Automan2164
Administrators
Everything posted by Automan2164
  1. Yep, thats an 8.25. Did you check the gears yet? Sometimes you can get really lucky and find the tag on the outside, but I would still pull the cover to check the gears and change fluid. Rob L. :cheers:
  2. AND winch!?!?!?! For $250? Dayem. Wish I could come across something like that. Rob L.
  3. Welcome to the club. General questions will get more attention in the Pub, I moved them for ya. Rob L. :cheers:
  4. Automan2164
    dual tc's
  5. That will be an 8.25... Good catch. Check the gears and throw 'er in man! Rob L.
  6. Probably wildman. :D Rob L.
  7. Automan2164
    magazine
    What the hell. You make it, I'll buy an issue. :thumbsup: Rob L.
  8. Sure it's not leaking up by the firewall? Rob L.
  9. I have a feeling it had to do with the complaints from their bumpers. Rob L.
  10. You might have gotten lucky. Most 4.0L, auto XJ/MJ's came with 3.55's already... Now notice how I italicized most. There are some oddballs in there. You might only have to switch the rear axle. Rob L.
  11. viewtopic.php?p=167318#p167318 Found it, here is the start to his gate. Rob L.
  12. CWlongshot did... Now if I can only find his build. Rob L.
  13. Keep all of your suspension stuff. You should be good with that. As for the perches, Mopar actually has some really nice perches you can get from the dealer, really long, and stout. Mr. Hornbrod will have to chime in with the part numbers though. Is the cherokee a stick or auto? Rob L.
  14. :hmm: I miss something? Rob L.
  15. Not many magazines have anything about a truck they only made 190,000 of, and I'll bet of which half still exist. JP is a good one for XJ stuff, and Jeep Junkie, which I find from time to time. Occasionally, you will catch an MJ in the readers rigs, but RARELY and I MEAN RARELY will you find a piece with the MJ in the limelight. Last time I saw that, it was in JP, and they were talking about common problems with the leaky fuel rails on XJ's, and they used an MJ as a demo. Rob L.
  16. Do you know how to weld? The cherokee is a spring over axle. In order to make it work, you will either have to weld perches underneath to retain your spring under on the MJ, or re-weld perches up top to fit the comanche's spring width. Front will be a direct swap. Rob L.
  17. Automan2164
    diesel ?
    AX5. Rob L.
  18. You can check that by pinning out the trans connector, and measuring the ohms of the solenoids. Someone else will have to chime in here about that. Rob L.
  19. Nope. The RENIX models don't even have a check engine light in the way you think of one. It doesn't store codes, or anything like that. IIRC, all it is, is an emissions light. Rob L.
  20. I have heard that about the used car lot thing. They are going for a premium now because the stock is low. Rob L.
  21. Yep, could be. Now, is the chipped gear on the little gears inside the carrier, or on the big ring gear, or the little pinion at the back? Rob L.
  22. Easy.......stick you head out the window, and use the rear view mirror on the side of the door :yes: From what I've seen, the lighted vanity mirrors came with the "lighting package" which also included the floor lights, and I think the under hood light. Who knows, these things had so many options that could be added.......I guest, anything is a guest :dunno: BTW.........Nice grab there Rob :yes: But its weird, because it has the lighting package, and has the footwell lights. Rob L. :dunno:
  23. On the ring gear, there will be two numbers a little off from the rest, but together. It will be the number of teeth on the pinion and the ring. So... if you see a 41 11 divide 41/11, and you get 3.72727272... round that, and you get 3.73's. Most common gears in '86 with your combo is 3.55, 3.73, and 4.10's as an option... Keep us posted. Rob L.
  24. It had to have one from leaving the factory. That plate light was on some MJ's from factory hidden up there... Rob L.
  25. Whoa, can we get more details? Rob L.
