure sensed by the computer or something else. My 1998 Chevy 350 sits in the driveway all week and I start it every Sunday and you just bump the key and it starts on 1st revolution and I like that. . Is there a way you can fool the 4.0 liter H.O. to start quickly. Bill in Wetumpka Alabama.
  24. Might check your steering box for play. Also check the rag joint or steering shaft above the box. Good luck.
  25. Hornbrod, down south in Wetumpka Alabama, I have had to many dillo's . I trapped 16 of them last year in a live trap. Tried sitting out in the yard, we are on Lake Jordan, all night waiting for them with my shotgun in hand but that is just to time consuming. My best way was to take two long boards 6 inches wide and about 12 feet long and funnel them into the trap, no bait or nothing in the live trap.,also if you have a fence put a live trap along the fence, they can not see well at all especially at night. Now I always have a live trap along my board fence and catch one occasionally still. Hope you catch them , they dig lots of holes looking for the white grubs in the soil. Lime on the grass helps as it eliminates the grubs. Best of luck !!!! Bill
