89eliminator
    2
Everything posted by 89eliminator
  1. post it up anyways
  2. plus that kit leaves out some important items like lower and upper control arms. probably best to stay away from that lift.
  3. i would lift the truck and go from there. if you don't experience any vibrations, than why drop the t-case. i never experience vibrations from the the front driveshaft, but did from the rear.
  4. $2.15
  5. Thanks, i always wondered how people did that.
  6. welcome! i've seen vids of it with a toolbox in the bed. i always wondered what was in it. weight?
  7. well, I'm been gathering some parts for this winter's modifications. here is a list have: rubicon express brake lines bumptops for front rear bumper shackles need: tubing for longarms, will be going with a true 4-link design rod ends limiting straps front Aussie locker money :yes: shocks so pretty soon, it will be tear down time :thumbsup:
  8. depends on what kind of terrain you run. obviously, they arent gonna be as good in the mud as a mud terrain tire. they seem to perform well on the rocks and trails though.
  9. exactly. this should be done for every vehicle you own. saves a lot of hassle if you were to ever get locked out.
  10. what do you do if you lock yourself inside the vehicle? :hmm:
  11. plus in one of the videos, the description says he is testing out a new "Cal-tracs type suspension". also he has slicks and internal rollcage. plus i've seen vids of it with a toolbox in the bed that definatly wasnt full of tools... also, look at the thing twist on take off.
  12. non-disconnect, high pinion to be exact.
  13. north dakota and wyoming as well :hijack:
  14. north dakota and wyoming as well :hijack:
  15. but, depending on the height of lift your going with, MJ's don't look that high when lifted. I'm lifted 6.5in with 33s and its about the height of a stock fullsize truck. i would think that you could get away with pretty much any reasonable lift (i.e. 8in or lower)
  16. but, depending on the height of lift your going with, MJ's don't look that high when lifted. I'm lifted 6.5in with 33s and its about the height of a stock fullsize truck. i would think that you could get away with pretty much any reasonable lift (i.e. 8in or lower)
  17. http://www.roughcountry.com/lift_laws.html
  18. http://www.roughcountry.com/lift_laws.html
  19. this is what i run. it will work on your motor. http://rustysoffroad.com/mm5/merchant.m ... de=PER_AIR
  20. this is what i run. it will work on your motor. http://rustysoffroad.com/mm5/merchant.m ... de=PER_AIR
  21. thats what i would do. or you can piece together your lift with new/used parts which is what i did. while looking for a lift, make sure that everything listed above is included.
  22. thats what i would do. or you can piece together your lift with new/used parts which is what i did. while looking for a lift, make sure that everything listed above is included.
  23. don't go with a 3in shackle. thats way too much in my opinion. just go with an add-a-leaf or a whole new leaf pack. you'll be happier in the long run (especially if you go with a new leaf pack). for a 5in lift, you'll need to address the upper and lower control arms, brake lines, shocks, sway bar end links, tracbar...
