PEEJ
Everything posted by PEEJ
  1. Did I read somewhere that some X.J. Wagoneers came with a front Dana 44? If so,How rare are they,What years,ect.
  2. I agree,Flip the grill,Gas er up,and drive er,Real nice truck.
  3. You would be way better off finding a doner X.J. of your liking.Thats what I did,All your nuts, bolts,linkage,hoses,wires,ect.will be right there.When you get done,part out what you can scrap the rest.
  4. Non Ethanol down to $2.95 down a dollor since drop started.
  5. Just got back from my annual Missouri hunting trip,On the way back I passed 7 different Comanche's in about 1 1/2 hours between the towns of Stover and Buffalo,Turned around for 1 in Fristoe stopped at a tire store but he had allready left,But parked behind the tire store was another Comanche (possible parts truck)Just ain't use to seeing that many Comanches.
  6. I am going from MJ bench to XJ buckets.Got a sweet deal on a nice set set of 94 XJ buckets in perfect shape and found a set of MJ brackets on C.C.
  7. What does it take to make 94 XJ buckets mount on Comanche bucket seat brackets? Thanks
  8. Ask around the XJ crowd.
  9. I.d go with the 89 I'm doing allmost the same swap as you,I.m using a 88 XJ doner for a 89 MJ conversion.Going from a 5 speed to an AW4 NP 242 I.ve allready swapped in the front and rear axles ,That was easy enough,From looking at the XJ, everything seems to be a straight swap.Gotta drill a few holes on the side of the hump for some linkage.Having a doner vechicle is really a big advantage over just gathering up the parts.Good luck which ever way you go.
  10. Did not get your PM . May still be interested try texting 931-622-6035 Thanks
  11. I run non ethanol in my Comanche ,Jet Skis,4 wheeler and lawn equipment.It's still around $3.25 around here. But that's a big drop from where it's been,Any one else running non ethanol in their Comanche?
  12. 54,After seeing this post I feel really old.
  13. Looking for a set of Comanche bucket seat brackets shipped to the middle Tennessee area,Thanks
  14. Straight axle is an 89,Dana 30 is an 88,Thanks
  15. Are the rotors and calipers the same on a 2wd. straight axle and a dana 30? Thanks
  16. Are the rotors and the calipers the same on a 2wd. and a 4wd.
  17. Thanks guys,I've got the doner XJ,so I should be in good shape.
  18. Is the full console in an XJ the same as the ones that came in the MJs?If not what needs to be done to make one fit an MJ. Thanks
  19. Man that looks good,Anyone remember the Blazer Chalet?
  20. Has anyone lengthened a rear XJ driveshaft to use in a swb. Comanche. Fixxen to do my 4wd. swap and plan on shortening my rear MJ shaft.The driveshaft shop is around 90 miles away,Spoke with the owner over the phone.He said he'd do it while I waited to save me from making a return trip.My only concern is the rubber centered 2wd. driveshaft and possible ballancing issues .If that becomes a problem I need a plan B .I'd rather pay more to retube the XJ shaft than hunt down the proper shaft and have to make the 180 mile round trip again.Plus the truck will be down till that's resolved.Thanks in advanced
  21. My bad.Didn't know that.
  22. Looks good,I like it.
  23. Passed a Comanche this afternoon on Hwy. 70 going through Waverly TN. wondering if it may be a member.Believe it to be a 91 or 92. I believe its this one I seen several months back.Nice truckImage Not Found
