Everything posted by Backdraft
The front is 4.5 inch Rubicon Express coils with 2 inch spacers (should have just gotten the 6.5 inch coils) and TnT Fab long arms. YJ brake lines. And Bilstein 5100 shocks. The rear is SOA with original perches and 2wd leafs. Dakota brake line. And Bilstein 5100 shocks. I'll try to remember to snap a couple of current pics today! She lives in the garage on the days she's not being driven.
Cheers Gents. How've you guys been doing?
I'm not sure if they are around anymore. I ditched that setup a while back in favor of a Dakota fuel tank and pump/sender. More capacity and pretty accurate reading. Good news is everything is still working as it should and it gets driven from time to time.
I had to park the Comanche this past spring. The blower stopped blowing and I'm not driving in the summer heat with no A/C. Between work, other projects, and single dad duties I haven't had much time to focus on it. The 2 year old optima red top seems to have died on me and won't take a charge. Boo! Once I get a weekend to call my own, I plan on tossing a fresh battery in and getting to work on making the blower motor spin again.
Thanks a lot man. I appreciate it. There was a lot of blood sweat and tears that went into it. But I couldn't be happier with the outcome. We're only 45 minutes from each other if you ever want to take a look at it.
No sir,not really. Just maintenance. Shamefully I haven't given it much attention lately. Work and family has taken the lions share of my time. But shes still trucking along. I kissed the rear end of a Mitsubishi Eclipse a couple of weeks ago on the way home. Back end of their car was dented in pretty bad. My front bumper didn't even have a scratch. I guess that's karma for you when you cut someone off and slam on your brakes!
New Texas member with '88 Chief just acquired!
Backdraft replied to Kickinmule's topic in Member Projects: Your Comanches
Hey man, If you ever need any help, gimmie a shout. I'm just down the road from you. :thumbsup: -
The ring I bought. However, I never liked the way it all worked. I could only use about 3/4 of my gas tank because the pickup for the fuel pump doesn't reach the bottom. What I did was replace it with a Dakota 22 gallon tank and pump/sender assembly. The fuel gauge reads more accurately, reaches the bottom of the tank, and gives increased capacity. There are a few threads floating around here on the subject. I also have some highlights in my build thread I think.
6.5 inches
I'm looking for opinions on aftermarket adjustable track bars. Thinking about ditching the one I have and going with something different. So what do you guys like? What do you prefer? What have you run successfully? And why? Thanks!
Thanks for the compliments guys! I really like the bumper. It went together easy, their directions were simple, and it looks pretty darn good.
I'll admit. It was a fun ride!
Had one of those curvy ones once. I thought with certainty that she was going to break my bed.
http://www.jcroffroad.com/mm5/merchant.mvc?Store_Code=J&Screen=PROD&Category_Code=XJB&Product_Code=DIY-MJ-R Bottom photos
Haha, Jay. I have a few days off. I'll have to see what I can come up with using all my scary black "assault weapons"! May go annoy some liberals and chase them down the streets in the truck. Because, you know, I'm a terrorist with those guns. I drive a gas hog that destroys the environment. All those horrible things!
Ryan, the outlet is powered using the same wires from the power socket I pulled out. I cut the OEM plug off and crimped female blade connectors on to the wires. I picked that side because the fit was better and it was also switched power.
The headliner is from Steve at SMS Headliners. The backboard is pretty thick and stout. I lined it up where I wanted it and marked it. Then cut a hole in the headliner for the hanger on the console to slip into. On the front. Its held up with two screws. I just used the two from the donor when I pulled it.
Alignment After Lift
Backdraft replied to JeepComanche89's topic in MJ Tech: Modification and Repairs
Agreed. I'm at 6.5 inches and running V8 ZJ steering with a stock pitman arm. And I have plenty of adjustment left on the sleeve. Unless one of your tire rod ends are bad or the drag link/tie rod is bent, you're stock steering should be able to perform. If they didn't give any better explanation than that, I'd be leery of their intentions. -
How Best To Fix Wheel Well Rust?
Backdraft replied to Biotex's topic in MJ Tech: Modification and Repairs
You're right. With the bushwhackers, the only trimming is on the front and rear of the wheel wells. -
I Let My Plugs Go To Long... 42K
Backdraft replied to airspeed's topic in MJ Tech: Modification and Repairs
Well crap. Sorry. I'm at work and in serious mode I guess. Please disregard and carry on. -
Um, Don........his sig says he has a 2.5L -
Thanks to a thread from Sir Sam a while back, i decided i needed another little doodad in my truck.
OK Eric......where are the pictures?!?!?!
Talked to Eric as he crossed in to Texas. Truck appears to be running fine. His spirits were up. I got a feeling the bonding experience is close to fully cemented!
