Spectormj
Everything posted by Spectormj
  1. The thing that bugs me is how they say its a Comanche the cab line doesn't work as a bed line..
  2. I saw my old truck once and I guess its bouncing around out there somewhere
  3. Well ill be a monkeys pecker you had a good trip I bet
  4. Welcome Keep up the good work
  5. So much shiny.. I like the blue paint
  6. You can still torch things. Hell if you fubar the cat cutting a bad exhaust system you can get a new one at the parts store or the nearest muffler shop
  7. Its a swb mj the fuel door tells all. Its more centered between the door of the cab and the rear fender. Lwb Comanches the flare is closer to the fuel door
  8. Rainwater don't ya know that to quickly and painless remove exhaust systems apply a torch and cut
  9. This seems like good news/progress for ya
  10. Trophy truck buid would be fun cause prerunners are so open to debate. Just don't be like the Chevy Reaper....its god-awful ugly and a Ford Raptor want to be
  11. The beer is good but ill see about bringing some good ol corn lyker fresh from them thar hills of Tennessee
  12. I'm not sure if a standard trans has a neutral safety switch. I know auto trans have em
  13. Summers sounds good to me. Cause I'm bringing a hammock
  14. August works for me Ya ill be between jeeps but ive got wheels and 4wd so ill be there.
  15. But also know water +electronic devices and hot engines and oil cavitys can be bad
  16. Its food for thought. Ive seen it work on the wranglers. You can go up to the hood with the cowl. Personaly I like the full snorkel but if money is tight go for the cowl then change over to full after
  17. I'm not sure if the mj and xj would accept this but I know a lot of tj,yj,jk guys that instead of a external snorkel they relocate the air intake to the cowl under the windshield
  18. Its a different looking mj. Id drive it but it might be a pita to get to it out of where its at
  19. And if I bring the truck I'm driving now it will be loaded with my gear my gun and a lot of straps and chains
  20. I am but ive still got a 4wd. sides it would be fun as hog killin day to meet more of yall
  21. I'm up for anything.
  22. You sir are lucky you didn't hydrolock
  23. This^^^^^^^^^^^^^^^^^^^
  24. Pull your plugs drain the oil and let it dry then new plugs coil and oil
