Everything posted by Htchevyii
It wasn't great. We managed to avoid all but one city. The biggest problem was if I had to stop on a incline, it wouldn't crank over fast enough to start. That happened twice and my dad pushed us with his JL. I think that it would have started in low range, but then we'd be creeping to a flat place to up shift and restart. I don't want to repeat hence the AA kit.
Yep pesos. I think it converted to just under $1000 USD.
Man, I like this rack with the opening sides. It would keep me from having to crawl around in the bed. It would also be nice to be able to access items in the inside of the swing up panels from outside. It also looks like a rear door could be fabricated fairly easily effectively protecting items in the bed from theft. They are in Mexico, I emailed them to see if they'd ship but did not receive a reply. I guess we might have to plan a trip to Mexico? I'm currently using a modified ladder rack. It does the job but not as good as this would.
I've found the 15w40 Delo or Rotella to work well in older engines, (as have many others). The diesel oils still have more anti-wear additives than regular oil, but not as much as they used to. The viscosity seems to be a good compromise and it's relatively inexpensive by the gallon. I've also been adding 2 ounces of Redline break in additive per oil change. Proceed with caution if you have a catalytic convertor as the anti wear additives can foul them.
I think the included adapters pretty much cover the bases. The parts list for the kit that I ordered shows that it comes with all of the adapters shown below. That is one of the reasons that I went with their kit, I've seen people splicing lines together or having to grind out master CYL mounting holes to mount. I'm also not too crazy about the later plastic hard line. I'm hoping to do it right and do it once. That throwout bearing is definitely a concern. If I don't like it, I'll order a Timken. I couldn't find where anyone had used this particular kit, so we shall see.
There are lots of cool parts on my wish list that I'd rather be purchasing, but after driving home 488 miles from the Black rock Desert with no clutch disengagement whatsoever, it looks like the AA external slave kit is it. Actually, it's already on the way from Summit Racing and expected delivery is 2 days. Dependability has to come before "cool stuff". I looked at piecing together the parts to save a few bucks, but there are no wrecking yards around here. By the time I bought the bellhousing on eBay and ordered the parts from multiple different sources and waited who knows how long, it didn't seem like it was worth the hassle for a few hundred bucks. I'll let you know how the install goes. The clutch setup is a LUK kit with under 15,000 miles on it, (the master and hose were also replaced). The slave failed suddenly and catastrophically. The fluid was leaking out of the bell housing as fast as I could pour it in, even if I didn't touch the clutch. The Comanche was working great for the first week. The only issue was a sticking IAC motor. I finally unplugged it when it returned to a reasonable idle speed and just gave it a little throttle in the AM. Of course, on the first fuel stop after the clutch issue fuel started leaking out of the sender. The lock ring was still tight. I need to get a few trips under it's belt without problems so it regains the trust of my wife! Part 1 of the trip is on YouTube. More to come. My parents' 2020 JLU did have a problem on the trip as well, but it was just a low fob battery that made the alarm go off when you opened the door with the key.
Need fuel pressure regulator brand advice - 87 4.0
Htchevyii replied to 87MJJeep's topic in MJ Tech: Modification and Repairs
I used a Delphi FP10504 because it was the only one that I could find that wasn't made in China. I think it was made in Mexico. -
There's two that I regularly see on the road and a couple others sitting in yards that I keep an eye on. One is pretty straight, but has been sitting with the window down for a year or so. 2018 tags on the plate. He wouldn't sell the last time that I asked.
It was just a kit to convert the mini console to the full console. For some reason, there was way less markup on accessories and performance parts than replacement parts. I remember pulling a "Mopar Performance" gear reduction starter out of a box and it had a standard PN on it. It came up as fitting a v6 mini van at about double the cost. I wish I could have bought more stuff at the time, but I was poor.🙄
I worked in the parts department at a Dodge dealership from 1998-2001. I remember "5 star" being a big deal at the time. I have a 5 star watch somewhere as well as a Mopar one. I had the Comanche at the time and remember buying Manual window regulators, interior lamps and a closeout Mopar accessory XJ center console for dirt cheap. Too bad I didn't buy some tail lamps!
Interested to see where he goes with the MJ. Simple shop truck or built off roader?
Great! glad to hear it. We are investing is some better equipment so hopefully better quality videos will come soon!
Not sure how many of you are running the long discontinued Spectre cowl intake, but I found an easy solution for the hard to access oil cap. I found a NOS one on eBay a few years ago, but tired of pulling the whole thing off to add oil. Speedway sells a kit to add an oil fill cap. It's a little tedious grinding away the fins to make a smooth surface, but worked pretty good. https://www.speedwaymotors.com/Valve-Cover-Oil-Filler-Cap,48973.html VID_20220909_124110675.mp4
I believe they have been discontinued for years. I lucked out a few years ago and someone Had several NOS ones for sale on eBay. PN 9945.
You can often get wheel boxes from a local tire shop. I have been using Pirate Shop lately for UPS and USPS an a significant discount over consumer rates. I hear that Fastenall also has good rates, but I have never used them.
Thanks! That was rough, it took a bit to regroup but in the grand scheme if things, it's just a story not tell now. I think my wife still has a little PTSD, but she is still ready to go on more adventures.
I can't deal with the peeling clear. Old paint maybe.
Our friends are moving out of state and owned about thirty vehicles. They got tired of making trips and gave us a 1989 Cherokee. I don't really need another project, but how could I say no? It's a desert rig, so it's rust free, but has baked paint. The story is that the PO paid someone to do an engine swap and put in a good running 92 HO engine. He swapped over the Renix parts and it has never run again. My friend did some troubleshooting and was pretty sure that they didn't change the flexplate to the Renix, but never got a chance to dig into it Confirmed!, it does have the HO flexplate! Hopefully I'll have a decent running rig with a little work. I am dreading the paintwork though.
We've had quite a few requests for a walk around video. Posted now. https://m.youtube.com/channel/UCCUwO90LMyZCxrYMzhP6Jwg
Thanks for watching!
Hi guys, Thanks to everyone who was interested in our YouTube videos and the Comanche's resurrection from the lake incident. It is back better than it was and we just completed a 600+ mile trip to camp with YouTube celebrities Jason from Primal Outdoors and Donald from Soft reading the West. More to come. https://m.youtube.com/channel/UCCUwO90LMyZCxrYMzhP6Jwg
The Golden Eagle Comanche that Jerry Bain built has a cut down aluminum shell with a rack built around it. So sweet!
