Red 1989 MJ
Everything posted by Red 1989 MJ
  1. Any suggestion where to buy the right gearing ?
  2. I just bought a 1990 4.0l MJ auto. 4x4 long bed for parts. I want to swap the D44 to my truck. My truck is a MJ 1989 4.0l AX-15, short bed. Could somebody tell me if auto and manual have different differentiel gear ratio?
  3. Welcome to CC. :clapping:
  4. You have a copper tab on the e-brake pedal under the dash. The circuit will stay open if your e-brake pedal is not height enought. :D
  5. We made this little repair, you will need a multimeter and patience. :D You have to pull out the fuel pump unit, the sending unit is attache with it. You could do it without dropping the tank. Diagnotic: - Could be a connection,You will see a wire attached to a rivet, check for the contact. - If not working, You will open the little plastic cover of the sending, you will see a coil of wire. Check the coil for any wire cut(variable resistance). The reading should be between 0-95 ohms. I think: 95 ohms for empty 0 ohm for full Good luck :waving: PM me if you need more info
  6. Welcome to CC :clapping: You hace a nice truck for your projet.
  7. Very Nice I love Red MJ's. :thumbsup:
  8. I have a good experience with CC. Always have somebody to help. :thumbsup:
  9. Watch out where you put your shoes ? :yes:
  10. :clapping: This is a good one.
  11. These covers are for the cab ventillation. You can pull them out. :D
  12. You can use the part from a XJ from the same year. The pressure bottle is the same. :thumbsup:
  13. Nice truck Welcome to our madness. :clapping:
  14. Welcome !! Nice truck, I love the resto project. :brows:
  15. Welcome to our addiction. Nice original Truck :bowdown:
  16. I prefer stick over auto, better control and fun. :banana:
  17. That is what I find in FSM 1988 Send you a PM
  18. Make me fill sad !!! :shake:
  19. I am curious too !!! :brows: How much you get ?
  20. You could leave the PB work a couple days and retry. You could heat the bolt. You could also drill it and make new thread. :oops:
  21. Welcome to the club :cheers: Post some pictures Where are you located.
  22. I installed a new cat + muffler Sound great
  23. Did you get it ? Sorry, but they are hard to find. I have to inform my fellow comancher. :yes:
  24. So the week-end was good for my MJ. :D We put A new Cherry Bomb Turbo + Cat.. It's sound great with low bass and louder sound at 3000 rpm. I am very happy. :rotf:
  25. Thanks Boilermaker I didn't know what i did wrong. Somedy help me ?
